Question about Quick Hector Windlass, hector windlass 1500w 24v 3/8in Quick
Hector anchor winch - Quick Hector Windlass, hector windlass 1500w 24v 3/8in Quick
  • Andre Beaulieu Jul 13, 2013
    Any idea were I can download service manual on a Hector Quick 1500anchor winch
How to tighten vinyl coated steel cable
go to the local hardware store and get wire tensioners
they are like a minuture winch with a ratchet cog
probably less than $5.00 each
anchor to one posr and put the cable through the drum and wind it up with a screw driver or rod
do not make the tension too tight or the cable will snap in windy conditions as the trees move apart from each other
May 22, 2017 | Birds
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Gearmatic winch 19 on a Cat 518. Winch pulls in powerfully all the time. Lever position does nothing.
    Byron: On site, Captain_Crunch said: "
  • Little band applys big band there is a toggle block at anchor point (rear of houseing) my guess is it is siezed that was our problem."
    Or, Try watching this YouTube video: https://www.youtube.com/watch?v=iZFGmWYmYnA
    May 25, 2015 | Cars & Trucks
    Electric winch
    Is there a load switch on winch
    Jul 13, 2012 | Electric Superwinch 12 Volt DC Winch -...
    Unit will not pull up the anchor
    First, put a volt meter across the winch's power terminals to verify that the voltage is not dropping several volts when comanded to run, indicating a bad cable connection somewhere. Anchor winch's pull alot of current from a battery.
    For a test, use car jumper cables from a good battery to the winch to see if it runs better.
    Oct 18, 2009 | Boating
    Anchor winch
    There is a great chance the clutch has frozen due to corrosion.It need to be pulled apart at the clutch.Its not a big job and quiet easy.The plates freeze together and need to be "cracked" apart.I hope this helps
    Sep 23, 2009 | Boating
    Quick Hector Windlass, hector windlass 1500w 24v 3/8in Quick Logo
    102 people viewed this question
    Top Quick Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Quick Boating Expert? Answer questions, earn points and help others
