Question about Pavilion HP Pavilion DV4-1225dx AC Adapter - 90 Watt (Replacement)
Laptop turns off when optical drive start to work
I have Pavilion HP Pavilion DV4-1225dx. it's optical drive (spare part no 497523-001) has a problem that, when i insert a cd or dvd and when the optical drive start to work, then laptop turns off.
    Sergeant:
  • 402 Answers
I will start with a battery test looks like the motor is drawing too much current for ac support only .
Posted on Aug 14, 2013
How do i change the cd rom on a hp pavilion laptop
Hello Turn off your Pavilion laptop and remove the AC power cord. Slide the battery release lever to the unlocked position and remove the battery.
Read more: How to Remove a CD-ROM Drive From a HP Pavilion Notebook N5425 ' eHow.com http://www.ehow.com/how_6138972_remove-hp-pavilion-notebook-n5425.html#ixzz2BTQ7dMMi
Remove the small Phillips head screw on the bottom of the laptop. This screw is used to secure the optical drive to the laptop case.Grasp the front of the CD-ROM drive and carefully slide it out of the bay. Slide the replacement drive into the bay and secure it with the Phillips head screw. Then replace the battery, connect the AC power and turn the laptop on.
Good luck
Nov 03, 2012 | Computers & Internet
The bios don't reconize my opical drive for a quanta 30D1 motherboard on a notbook pavilion dv 9700
Please post more information: Is this an external - it sounds as if it is - and is it connected via USB or some other method, like firewire?
Do you attempt to connect it immediately after restarting your computer and waiting for the startup to settle down, as in, the desktop is all configured and it has stopped adding items?
Also, did this optical drive come with a disk with a setup program, or specific drivers on it?
If so, did you do the install, before plugging in the drive? If the drive is already plugged in when you start the install, that might have an adverse effect on it.
Please let us know. Or, try the suggestions, above, and let us know if they helped.
Cheers!
-a.
Apr 10, 2012 | HP Pavilion Computers & Internet
How to care my hp dv5 battery? buy the hp dv5 battery from http://www.batteryfast.com/hp/pavilion-dv5.htm
For long life battery:
-Don't play computer games, music or DVD movies - Multimedia activities drain laptop batteries.
-Disconnect all external device like PC Card modems, Firewire, USB devices and optical drives. Use the notebook touchpad instead of an external mouse.
-Adjust your screen brightness - Dimming your display saves battery power.
-Tweak Windows Power Options - Choose a Laptop power scheme that turns off the notebook monitor and hard disk after 10 minutes of inactivity.
-Decrease or mute the Laptop Speaker Volume.
-Programs that are run from a CD or DVD can be copied to and run from the hard drive, which typically consumes less power than an optical drive.
Mar 19, 2012 | Computers & Internet
Hp pavilion dv5-1125nr dvd player does not read cds or dvds it spins i did drop the laptop can i remove and reinstall the drive and try that? how?
Yes you should try that if you really think it is broken. Make sure you pull the DVD drive slowly and carefully. Also make sure you know how to take it out. You don't want to break it.
Sep 03, 2011 | HP Pavilion dv5-1125nr Notebook
DOSE THE hp pavillian dv7 have a burner for cd or dvd
Hello and Welcome to FixYa!
Hp DV7 comes with both, COMBO as well as Super drive. It depends. Most of the models, are usually equipped with Super drive that means, it came with DVD writer..
Have a Nice day,
Concerned.
Jun 28, 2011 | Computers & Internet
I have a hp pavilion dv9730us.cd/dvd drive is missing in windows 7 device manager,and is not recognized in bios(cannot boot).i removed the optical drive,and tested on another laptop.is working.i put back...
Up date the bios and than reinstall the chipset, also check in device manager for the make and model of the optical drive and update firmware before that run this link from MICROSOFT
Dont forget to say Thanks!
Aug 11, 2010 | HP Pavilion dv9730us Notebook
My HP Pavilion dv1130us DVD optical drive will not read CD's nor DVD's,. It seems to try; but doesn't execute. What can I do?
You can try a cleaning disk, but optical drives don't seem to have a great lifespan. You may need a new drive.
Apr 12, 2010 | HP Pavilion dv1130us PC Notebook
How do i remove and install a optical drive on my HP Pavilion zd8000 laptop.
Go to Start->Control Panel->System->Hardware->Device Manager-> select you drive here and delete by pressing del key. Then scan for new hardware. It will show you this drive or any other new drive. Install its drivers and off you go.
Oct 09, 2009 | HP Pavilion zd8000 Notebook
HI I CAN'T OPEN THE DISK DRIVE OF MY HP PAVILION ZD8000. .HOW CAN I DO THIS? THERE ISNT A DISK INSIDE.
Take a pin, and gently insert it into the crevice of the optical drive. You should be able to open the optical drive now.
Here is a how-to in depth.
Dec 28, 2008 | HP Pavilion zd8000 Notebook
Hoow to install a dv2000 hp pavilion dvd rw drive (internal)
Remove the Phillips PM2.5x7.0 screw (1) that secures the optical drive to the computer
Insert a thin tool, such as a paper clip, into the media tray release hole (2). (The optical drive media tray release from the optical drive)
Use the media tray frame to slide the optical drive (3) to the left.
Remove the optical drive.
ce642a5.jpg You can download the complete manual here:
http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
Jul 22, 2008 | Compaq Pavilion ZT3280US Notebook
Pavilion HP Pavilion DV4-1225dx AC Adapter - 90 Watt (Replacement) Logo
57 people viewed this question
Top Pavilion Computers & Internet Experts
Donna Sander
Josh Whitehead
Josh Whitehead
Are you a Pavilion Computer and Internet Expert? Answer questions, earn points and help others
