Question about Garden
Ryobi plt3043a fuel line - Garden
4 Suggested Answers
moretons
  • 155 Answers
SOURCE: starter cord on Ryobi PLT3043A broke - is it simple to replace?
unless you are mechanically minded you can run into trouble it is best to get a quote from your local dealer
Posted on Jul 25, 2009
rwvanlue
  • 486 Answers
SOURCE: I bought a second hand RYOBI PLT3043a line trimmer
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 25, 2009
Ryobi line trimmer plt3043a starts idles but dies when i attempt to increase speed
May I suggest checking along the fuel line and its attachments for a very minor air leak. The minute it sucks air it will stop. Check any rubber washers or O rings too.
Feb 02, 2015 | Ryobi Garden
I wish to replace the trimmer head on my Ryobi PLT3043A Whipper Snipper. Its just worn from to much love ???? I know how to replace the cord but wish to replace the cord haed assembly. I brought the...
Hold the shaft to prevent it from turning, then turn the trimmer head clockwise (viewed from the bottom) The cutter adapter has left hand threads. Hope this helps you out, as this is from the service manual. Best regards and good luck.
Dec 30, 2010 | Ryobi Garden
I have a Ryobi Leaf Blower (Model 310 BVr) which
Look for a cracked fuel line, or a loose fuel line around the fuel tank. I'm going to lean towards the cracked fuel line.
Feb 01, 2010 | Ryobi Garden
I bought a second hand RYOBI PLT3043a line trimmer and am failing to start it.
Basics to check:
b) is there spark
1) spark plug
Chain Saws:
Remove Carburetor
Nov 25, 2009 | Ryobi Garden
Starter cord on Ryobi PLT3043A broke - is it simple to replace?
Jul 03, 2009 | Ryobi 15" Electric Factory Reconditioned...
Need routing of fuel lines on Ryobi string trimmer Model 725R.
The larger fuel line goes from fuel filter to carbuerator.The smaller line is the return line from the purge bulb tofuel tank. mitchjl_1692
May 27, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
