Question about Pool & Spa
Hi limit switch
I have a leisurerite hot tub with no heat
Leisurerite spa
ok, what exactly is your question?
Sep 04, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Jacuzzi hot tub will not reach temp pumps do run?
If your hot tub is running but NOT heating then you need to look at a couple of things.
First, on the topside, is the heat indicator light on?
If it is on and the tub is not heating then the temp sensor or the high limit sensor is not working and need to be replaced.
US Parts Center
Oct 22, 2013 | Jacuzzi Home
I have a Leisurerite GL2000 and it wont heat. No error messages coming up so don't know why. Are you able to help please?
There are a couple of things for you to check.
Look for the heat indicator light on the topside panel. Is it on?
If it is on you may need a new temp sensor or hight limit sensor.
If it is NOT on the the pressure switch may be out.
Not sure why you are not getting an error code on the topside panel.
Rod
US Parts Center
Feb 03, 2013 | Pool & Spa
Spa thermal overheating
Turn off all power to the hot tub as soon as you realize it is overheating. The spa should have an automatic shut off when the water temperature reaches about 112 degrees fahrenheit. Call your hot tub dealer or manufacturer for service options. There are a variety of conditions that could lead to the overheating of your hot tub, but may differ in various hot tub models and brands. Check the water level of the hot tub. Low water levels could be the culprit for the over heating, so you may just need to add more water to the hot tub.
Check the shut-off valves in the hot tub. If they are closed while the hot tub heater is on, it could cause the water to reach unsafe temperatures.
Clean the hot tub filter. A dirty filter could be blocking the flow of water, causing the water to sit in the hot tub and overheat.
Turn the power back on after finding the problem and talking to the hot tub dealer. The hot tub will probably not start back up until the water reaches a safe temperature
Jan 06, 2012 | Endless Summer Pool & Spa
Hydro-Quip pack in my Hydro-Spa hot tub no heat.
3 Flashing dots (display) - Water flow problem check for closed valves, dirty filters, water level, pump/wet end operation/defective pressure switch.
If your spa has been off for a while its likely something is blocking the lines.
Flashing dots & Lit light on display - Hi-limit trip, reset power to clear.
Nov 16, 2011 | Hydro Quip Inc Pool & Spa
Our hot tub says that there is a sensor problem detected what do we do it will not heat up or anything
either have the temperature/high limit sensors tested or replaced. Also, try resetting the tub by cutting power to it for 5 minutes if you haven't already done so.
Nov 23, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Savannah spas
probably a dirty filter!! take it out turn tub off to reset turn back on with filter out and c if nthis solves problem if so replace filter.
Nov 20, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Just filledd up an old dakota hot tub model126-dkn-4248-2 and ita been running for about 4 hous and wont heat up i would also like an owners manual for one but dont know were to look
it may take longer to heat to desire temp. if nothing chang have you adjust the temp higher . if everything check ok check high limit switch next to the control box ussualy red bottom push soft in
Sep 13, 2009 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
QCA Opal hot tub display reading OH.
The tub experienced an overheat situation. This may be due to leaving the t stat turned all the way up and not monitoring or the hi-limit sensor is defective. The hi-limit sensor will shut down the heating cicuit if temp gets above 105 D optimally.the fact that the heater light is on is a good sign that things are working at this point.Whether or not a suitable temp(100-103 D) will be arrived at is to be seen. If spa heat kicks off before set temp is reached then replace hi-limit sensor.
Apr 10, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Pool & Spa Logo
18 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
