C352 errorcode c3542 - Office Equipment & Supplies
Heated drivers seat dont work on my 1998 lincoln contenital
It could be the heating element or the Driver heated seat module ! Do you know anything about automotive electronic's ? Circuit testing with a DMM - digital multi-meter ? This system has a element in the seat an the back . None work ?
  • Heated Seat Inoperative
  • Circuitry open/shorted.
  • Damaged heated seat heater elements.
  • Damaged heated seat module.
  • Damaged heated seat switch.
  • GO to Pinpoint Test G .
PINPOINT TEST G: HEATED SEAT INOPERATIVE G1 TEST HEATER ELEMENTS
  • Disconnect connectors C352 LH ( C356 RH) at heater modules.
  • Using an ohmmeter, measure resistance of heater elements according to the following chart:
    Connectors C352 LH; 356 RH Pin Circuit Pin Circuit 12 1067 (P/LB) 9 1066 (GY/LB)
Is resistance of elements 2.5-10 ohms?
Yes No GO to G2 . GO to G4 .
The seat heater module is under the driver seat .
G2 TEST HEAT SENSORS FOR OPEN CIRCUIT
  • Using an ohmmeter, measure the resistance of sensors according to the following chart:
    Connectors C352 LH; 356 RH Pin Circuit Pin Circuit 11 1063 (O/LB) 10 1062 (R/LB) 6 1061 (BR/LB)
Is resistance more than 10,000 ohms?
Yes No REPLACE trim covers. RESTORE vehicle. RETEST system. GO to G3 . G3 TEST HEAT SENSORS FOR SHORT CIRCUIT
  • Using an ohmmeter connected to a known good ground measure resistance of Circuit 1063 (O/LB) at Pin C352 LH; Pin C356 RH.
  • Measure resistance of Circuit 1061 (BR/LB) at Pin C352 and Pin C356 .
Is resistance 0 ohms?
Yes No REPLACE trim covers. RESTORE vehicle. RETEST system. GO to G6 .
G4 TEST CIRCUITS BETWEEN HEATER MODULE AND HEATING ELEMENT CONNECTOR
  • Disconnect connectors C353 and C351 LH.
  • Disconnect connectors C355 and C354 RH.
  • Using an ohmmeter, measure resistance of circuits between module connector and heater element connector according to the following chart:
    Connectors C352 LH; 356 RH Pin Circuit Pin Circuit 12 1067 (P/LB) 11 1063 (O/LB) 6 1061 (BR/LB) 10 1062 (R/LB) 9 1066 (GY/LB)
Is resistance less than 5 ohms?
Yes No GO to G5 . SERVICE suspect circuit for open. RESTORE vehicle. RETEST system.
G5 TEST HEAT ELEMENT AND SENSOR CIRCUITS FOR SHORT TO GROUND
  • Refer to Circuit charts in G4.
  • Using an ohmmeter connected to known good ground, check resistance of circuits.
Is resistance less than 10 K ohms?
Yes No SERVICE suspect circuit for short to ground. RESTORE vehicle. RETEST system. Circuits satisfactory. REPLACE trim cover. G6 TEST HEATED SEAT SWITCH POSITION 1
  • Disconnect connector C352 LH ( C356 RH).
  • Make sure switch is in position 1.
  • Using an ohmmeter measure resistance between Pin C352 , Circuit 1018 (LG/O) and Pin C352 , Circuit 1019 (T/LB).
  • Measure resistance between Pin C356 , Circuit 579 (BK/O) and Pin C356 , Circuit 580 (BR).
Is resistance between 2.0 K and 2.75 K ohms?
Yes No GO to G7 . GO to G14 .
Jan 07, 2018 | Lincoln Cars & Trucks
How to fix konica c352 elevator
you mean finisher? output trays what is wrong with it?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 14, 2014 | Konica Minolta Bizhub C352 Digital Copier
"Konica Minolta C352 - cyan and white pattern background on every print?!
What are you printing a Word document when this happens ?
suspect pattern may be in the software you are printing from.
Go to software help screen and look search for removing background pattern or removing watermark.
Apr 11, 2014 | Konica Minolta Bizhub C352 Digital Copier
I would like to teach me to scan the Bizhub C352, ie what are the steps to take to scan a document in BIZHUB C352. thank you Manuel Medina papelariapatrick@hotmail.com
Mack a scan folder on your computer & share it to network the you go on c352 and press scan key - direct input / scan to SMB / reference / work group open / your pc name open / scan folder ok -you are ready to scan any document any help you con- me 919899653281
Mar 19, 2013 | Konica Minolta Bizhub C352 Digital Copier
How to find server name for bizhub c352
The fiery network info can be found by pressing the small "i" in the bottom corner of your screen and selecting the config option. You can also access fiery settings by pressing "utility/counter" followed by "controller detail".
Mar 05, 2012 | Konica Minolta Office Equipment & Supplies
Plz guide this machine gives me an error mal function what is mal function
What is the malfuction code showing on the display? This code will be a letter followed by 4 numbers. Such as C3542. Reply back with the code so we can assist you further.
Feb 08, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
k24674
jasbo
jasbo
