Question about Sharp Comfort Touch AF-R120EX Air Conditioner
Is there a hepa filter or allergen filter available for this model? Sharp Comfort Touch AF-R120EX
5 Suggested Answers
KOakaKO
  • 135 Answers
SOURCE: Air condition problem
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The manual says to clean filter and unplug unit, then plug unit back in and code will be reset.
Posted on Aug 02, 2007
  • 3 Answers
SOURCE: I have a Sharp Comfort Touch AC displaying E-1. ??
This is a reminder to clean the air filter. It happens every 720 hours of operation. Here are the steps to get it back up and running:
1. Power down the air conditioner using the "power" button on the front panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above EXACTLY.
Posted on Jul 26, 2010
  • 20 Answers
SOURCE: we plugged in the sharp
if unit trips breaker from second circuit unit has dead short possible bad compressor or controlls related problem. doesn't look good..... mike 20 year HVAC service tech
Posted on Jul 03, 2011
  • 4736 Answers
SOURCE: We need a replacement filter
Karen, even though your model has been discontinued, you can still get a washable filter replacement for you AC Unit. Most hardware stores and home improvement stores sell a washable, mesh filter kit, that can be cut to size to fit your unit and hundreds of others. You'll probably have enough left over to make two filters, if necessary
I hope this helped you and thanks for choosing FixYa.
Posted on Aug 01, 2011
Sharp AF-S100FX Comfort Touch Air Conditioner not working
You may have it in a timed mode. Here are the instructions for your unit. There will be a start delay if it is in timed mode. My Retrevo My Manuals
May 15, 2014 | Sharp Comfort Touch AF-R120EX Air...
My air conditioner is freezing up
Hello, the unit will frost from either low airflow ( dirty coil or filter) or a low refrigerant charge due to a leak.
Jul 04, 2012 | Sharp Comfort Touch AF-R120EX Air...
My sharp comfort touch air conditioning 12,000 BTU FS-S125FX-A does not cool any more. It's running but at room temp.
Can work the external drive and you see that turns the fan but look at the compressor he works; logically not working if the fan brings the temperature domatiou.antikatestise external capacitor again if the air conditioner does not work then the compressor is stuck.
Aug 07, 2011 | Sharp Comfort Touch AF-R120EX Air...
Turning off code e1 flashing what is e1 code
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Jul 28, 2011 | Sharp Comfort Touch AF-R120EX Air...
I have a Sharp Comfot Touch AC - AF-121208W that I inherited from my brother years ago. I do not see a "drain" but can see water inside the unit. How would I get the water out? I do not see...
The unit will have a small amoount of water in it just make certain that it is tilted tot he ouside to help it drain. check the filter and clean it while your at it . let me know
Jul 23, 2011 | Sharp Comfort Touch AF-R120EX Air...
I have a Sharp model number AF-S125FX that shuts off and I get the E1 message . I have cleaned the filter and tried the E 1 solution that was listed for a differant model number and have had no...
please check the relay of the comppressor and also the capacitor of the compressor. Check also if there is any issues in the controller section that can bring in the errors.
open and tigten all connectors, take a test on relays to manually switch on fan and compressor to confirm their worrking. the check for the micro controller's functiioning.
Sep 02, 2010 | Sharp Comfort Touch AF-R120EX Air...
We have had our 12000 BTU sharp ac for about 10 years now. The unit seems to be working but is not cooling the room that well. How do I know if its the compressor or it just needs coolant? If it isn't...
Remove the unit and clean the evaporator coils and the condenser coils with a good coil cleaner chemical.
Oil the fan motor bearings.
Replace the capacitor.
Jun 27, 2010 | Sharp Comfort Touch AF-R120EX Air...
No power to my wall sleeve air conditioning unit. Outlet has power.
its very common with all the vibration within the wall unit for wires to come loose try tighting all wires if this does not work call a tech it should simply be a loose cable ..very common
Jun 24, 2010 | Sharp Comfort Touch AF-R120EX Air...
Filter is stuck inside
I have had to break the plastic around the filter to get it out before, <not telling you to do that> , but you may have to force it...be careful so you dont brak the faceplate>>>good luck
Jul 12, 2009 | Sharp Comfort Touch AF-R120EX Air...
Sharp Comfort Touch AF-R120EX Air Conditioner Logo
26 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
