Question about Video Game Consoles & Games
Moore o matic garage door opener model 800.The door goes down 2 panels the reverses to up.
I have already lubed the track and rollers with teflon spray. Tried to adjust the travel with the set screws in the back of the unit. I've had this problem before. I just didn't use it for a couple of days and I guess it reset itself.
2 Suggested Answers
Diamond E
  • 57 Answers
SOURCE: programming garage door opener
http://www.aaaremotes.com/linearx.html http://www.chamberlain-diy.com/pdfdocs/114A2504.pdf 1rst is to purchase the second is a manual index.
Posted on Sep 13, 2007
Why is Moore O Matic 700-S Garage Door Opener Not Working After Lubricating Chain?
Sounds like you got oil on an electrical part. Inspect all & clean oil from parts that don't need it.
Apr 02, 2018 | Cars & Trucks
Where is the program button located on moore matic x150.
If you mean the Moore-o-matic X150 garage door opener, it doesn't have a program button. It has three adjustment screws: Up limit and Down limit are on the downward side of the opener, the Door Pressure adjustment is on the back of the opener (lower left relative to the door operator terminals).
The manual for the Moore-o-matic X150 is available online from Manuals Lib, https://www.manualslib.com/manual/977303/Moore-O-Matic-X125.html#product-X150 , and liftmaster.com, https://www.liftmaster.com/catalogresourcesv3/en-us/shared/files/tucmanuals/a8448mm.pdf .
I hope this helps.
Dec 03, 2017 | Cars & Trucks
Liftmaster GDO goes up 1/2 way and stops,springs are fine.
The Liftmaster openers have 4 movement switches, a )opening and b) closing limit and c) opening and d) closing force. First check the door for smooth operation by opening the door by hand (disconnect from the opener with the release cord). Any binding should be felt this way. It is possible for a binding hinge, roller or torsion springs to add too much drag and cause the force switch to shut off the motor. Hinges, roller shafts and torsion springs should be lubricated at least annually with a non oily spray (silicone or teflon spray). Not WD-40 or 3-in-1! A light band of lube should be applied to the torsion spring coils. If the door can be operated smoothly by hand, then adjust the closing force switch 1/4 turn at a time. This is a safety device do not use it to overcome another problem!
Aug 15, 2014 | liftmaster Garage Door 1/2 Hp
My garage door will not open, the door gets close to the ground, then back up again. one sensor is green and other one yellow color. Please help me. My email- frooty2cute@yahoo.com
LUBE THE SPRINGS AND ROLLERS WITH WD40.
WATCH THE SENSOR LIGHTS TO SEE IF THEY GO OFF JUST BEFORE THE DOOR CLOSES. IF THIS IS THE PROBLEM EITHER ADJUST THE TRACK OR MOUNT THE SENSORS TO THE WALL INSTEAD.
IF THE SENSORS STAY LIT AND THE DOOR STILL REVERSES AFTER LUBE. ADJUST THE DOWN SENSITIVITY ABOUT 1/8 TURN AT A TIME (LESS SENSITIVE) ID YOU HAVE TO ADJUST THE SENSITIVITY MORE THAN 3/4 YOU WILL NEED TO CALL A PRO OUT TO CHECK THE PROBLEM.
HOPE THIS HELPS
Oct 19, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Garage door: on calm day panels are weather tight
Garage door work like a wedge. As it goes down the door get closer to the jam. So if you moove the weather stips closer to the door that probebly solve your problem. Do that whith the door complitely close.
Good day Paul
Feb 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door opener has problem opening door
Neither the chain nor the track require lubricant. The roller bearings, the hinges and the rail need lubricated from time to time.
On the rear of the motor unit you will find a control "up force." Increase this about a quarter turn.
Jun 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener does not reverse after hitting obstruction
release the door from the opener and see if door moves freely the check proper torsion by moving door up to 3-4 ft if it stays in this area torsion is properly set if not call technician to adjust torsion
if door does not move freely all the way up and down check for binding track alighnment and roller condition. the adjust closing pressure.
Jan 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
1/2 hp craftsman garage door opener won't open when cold
I called Sears garage door customer service number due to the same issue. The test is to disengage the opener drive by pulling the emergency disengage handle, then open the door half way manually and then let it go. If it stays there it is a door/track/lub problem; if it drops down and closes its a garage door opener problem. Mine stayed open half way during this test so it was a door/track/lub problem. After using silicone spray on all tracks, rollers, and springs mine has been working great. Good luck.........
Dec 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Jul 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
Video Game Consoles & Games Logo
41 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
