Question about Husqvarna Viking 1
H CLASS 200S, new, just out of box, Hand wheel will not turn.
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
My bobbin thread bunched up and the hand wheel won't turn
hate that when it happens start at the bobbin and start cutting thread all the while trying the hand wheel forward and back . it will all come out eventually
Mar 27, 2015 | New Home L-373 Mechanical Sewing Machine
How do I add thread to the bobbin
The small box you will turn towards you while you hold the big handwheel. It might me very tight but it isn't going to break by turning hard. Tighten the small screw before you begin. When it is loose you can wind your bobbin.
Feb 23, 2015 | Sewing Machines
Hand wheel is hard to turn
even though the machine is fairly new, it sounds like it needs to be serviced, to see if there are any broken or damaged parts.
Jan 24, 2014 | Singer Sewing Machines
I have a husqvarna H Class E10 sewing machine. The hand wheel has tighten up on me. I can not loosen it.
I suspect the main bearings and other rotating parts need to be cleaned of old lubricant and regreased. This obviously requires dsassembly of the maching. Unless you're a mechanic, leave it to the repair person.
Feb 21, 2013 | Husqvarna Sewing Machines
Brother SE400 Hand wheel is very tight and the needle will not go down
if the machine is brand new then it needs to go back & get another one
Mar 27, 2012 | Brother SE400 Computerized Sewing Machine
Motor is fine, but won't sew
since the machine has been setting for 20 years, it needs to be serviced
the old grease & oil have probably turned the gunk. the servicing can also tell if any parts are damaged
Mar 18, 2012 | White Sewing Sewing Machines
Kenmore 10 stitch needle won't move
hi there,
push or pull hand wheel clutch to engage
motion of needle and shutter.
if not check belt on downside of hand
wheel open cover motor,loosen bolt cover
see belt check if engage on pulley by
holding hand wheel move belt if
hand wheel move,if not tighten screw on
pulley from hand wheel and moter.
have a nice day and thanks
Apr 03, 2009 | Sewing Machines
Sewing Machines Logo
20 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
