Instructions for rotating antenna model #36774
We just installed an ematic edt312 outdoor rotating antenna. We cannot make it rotate, or get any reception at all. We have the antenna mounted 5 feet above our rooftop. Can you help us? .
Rotating antennas are not cheap and they have multiple connections on them for the motor and the drive box as well as the signal connection. This particular antenna was subject to being cloned and faked and you may have gotten one of those.
Jul 16, 2017 | Televison & Video
Instructions for lan-2850 antenna
Hello Arthur Duff,
Walmart responds... Manufacturer "LESHP"
Purchase specs.
LAN 2850 Universal 150 Mile Control 360 Degree Rotation Outdoor HD TV...
shipped by... HONGRU
Hongrui Electronic Commerce(Hong Kong) Co., Ltd
Only contact number seems to be WALMART...
I would give them a call: Phone: (877) 215-5831
Jun 10, 2017 | Computers & Internet
Why will my digital antenna not rotate using either the remote or manual button?
If the motor has not been turned for a long time the grease on the gears may dry out and freeze the motor.
Mar 19, 2015 | Lava HD-2605 Ultra with G3 Control Box...
Why is it only abc tv have a weak quality signal & reception
sounds like an antenna problem. rotate it with someone who can tell you how TV is affected by rotation. Some people buy an antenna motor for reception.
Feb 16, 2015 | Televison & Video
My 9537 lights up and goes thru the numbers 0-360 but the antenna does not movmove
Has this installation previously worked or is this a new installation?
Sounds like it may be in the rotator itself.
Dec 28, 2014 | Channel Master CM 9537 Antenna Rotator...
My antenna won't rotate and I now receive only local channels
There could be a problem with the wires going from the control box to the rotator, or the remote itself
Good luck,
Marty
Apr 22, 2014 | Digiwave ANT-3045 Remote Control Outdoor...
Rca vh126r troubleshooting
Replace remote batteries.
check wire connections to motor.
There may be a fuse that has blown on the control box?
Growing up our antenna rotator gears stripped themselves and the antenna just spun freely. For many years we just tied a light rope to one end of the antenna and basically went outside and turned it from the ground by pulling the rope and tying the other end to a garden steak. We didn't have much money till after us kids grew up and moved out, my dad got satellite TV. Good luck!
Apr 14, 2014 | RCA VH126N Programmable Antenna Rotator...
I HAVE A RCA 42" LED TV. I RECEIVE MY SIGNAL FROM AN ANTENNA. I CAN ROTATE MY ANTENNA, SCAN THE TV FOR CHANNELS, AND THIS WORKS FINE. THE PROBLEM IS IF I HAVE TO ROTATE THE ANTENNA FOR OTHER CHANNELS,...
on B:Press the MENU button on the remote.Select Setup.Select Auto Program.Choose Air or Cable.Select Auto Program to let the TV reprogram the channels.Check that the channel is programmed into memory. There are a couple of ways to do this: Use the TV menu system. Accessing this setting varies depending on the model TV that you own. Here are two options that are common on many TV's: Option A:Press the MENU button on the remote.Use the VOL and CH buttons to move through the menu and add any missing channels try this if not r
Do a full reset if this dosnt work
Dec 25, 2013 | RCA L42WD22 42 in. LCD Television
GE Model 20GT360 TV and digital antenna problem
Are you connected to a digtal converter or just a digital antenna? If only to an antenna then yes you will most likely pick up one or two low power UHF stations that are still able to broadcast in analog.
Nov 17, 2009 | Televison & Video
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
