Question about LG Electronics BT20N 8x slim dvd-rw/bd internal
Where can I find firmware and/or driver supporting Windows 8
LG BT20N will intermittently stop running, "disappear" from List of devices and Unit Handler. Have searched for downloads on LG homepage, but nothing there. Usually it "returns" after 1 or more re-boots of Windows 8.1 Pro Preview. Have checked Win logs, says: Driver outranked ??? Have taken pictures of above, available thru my DropBox.com account. Can share folder with you if you e-mail me your e-mail address. Brgds Lars W
carpenocte
  • 104 Answers
SOURCE: LG CD-ROM CRD-8521B driver
go http://www.cdrom-drivers.com/drivers/77/77204.htm (thats driverguide: name temp; pass 512)
but that CD reader does not need drivers if you use windows98 Me 2000 XP 2003 or Vista... if its not working and your computer is ok you surely have connected something the wrong way.
Posted on Mar 15, 2008
  • 9 Answers
SOURCE: MTP Device Searching Preconfigured Driver Folders
I was having this problem as well, but solved it.
I, like others decided to just buy a USB cable for my VX9900 and use Windows Media Player for sync'ing. (I also have the Verizon Essentials program that I downloaded, but I like WMP better. No particular reason).
I was getting the installation messages and as soon as the MTP message came up, I got the "problem" message and it didn't sync.
What I did when I got the cable was to run the CD drivers that came with my cable. That may have been my mistake. I was bothered that the date of my driver was in 2005 since the phone came out late in 2006. So I looked at the name of the driver and it was something like C:\Windows\System32\Drivers\LGUSBDriver.xxx whatever... I went to my device manager and uninstalled the driver. I went to the C:\Program Files\ and deleted the LG USBDrivers folder. I went to the Windows/system32/drivers folder and there were three LG*.* files I deleted them. The next time I plugged the phone in and set it to sync, it worked. It's late and night and I may not have typed this really clearly, so feel free to contact me at bill (at) halfamind.com (because a half a mind is still a terrible thing to waste).
Bill Isles
Posted on May 04, 2008
  • 207 Answers
SOURCE: Missing DVD driver
1.Turn on the PC. When the HP/Compaq logo screen appears, press the F1 key repeatedly until the BIOS Setup screen appears (on some models this key press may different, F2 or Del)
2.Use the Left and Right Arrow keys to select Main.
3.The hardware-identifying name should appear next to Secondary Master, Secondary Slave, or Primary Slave.
If the name for the drive exists, skip to Step 3. Otherwise, continue to the next step.
Step 2: Reseating cables
If a drive name does not appear for each drive and None is listed in the BIOS, use these steps to open the computer case and reseat the drive cables. Work on a hard flat surface over a non-carpeted floor.
1.Turn off the computer, unplug all cords from the PC, and then press the Power button on the front of the PC for five seconds.
2.Remove the side panel.
3.Remove both the IDE ribbon cable and the power cable from the back of the CD drive.
•If the drive name appears in the Primary IDE section or the hard drive name is now missing, the IDE cable is bad or the drive settings are wrong. Replace the IDE cable and connect it according to the drive jumper settings . That is, if the small rectangular connector (the jumper) on the drive is set to MS (Master), connect the master end of the IDE cable into the back of the drive. If the jumper is set to SL (Slave), use the slave connector on the cable. If the drive is set to CS (Cable Select), you can connect using either connector on the cable.
Step 3: Removing Drive in Device Manager
Remove the drive name from Device Manager:
4.Close the Properties window and select the CD drive name.
5.Click the Uninstall or Remove button (in Windows XP this is the square button with a red X).
6.Click Yes or OK to remove the CD listing. Do not restart the PC.
7.Close Device Manager.
8.If your PC has Windows XP, perform the next step to clear the registry filters without restarting the PC.
Clearing the registry filters in XP
Click Start, Run, and type the following into the Open field: regedit
Click OK. The registry editor appears.
In Windows XP, click File, Export, type a filename that is easy for you to remember, and click Save.
In Windows 2000, click Registry, Export Registry File, type a filename that's easy for you to remember, and click Save.
A copy of the registry has saved for back-up purposes.
Click the plus sign (+) next to the following items in the list:
•HKEY_LOCAL_MACHINE
•SYSTEM
•CurrentControlSet (or the current control set with lowest number if that is all that is listed)
•Control
•Class
Select 4D36E965-E325-11CE-BFC1-08002BE10318.
Select UpperFilter in the right window and press the Delete key.
Confirm the deletion by clicking Yes.
Select LowerFilters in the right window and press the Delete key.
Delete all other UpperFilter and LowerFilter values within the 4D36E965-E325-11CE-BFC1-08002BE10318 key.
Posted on May 18, 2008
SOURCE: Download Lg kg 300 mobile driver to run internet through mobile
hello friends you can find all the driver mobile company
on
http;//nodevice.com
to find lg kg300 driver go to the link
http://nodevice.com/driver/KG300/get41587.html
after downloading it just run it to your computer
and connect ur mobile with pc
if some problem is there than u can contact me on my email address
rajkumar2486@gmail.com
Posted on Sep 09, 2008
  • 8 Answers
SOURCE: How to download video to the LG enV VX9900 using my PC ?
Well Sir,
You Cannot Active Sync Videos And Pictures To The Lg enV (vx9900), To The Best Of My Knowledge. The Reason Is That The Folder That Active Sync Puts The Files In Is The Wrong File, What You Are Gonna Need To Do Is Get A Micro SD Card And Download A Free Video Editing Program Called "Super," Just Google It And You Should Find Something, The Next Part Is To Install And Open The Super Program At This Forum (http://cellphoneforums.net/lg-env/t250088-convert-put-videos-your-env-lg-vx9900.html) You Should Find Some Good Settings For Video's, Its What I Use, After The Setting Are All Finalized Click The Encode Button, After The Video Is Encoded The File Should Be Saved In C:/program files/eRightsoft/Super/Output/(File name). I Recommend Having A sd Card Writer, Thats The Only Way I Know To Do It, Then Copy The File In The Output Folder And Paste It To The Folder Named my_flix In Whatever Drive The SD Card Is. You Should Have A Video With Some Pretty Good Picture Qualities, Hope I Helped XD
Tim2o9
Posted on Jan 04, 2009
I WANT TO INSTALL WINDOWS 8 ON MY IBM R60 BUT THERE IS A RISK OF LOOSING DRIVERS . I DONT HAVE DRIVERS CD SO PLEASE TELL ME HOW AND FROM WHRE I CAN DOWNLOAD THE DRIVERS FOR MY IBM
Use the Windows 7 Upgrade Advisor
Before scanning your PC with the Windows 7 Upgrade Advisor, be sure to plug in and turn on any USB devices or other devices, such as printers, external hard disks, and scanners, that you regularly use with the PC you're checking.
Download the Windows 7 Upgrade Advisor
Sep 18, 2012 | IBM ThinkPad R60 Notebook
Tip
How do I remove Bluetooth Drivers?
<p>When a new Bluetooth device with your computer, you generally need a driver for the work to install. Once you stop using a Bluetooth device, you may need to uninstall it before it is used by other Bluetooth devices that you still use. Bluetooth drivers and other drivers are removed from the Device Manager that is built into all versions of Windows. <br /> <p><br /> <p>1. Click Start&gt; Run. When the Run text box, type "devmgmt.msc" and click "OK" to open the Device Manager. <br /> <p><br /> <p>2. Scroll through the menu of categories device in Device Manager and find "Bluetooth devices." Expand this category by clicking the "+" sign next to it. <br /> <p><br /> <p>3. Scroll through the list of devices in this category and identify those that you do not plan more. Right-click and choose the first "Uninstall" option in the pop-up. When Windows asks you to confirm the deletion, click "Yes". <br /> <p><br /> <p>4. Repeat step 3 for all other devices with Bluetooth driver you want to delete. When finished, close the Device Manager. <br />
on Jun 26, 2011 | Computers & Internet
Tip
How do I restart a Bluetooth Stack?
<p>Bluetooth is a wireless technology used primarily to connect a serial cable to be replaced by automatically connecting two associated equipment which are close to each other. Microsoft Windows 7 operating system includes support for Bluetooth devices using drivers typically supplied by the Bluetooth device. When a Bluetooth device that is configured to associate a computer with Windows 7 is disconnected from the computer, restart the Bluetooth stack to solve the problem quickly in many cases. <br /> <p><br /> <p>1. Click the "Start", click "Control Panel" and double-click Administrative Tools. <br /> <p><br /> <p>2. Double-click "Services" item in the list. The "Services" window will appear. <br /> <p><br /> <p>3. Click here to see the "Bluetooth Support Service" to highlight it and click the "Restart" on the left side list of services. <br />
My Lg driver for gh22ns50 dvd writer for windows 7 is not detected
Hello subaikri,
I've given you a "Link to the Website, where you can,
"Download the Drivers that you need."
First, make sure that the you choose the Windows 7,
**{New Firmware for "TN02"}!
Scroll-down the (page), until you see the "Drivers and Software."
There will be a {List}, to choose from!
This way, you'll be able to get the right "Drivers / Firmware."
Next, download the [File].
Find the {File, and "Install the Driver / Firmware"}.
"Restart the computer, so that the configuration can make the 'correct' changes.
If you need help with anything else?
"Write a 'comment'; I'll be here to assist you!"
"Best Regards"
Click here for "Drivers" http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=GH22NS50&initialTab=documents&targetPage=support-product-profile
Aug 15, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Hi, I have trouble to see some bluray disc on my BD 530 blue ray player, could you tell me where can I find the firmware or update to try to fix this problem, thanks
There is a firmware update available here: http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=BD530&initialTab=drivers&targetPage=support-product-profile (the second one in the list). Make sure to click the drivers and software tab. Be sure to check the manual (available at the manuals and documents tab) for details.
The firmware comes as a zip file designed to be used with Windows.
I hope this helps.
Jan 31, 2011 | LG BD530 Blu-Ray Player
Tip
How to Repair a Driver Problem in a Laptop
<span>Instructions</span> <ol> Windows Vista <li> Open "Start" and click "All Programs." Select "Windows Update." Type in your account password if the operating system prompts you for it.<br /> </li> <li> Click the "Check For Updates" link. Select "View Available Updates" and check to see if any drivers are listed for your laptop. Click the specific driver you want to update.<br /> </li> <li> Click "Install." Restart the laptop after the installation finishes and see if the driver problem is resolved. Return to the "Start" menu and click "Control Panel" if the problem persists.<br /> </li> <li> Select "System and Maintenance." Click the "Update Device Driver" link underneath the "Device Manager" heading.<br /> </li> <li> Find the specific device that isn't working properly in the list of available devices. Right-click the device and choose "Update Device Driver."<br /> </li> Windows XP <li> Right-click the "My Computer" icon on the desktop. Click "Manage," then select "Device Manager."<br /> </li> <li> Scroll through the list of hardware devices being used by your laptop. Find the specific device that is having a driver problem.<br /> </li> <li> Right-click the name of the device and choose "Properties." Navigate to the "Driver" tab.<br /> </li> <li> Click "Update Driver." Select "OK" to repair the driver problem.<br /></li></ol><span><br /><br /><a href="http://www.ehow.com/how_5793827_repair-driver-problem-laptop.html#ixzz1A58qJjG3"></a></span>
on Jan 04, 2011 | Computers & Internet
Firmware won't update; Player won't turn on or show up on PC
well done XP! device repaired :)
I'm so happy I didn't sell my travel notebook,
good enough for running XP slowly... very slowly.
I will left more space now than last time. Why I didn't
thought that some kilobytes aren't enough for operating.
May 07, 2009 | Philips GoGear SA5285/37 Digital Media...
Many problems in using the FM37 media player. I wish I had bought the next Philips up from the 2GB model I have. At least they 100% know how to develop decent software, even a child could use. Using any...
I did solve the problems with the LG FM37 media player. After the download of the LG FM37 firmware to the latest version 2.20EN, the device kept mentioning "download & press record". As nearly every function is controlled by touching the screen, I pressed where it said "record" in the message. Of course to no avail. Then I though perhaps it is suggesting the voice record button on the side of the device, and when pressed the device did it's thing and transformed to version 2.20. When I turned the device on, all the files had become question marks, and nothing functioned. In fact I could not turn it off. So, **** the reset/microphone hole with a needle, I decided the best thing to do was to format the thing from the settings selections. Prior to the re-format, the device kept mentioning "error code 9001". That disappeared once the device was re-formatted. And that did the trick, once the re-format was done, there were no files, for sure, - but the first video a Donald Duck cartoon from Youtube was successfully downloaded. Previously I had been using a free on line video converter to convert the Youtube FLV to AVI - which is what the FM37 converter changes files to, then I would run that through the FM37 LG converter to size for the device. But it seems happier to have the FLV converted to WMV. I use the free "Any Video Converter", then to run that through the LG media converter, which it transforms to AVI. Since the re-format of the device and the conversion thing, the videos have all neen synchronised normally. I haven't solved the "Library" issue on the LG Media Converter, which still thinks there are a lot of files in the Library, which are no longer on the device. There is no delete facility, - crazy. But Windows media does allow you remove files from the device, but if set to automatic synchro, Media Player annoyingly reinstalles them in the device. Change Windows Media player to manual operation, to stop that. I don't know what changes firmware version 2.20EN made, but one useful thing is a "trash bin" icon at the top of file contents (videos in this instance). You can click on the file you wish to delete, then the trash can to delete it there and then. Useful for files you downloaded to the device without converting, for instance. However, it seems the LG Media Centre *will allow only an AVI file through (without further processing), but if not converted, the device itself will just show an error message and play the next video. The Philip's "Go Gear" Media Centre would *not allow you to download incorrect files. I like the way the LG plays all the video files one after the other, without intervention, as does the Philips (which can also repeat). That is the main reason I didn't buy Creative Zen, as one always has to return to the menu to selct the next video.
Oct 06, 2008 | LG Audio Players & Recorders
LG Electronics BT20N 8x slim dvd-rw/bd internal Logo
130 people viewed this question
Computer Repairing
Computer Repairing
