Vox 3000 digital receiver
How to get cc-cam to work in this receiver
Uniden turn off vox
Hi Jon,
The problem is easy to solve, so here goes:
vox indicates that your unit is set to work via the microphone(if you have one), and is activated when you start to speak, (hence vox=voice activated microphone), if you don't have the microphone that came with the unit, you will need to buy/borrow one and connect it to the unit, before you can turn off vox, so that the unit can work with or without the microphone(vox will no longer show), once you have done this.
I hope this helps.
Cheers,
Peter
Feb 22, 2013 | Uniden Radio Communications
Hi. the mobicam keeps turning on and off and the light is flashing?
What does the VOX switch do?
When the VOX function is active, both the LCD screen & Audio turn off and will automatically reactivate when there is
noise in the room being monitored (e.g. baby crying). This feature is useful at night so the light coming from the screen
doesn't bother you and also when running the MobiCam Ultra receiver on batteries since it will extend the life of the
batteries. Note: The VOX function will not work when batteries are low and you cannot change channels on the receiver in
the VOX mode
Jun 14, 2011 | Mobi-Cam Mobi AV Monitor
Euro vox max gone off
Unfortuntely the code above does not work as it was changed again. Anyone got a new code for NTL in Luton?
Feb 09, 2010 | Televison & Video
My mobi cam is in VOX mode.....How do I get it out of VOX mode?
There is a switch on the side of the camera - just move it off of VOX
Oct 31, 2009 | Mobi-Cam Mobi AV Monitor
My Mobi-cam keeps turning off by itself. What is
This is from the Mobi Camera Manual
Q. What does the VOX switch do?
the VOX mode
Sep 17, 2009 | Mobi-Cam Mobi AV Monitor
Need to update NTL Dublin Euro-Vox Max V Codes
you nedd a(9pin female to female 9pin null modem cable) you get them for fiver i can send you one or you can try get one up to you
then you go to
www.chatterbox.cc.com
download the toolbar
go to..files&fixes
then.areacodes
then..ID frequencey
then.drop down the keymaster.(this is in shape of a real doorkey)
then....go to zipped for the neares date available
then....zip it download the zip
then..open the zip and all the codes come flashing on your screen
thats it its very easy
if you want me send you a 9pin cable let me no ur details
do you have paypal?
i got 3 wrong 9pin cables at start the 4th one was the correct one
there 4.99+1.50p+p
thats the price i dont put extra on im genuine gal and like helping others
charlygalxx@hotmail.co.uk
thats ma addy mate
Gill
Dec 21, 2008 | StarTech.com StarView SV211K 2-port KVM...
NTL code for dublin1
i put the code for dublin up on the site mate and it has been tested and 100% works
Nov 08, 2008 | Televison & Video
GuitAR AMP AND EXERCISE BIKE
there are many versions of the AC30.... here is one of them Good luck
http://www.blueguitar.org/new/schem/vox/ac30volt.jpg
Jan 11, 2008 | Audio Players & Recorders
Headset problem with Uniden 1558
Determine if this is a VOX problem or a headset problem.
Turn off the VOX. Does the headset work for normal transmit and receive?
Remove the headsets. Do the radios work normally on speaker?
Plug one headset in And test with the (other) radio in speaker mode. Does it work? Now turn on VOX in this mode (yes it will work this way). Does vox work (put you mouth right on the mic)
If so swap headsets and try the other.
If one Hset works but not the other its the headset. If neither works its likely the radio ..but before you decide try the same headset experiment on the other radio. Find out which of the 4 devices the problem follows.
Happy New year
Dec 24, 2007 | Uniden GMR-1558 / 2CK 2-Way Radio
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
