Question about Adtran 1200637G4 Netvanta 814 4 Port Efm Mfr P/N 1200637G4
ADTRAN 814 Router Commands
Looking for CLI commands
2 Suggested Answers
  • 83 Answers
SOURCE: Adtran Telnet
Are you getting any failure msgs? Where are you telnetting from? Has your router been restarted? If you have web access turned on the router, you might be able to login via your browser, or you could directly connect to your router via a console cable to check your configuration.
Posted on Jun 23, 2009
Why disk operating system still exist in all windows operating system?
Every operating system has its own Command Line Interface like DOS. Even hardware and software has their own CLI or uses the one from an operating system. It enable us flexibility to debug, run scripts, troubleshoot and much more on a console type of environment. There are many commands available that we use to troubleshoot an operating system. DOS or CLI's are very useful for IT professionals and software makers.
Jul 13, 2011 | Computers & Internet
I have a 3Com Router, Model 3030. What are the router commands used in that Router. I cannot use the following Commands: 1. sho version 2. sho interface 3. sho dsl int atm 0 4. sho ip route Are the...
The commands are different than a Cisco device. Rather than try to list all the commands in this solution I'm providing you a link to the products support page on the HP website (HP bought 3Com a while back). The support site has the manuals, command reference guides, etc for your device. It should be everything you need to get started. Best of luck!
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=12883&prodSeriesId=4235691
May 05, 2011 | 3Com Computers & Internet
Setting timezones on Netvanta 3200 router
clock auto-correct-dst
clock timezone -5-Eastern-Time
clock set 23:58:00 05 May 2010
Aug 28, 2009 | Adtran NetVanta 3200 Router
How to configure the router cisco with all parameters
3. Configuring your Cisco Router If you have just turned on the router, it will be completely unconfigured. If it is already configured, you may want to view its current configuration. Even if it has not been previously configured, you should familiarize yourself with the show commands before beginning to configure the router. Enter privileged mode by issuing the command enable, then issue several show commands to see what they display. Remember, the command show ? will display all the showcommands aavailable in the current mode. Definately try out the following commands:
Router#show interfaces
Router#show ip protocols
Router#show ip route
Router#show ip arp When you enter privileged mode by using the command enable, you are in the top-level mode of privileged mode, also known in this document as "parent mode." It is in this top-level or parent mode that you can display most of the information about the router. As you now know, you do this with the show commands. Here you can learn the configuration of interfaces and whether they are up or down. You can display what IP protocols are in use, such as dynamic routing protocols. You can view the route and ARP tables, and these are just a few of the more important options.
As you configure the router, you will enter various sub-modes to set options, then return to the parent mode to display the results of your commands. You also return to the parent mode to enter other sub-modes. To return to the parent mode, you hit ctrl-z. This puts any commands you have just issued into affect, and returns you to parent mode.
Mar 31, 2009 | 3Com Computers & Internet
Forgot password of Adtran NetVanta 1224R Switch
  1. Recovering passwords requires direct physical access to a unit. This procedure cannot be performed remotely over Telnet, SSH, or the Web GUI.
  2. Connect a straight through serial cable to the console port of the unit.
  3. Configure a VT100 session (i.e. HyperTerminal or ProComm) using the following settings: 9600 bps, 8 bits, no parity, 1 stop bit and no flow control.
  4. Reboot the unit by removing the power.
  5. As the unit boots, you will be given the opportunity to break into bootstrap mode by pressing the ESC key within 5 seconds.
  6. While in the monitor mode issue the following commands:
Bootstrap# bypass passwords
Bootstrap# boot
Notice that you are issuing the boot command not the reload command following the bypass passwords command. Once the unit has finished booting up, you can issue the enable command and you will not be required to enter the privileged (i.e. enable) password. Once you are in privileged mode, you can view the configured passwords by using the show run command. A new password can also be entered by going into global configuration mode by using config terminal command and issuing the enable password <word> command where <word> is the new password. Also remember to change any Telnet, SSH or Web GUI passwords if necessary.
Below is a sample output of these steps:
Router (1200990L1)
Executing bootstrap...
ram: 268435456 bytes of RAM detected.
Serial Number: LBADTNXXXXXXXXX
Bootstrap version: 11.03.00, checksum: 0F3C, Thu Feb 09 17:40:34 2006
vfs: NONVOL: 120 tracks, 128 sectors/track, 1024 bytes/sector.
eth0/1: initializing...
eth0/1: MAC address is 00:A0:C8:XX:XX:XX
bootstrap: Checking boot configuration...
bootstrap: Primary image is 'NONVOL:/NV5305A-12-01-07b-E.biz'.
bootstrap: User escaped to command line interface.
cli: starting command line interface...
cli: starting user interface
Press '?' for help.
bootstrap#bypass passwords
bootstrap#boot
Mar 20, 2009 | Adtran NetVanta 1224R 24-Port Ethernet...
Configuring remote access
Here is a document which describes this.
Please download, it then:
1. Connect the console.
2. Configure ip address of the router
3. Enable telnet access.
Here is the document location:
http://www.adtran.com/adtranpx/Doc/0/UL9SGGEDF2I4D51F3K4IIEE2FC/61202860L1-13B.pdf
Jan 09, 2009 | Adtran NetVanta 3200 Router
How can i know the routers commands to configuare a cisco router ? Thanks
Question mark is your best friend if you don't know when what commands you can type, but learning how to configure a cisco router is not a 2 minutes thing and 1 post is far not enough to tell you all about it. A list of commands won't do too much good for you anyway because there are 3 different modes and each has it's own commands and there are lots of commands.
If you want to learn the basics I suggest you to read their most basic book "CCENT/CCNA ICND 1"
Or try out their SDM, that way you can configure the router with good old fashion pushbuttons and check out the commands what it's sending to the router.
Here's a little bit of showaround about SDM:
If this isn't going to help you out I suggest you to post another question where you are specifically telling what you'd like to do and some expert will write down the commands, but you need to be very specific with the details of the network and the requirements and the services you need, wich routing protocol you'd like to use, etc...
Nov 23, 2008 | D-Link AirPlus DI-524 Wireless Router
HOW TO MODIFY A CONFIGURED IOS COMMAND AT WORKING ROUTER
What type of router is it? Cisco, Netgear, Juniper?
It depends on who the manufacturer is of the device. Cisco you can either use a CLI to change the router rules table or you can use a GUI to make the changes. Most newer manufacturers have a built-in webpage for modifiying the commands. Although it is not the most efficient way to do it for those who are not very familiar with CLI it might be easier. To check to see if the device has a GUI, open a browser (I suggest IE, most compatible) and enter the IP address of the router into the address bar. If there is a GUI the page will open. Depending if you used a uername and password you might be prompted to enter it now.
Hope this helps you out. Cheers,
Keith
Oct 04, 2008 | Computers & Internet
ROUTER RIP CONFIGURATION
from the login:
enable
configure terminal
router rip
version 2
network xxx.xxx.xxx.xxx
Hope this works for you.
Sep 23, 2008 | Computers & Internet
FTP
In what way? FTP sessions are controlled by you and the input you place into the CLI (Command Line Interface).. Here is a page with the basics, on how to create a session and the commands to use to manipulate it:
http://www.cs.colostate.edu/helpdocs/ftp.html
DG
Dec 24, 2007 | Computers & Internet
Adtran 1200637G4 Netvanta 814 4 Port Efm Mfr P/N 1200637G4 Logo
42 people viewed this question
Top Adtran Computers & Internet Experts
Jax Planet
Jax Planet
Are you an Adtran Computer and Internet Expert? Answer questions, earn points and help others
