Compaq keyboard SDM 454 OUL - Computers & Internet
2 Suggested Answers
ghost2233
  • 3606 Answers
SOURCE: my problem is I wana driver for keyboard compaq
Hi, you can try this driver from here:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=316720&swItem=vc-45465-1&prodNameId=316722&swEnvOID=181&swLang=13&taskId=135&mode=5
The driver is for windows xp.
Just click on download.
And select the exe file when downloaded.
Posted on Sep 01, 2011
Pass. floor panel flooded, SRS module damaged. Purchased air bags, clock spring, harness and module from undamaged Impala.
You can't just replace parts like that .
DTC B1001 Option Configuration Error
When the ignition is turned ON, the inflatable restraint sensing and diagnostic module (SDM) compares the restraints ID that is stored in the SDM to the restraints ID that is stored in the body control module (BCM). The restraints ID that is being compared contains the last four digits of the SDM part number. Then, the SDM compares the VIN that is stored in the SDM to the VIN that is stored in the BCM. For more detailed information concerning the class 2 data lines, refer to Data Link Communications Description and Operation in Computer/Integrating Systems.
If the SDM is replaced you must setup the new SDM part number in the BCM. With a scan tool, select the SIR module setup. Select Setup SDM Part Number in BCM and follow the on-screen instructions. After, you must setup the new SDM. Select Setup New SDM and follow the on-screen instructions.
Oct 13, 2016 | Cars & Trucks
What does error codes: B0100 and B0140 indicate wrong on a 2011 Buick LaCrosse CXL 3.6 V6 eng.?
B0100:
Perform trouble checking for the following: the front end sensor, the SDM module, the SDM wiring harness connector. Damage to the following parts needs replacement or repair. For the DTC B0100, detach the front end sensor1 connector and also detach the SDM connector. Perform trouble checking of the signal and voltage circuits between the SDM and the front end sensor for a short to voltage and for a short to ground. Reconnect all the SIR components and if the DTC B0100 is present then the front end sensor1 has to be changed.
B0104
Perform trouble checking for the following: the front end sensor, the SDM module, the SDM wiring harness connector. Damage to the following parts needs replacement or repair. For the DTC B0104, detach the front end sensor1 connector and also detach the SDM connector. Perform trouble checking of the signal and voltage circuits between the SDM and the front end sensor for a short to voltage and for a short to ground. Reconnect all the SIR components and if the DTC B0104 is present then the front end sensor2/right has to be changed.
i could not find anything on the B0140 code so i included the B0104 incase of typo
May 18, 2014 | 2011 Buick LaCrosse CXL
Function keys don't work anymore
I would first reinstall any software/drivers that came with the device. You should also try contacting Logitech Technical Support (+1 646-454-3200). I've dealt with them recently and they were very helpful, even going so far as to replace my device completely at no charge when the support rep could not fix the issue I had.
May 25, 2011 | Logitech Cordless Desktop MX 3000...
Can't find anywhere to buy new feet for my logitech ex110 keyboard
call logitech 1 646-454-3200 option 1 then 2 advise them of what you want then they will tell you cannot give you any replacement parts and will give you a coupon to get 50% off your next keyboard mouse combo. woot
May 05, 2011 | Logitech EX110 Mouse
Keyboard is locked, looks like in safe mode.
Compaq laptop keyboard is locked, looks like in safe mode. How can I get the keyboard to work???
Jul 02, 2009 | Compaq Easy Access Internet Keyboard
We have a magnavok big screen tv
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
Hope that helps, good luck
ALSO:
I searched a Magnavox manual for the lock feature here is what I found...
The following functions are disabled during SDM (and enabled after leaving SDM):
· Parental lock
· Blue mute
· Hospitality Mode
· No-ident Timer (normally the set is automatically switched off when no video signal (IDENT) is received for
15 minutes).
All other controls operate normally.
Entering Service Default Mode
To enter the Service Default Mode, press the following key sequence on the remote control transmitter:
0-6-2-5-9-6-MENU
Do not allow the display to time out between entries while keying the sequence.
Upon entry into the Service Default Mode, the letters “SDM” will be displayed at the upper right corner of the screen.
ALSO:
- Line 7 : “CHANNEL BLOCKED”
Indicates that all channels are locked except the selected channel.
The following complaints may be generated due to locked channels:
- TV cannot be switched on from standby with the local keyboard buttons.
- “CH+” and “CH-“ buttons on local keyboard do not function.
To disable the LOCK feature:
Select ”FEATURE” menu (with the Remote Control).
Select “LOCK” (with the Remote Control).
Set to “OFF”
Sep 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
Looking for a wrist support for a logitech keyboard
Contact Logitech here via email:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/ask.php
or you can call them at +1 646-454-3200
Monday - Friday: 6am - 6pm PST
Saturday - Sunday: 7am - 5pm PST
Hope that helps.
Sep 04, 2008 | Logitech diNovo LX300 Keyboard/Mouse
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
