Question about Cell Phones
Samsung gt s3533
Track pad hang
Track pad quit working
Check if the track pad has been turned off accidently from the top panel which has a track pad turning off button.
Nov 02, 2013 | Toshiba Satellite S955
Pavilion dv7 3174nr track pad in windows 8
Check if there is a rounded area in one side of your touchpad. Tap it twice and it should unlock your track pad.
Dec 30, 2012 | HP Pavilion Computers & Internet
Dvd player dv692h hangs after 1hr of play
Hello
Check the CD for any defect. Hold it against light and see whether there is any tiny spots. If the CD is faulty this kindl of fault can occur. OK.
Jan 09, 2012 | Televison & Video
How to stop your scroller on the blackberry 9300 from freezing ?
Try this, Place some cloth, or a glove on your finger and see if the track pad detects your finger.
If it does response then the problem is with the track pad sensibility.
If it does You will have to adjust the sensibility and/or clean the track pad from any dirt.
If that doesn't solve your problem, you have a damaged track pad that needs to be replaced.
Let me know if you need further assistance on disassembling the curve and replacing the track pad or with any other question you have.
Sep 20, 2011 | RIM BlackBerry Curve 8520 Smartphone
My trackpad on my blackberry 9670 isn't working. how can I fix it?
Bb curve 8520 track pad would not work replaced with a new one but still have the same problem can you help
Try to test at least 2-3 track pad,might the one you bought is still defective,same case i've got in you, on the 4 track pad,it works.
Also clean the main board interface connector of the track pad,might be corroded that is why it is not working properly.
Good Luck...
Aug 11, 2011 | RIM BlackBerry Curve 8520 Smartphone
My computer comes on opens windows all looks ok as soon as i touch the cursor, nothing responds,
Make sure that the track-pad (mouse-pad) is not disabled. There should be a button located above the track-pad that allows you to disable or enable the track-pad. If not, I would use a USB mouse and then go into the Control Panel, mouse and change settings there to enable the track-pad.
Nov 08, 2010 | Acer Aspire 4720 Notebook
Pointer on track pad moves on its own. it does not move along with finger and goes in jerky direction elsewhere.
did water get on the track pad? Try connecting an external mouse to get control over your pointer, and navigate to system preferences/track pad. See if you can play around with the settings, but if the external mouse works ok, it sounds like water may have come in contact with your track pad.
Sep 12, 2010 | Apple MacBook Pro Notebook
MY CONTROLLER WILL NOT CHANGE PROGRAM OR ADJUST VOLUME
Carefully open the remote controller unit and look inside for possible failure of the carbon pads or the remote control PCB tracks.So first of all open to clean the padds and the pcb then check specially on the volume controller pads, use old pads to be stuck on or carbon dots that are available for repairing remote controllers.Repeat this for the program pads. If the fault does not clear then look into the PCB section of the volume tracks and program tracks and use a carbon pen to make the tracks prominent. Hope this works. Good day
Aug 11, 2010 | Bose Wave Music System Remote
Door opener will not engage as mechanism moves along the chain track
Make sure the rope hanging down has not been pulled. If it has the door has been disengaged from the opener. You can correct this by flipping the metal part up (that the rope is connectd to) toward the drive track. Then open or close the door using the remote. The track should grab the door again.
Jul 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
