Hoover 750L1AUS some wireing plugs have come off there pins behind control panel
2 Suggested Answers
  • 19 Answers
SOURCE: wires behind the panel are unpluged
Go to www.desatech.com in the customer care center you will find a link to get owners manual. If they don't have the right owners manual look in the tech tips they have the diagrams in there also.
Posted on Feb 23, 2008
I have a 2004 Dodge Durango With Out a Tow Package. I need to install a Break Controller on in. I have already put the Y connector for the 4 pin harness on, and then installed the 7 pin kit to that. It...
as to under dash will need to look up for a plug and play adapter [if their is one ] and as to the rear plug and play adapter usually tap off connections behind rear light lens or behind the trunk panel
Jul 31, 2017 | 2004 Dodge Durango
My hoover steam vacs brushes will not turn . could there be a belt broken? I have misplaced the manual
For the manual:
http://www.hoover.com/pdfs/manuals/F5914900.pdf
For the brushes:
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
The gear box that drives the brushes is driven by vacuum air, running the turbine inside.
There are no belts, just direct drive.
Mar 10, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brushes on Hoover steam vac dual v do not turn
Nov 19, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
How do you change the belt on a f7441-980 hoover carpet cleaner
There are no belts on the SteamVac series. If you have a brush rotation problem, please check this:
(4)Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen
Oct 06, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover 1200 front loader washing machine is tripping mains ecb
you have a direct short circuit unplug the machine and remove the plug cable cover then: look for wires touching or, wires touching the metal of the machine the plug wires should only touch their respective screws if these are alright then take a multimeter set it for resistance (ohms) place one probe on a plug pin and the other probe on one of the other plug pins if you see continuity you have a short check all interior wires until you find a blackened burned wire etc. when you have high continuity you have fixed the problem
Apr 26, 2009 | Washing Machines
Hoover washing machine does not switch on
Could be a bunch of things... when you say it isn't switching on, you mean that the lights on the display aren't lighting up?
You're going to have to open it up to be sure that there isn't a broken or disconnected wire somewhere, (kind of unlikely, but possible) failing that I would say it is probably the circuit board behind the control panel, on most models, the power goes directly to the wall to the board, so if panel doesn't even light up that is where the problem is.
To open, remove the screws from the back side of the top panel, slide the top back and lift off. Then you can get to the screws holding the control panel on (it also may be held on with plastic snap hooks). Once you get access to the panel, changing the board is pretty easy if you remember to disconnect the cords one at a time, and reconnect them to the new board so that you don't plug anything into the wrong place.
As with all appliances, be sure to unplug from the wall before you begin.
Mar 14, 2009 | Washing Machines
The fridge part of my fridge freezer keeps freezing everything,
Hello
I have the same problem and have talked to the manufacturer. They said to turn off the appliance for 24 hours then it should be good as new when you switch it back on. Obviously you'll have to find somewhere for your freezer contents. I'm going to try this myself tonight.
Fridge Reboot!
Jan 05, 2009 | Hoover HCA390FFK Bottom Freezer...
I am a law enforcemnet officer and I am installing a RADAR unit in a 2008 unit. I need to know the location of the VSS wire. On the 2006, the wire was a gray/black wire located behind the passenger's...
Hi Hodgson, If you want,you can go on alldatadiy.com and buy you vehicle info for under 20 bucks for a year. That will give you all the wire diagrams you need. You will be looking for the vehicle speed sensor signal wire . ( VSS). I would look at the pin out connector of the computer and it will be there. Most of these have 3 wires,one power 5V, and one ground and the other is the signal. Goodluck and let me know if this helps. If you need more info I will be happy to answer any questions you have.Thanks....Dan
Jul 27, 2008 | 1989 Ford Mustang
My Hoover 550 wil not stop filling with water
Possibly caused by a leaking water level sensor. Turn off the power, remove 3 screws at top back of control panel. Rotate the control panel forward and have a look at the white rubber hose on the left hand side. Check that it is connected at both ends and not perished. Also check that the adjuster cam (turn the level knob and look behind) is not broken.
May 01, 2008 | Hoover Washing Machines
One of the pins on the plug on my hoover have snapped off, the top one. so i cut it off & tried to use a normal plug but it has blew the electrics. Is there any way round this? Thanks
If you connected all the wires the correct way to the plug then you could have a short in the wiring in the hoover. Get an engineer to check it out.
Mar 25, 2008 | Vacuums
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
