Unknown error received from icc in lotus notes 8.5.3
IBM System x3100 M4
Palmbeach
  • 185 Answers
SOURCE: Lotus Notes files
Unfortunately, it's not possible.
Lotus notes files are all .nsf and you will only be able to view them with a full client lotus notes installation.
There is no other software available that will read .nsf files.
You could save your archived files to a cd or flash drive, then find someone who has lotus notes and use their system to view your files. You need the full installation as you will not be able to use the web access version to view your old archives.
Posted on Mar 05, 2008
SOURCE: HTC G1 and Lotus Notes ? --- Friends or Unlikely companions.
the link recommend cost 29.99 for a third party software to enable an "email friendly" phone to support corporate e-mail. It's more of a work around a basic problem with this devise
Posted on Nov 24, 2008
jcoady
  • 79 Answers
SOURCE: Lotus Notes 8:How do I turn off ?Send Immediately When Connected?
There is not a perfect mirror of that function in Notes, but you do have options.
The first one is the "Recall" option:
==========Extracted directly from Lotus Notes Help================
You can retract a message that you have already sent and saved in the Sent view. This is useful if you sent a message in error, or if you want to edit the content of a sent message and resend it.
  1. In your mail, open the Sent view.
  2. Select the message.
  3. Above the message list, click Recall Message. If this button does not display, your Domino™ administrator has disabled this feature.
  4. If the message was sent to more than one recipient, select the recipients to recall the message from.
  5. (Optional) To recall the message from a recipient even if the recipient has already opened or previewed it, select Recall the message even if it has been read.
  6. (Optional) To suppress recall status reports, clear Send me a recall status report for each recipient. Recall status reports confirm whether a message is recalled successfully or not.
  7. Click OK.
Note For a message recall to work, both you and the message recipient must be using the Release 8 mail application template (Mail8.ntf) on a Release 8 Domino server, and the message recipient must have the basic mail preference Allow others to recall mail sent to me selected.
Of course this assumes you catch it before they read it.
No other option works on an individual message, but treats all messages with the same 'solution'.
One of those solutions is the somewhat obvious [Save as Draft]. Of course then the onus is on you to follow up and actually send them. I've trained myself to use this option if I'm a bit hot under the collar.
You could assist that process by creating an agent that would flag you with a reminder when messages are held in the draft folder. To do that you will need to know a little bit about agents and scripting. It's not as scary as it sounds - the interface for creating agents helps guide you a bit. And don't get this confused with Rules. Though there are similarities Agents is a more robust scripting environment.
A bit more sophisticated method:
  1. The first step is to set up for local Replication, where your Inbox is mirrored on your local hard drive. This should be done anyway because it allows you to read messages offline and it reduces overall network traffic.
  2. This is similar to how Outlook would store your messages in the local .pst files. Your Notes admins may already have you set up this way. If not, inquire about it - all mobile users will depend upon this, and office users can benefit as well.
  3. The other benefit is that when you click 'Send' it's que'd up to be sent the next time it's scheduled to replicate.
  4. Once you have replication set up and you have defined your replication schedule you will have xx minutes between replications to change your mind. Again, not perfect, but bearable.
A companion to that solution is the use of Location Profiles.
  1. If you look to the bottom right corner of your Notes screen you will probably see the work "Office", or "Network". If you click there you will see your available default location profiles.
  2. Each location profile is set up to a specific enironment. In my office we have "Island (Disconnected)", "Office (Network)", and others - each one set up to assume a certain type of connection to the network.
  3. If I select 'Island" it won't attempt to contact the server, thus convincing Notes I am disconnected from the network and ques all 'Sent' messages to be delivered. Once again the onus is on you to 'connect' by selecting the "Office (Network)" profile in order begin the push/pull of your messages.
For more information look into the Help system for Replication, Location Profiles, and Agents.
A less frequently used option is to use the 'Transfer outgoing mail if: xx messages pending. In this instance you would set the number to a high threshold, say 50. But, again, you would be responsible for forcing the transmission by manually initiating replication.
Unfortunately, none of these is a perfect substitute for the Outlook option you depend on. I hope this helps.
Good Luck!
Posted on Jun 05, 2009
Number5Gayle
  • 98 Answers
SOURCE: The NTVDM CPU has encountered an illegal instruction.
Do you have an anti-virus program? If you are with Comcast, it is FREE to download McAfee...run your virus protection application and see if it hits on it....and then choose to quarantine, or remove...make sure you update you virus protection weekly, you never know what is out there!!
Posted on Jul 31, 2009
SOURCE: RRV bucket error lotus notes 8.0
RRV bucket is corrupt occurs when opeing mail file. Unbable to open archieve folder. We are using lotus notes 6.5 version. Pls help.
Posted on Feb 08, 2010
Lotus notes give an error while accessing the nsf file
1. Click on the "Start" button and then go to "All Programs" in the menu.
2. Click on "Accessories" and scroll down to the "Command Prompt."
3. Right click on the "Command Prompt" and then click "Run as administrator" from the menu.
4. Enter your administrator user name and password into the fields if prompted on the screen and then click "OK."
5. Type "sfc /scannow" into the blank command prompt and press "Enter."
6. Wait for the system to scan your computer and fix the broken file.
If you are still experiencing the issue after applying this fix you can tryLotus Notes Fix Toolbox https://www.fixtoolbox.com/lotusnotesfix.html
Sep 25, 2015 | IBM Lotus Domino Enterprise Server with...
Tip
How to Migrate mailbox data to MS Outlook?
One changing their email client from IBM Lotus Notes to Microsoft Outlook user also want to migrate their mailbox data. Here I like to Introduce Kernel for Lotus Notes to Outlook conversion software for easy and error free conversion of Lotus Notes mailbox to MS Outlook. It will support all Lotus Notes and Outlook version. To download this third party email migration tool visit
http://www.nsfpst.org
on Nov 05, 2014 | Computers & Internet
How to stop 'No Sitemap Found' error in Lotus Notes?
In case you get the error message, while trying to open your mail file using the icon on the workspace, you can dismiss the error message and close all the opened tabs of the mail file. Go to the workspace and use the icon to again open the mail file.
Notes: The 'No sitemap found' error message usually occurs when you open the mail file from the workspace, while mailbox and calendar tabs of a previous session are still open.
There are various other ways to fix such error messages and issues occurring in Lotus Notes. In case you are still not able to see mail items in the mailbox folders, you can use various techniques to recover inaccessible or lost mail items from Lotus Notes.
Since, Lotus Notes is a professional software, used mostly in organizations for an efficient communication; it is advised to use a professional tool to overcome any issue including data loss situations.
Recovery Toolbox for Lotus Notes is a highly efficient tool to recover user mailbox items like emails, contacts, notes, journals, etc. from corrupt or inaccessible Lotus Notes database files. With the ability to display preview of all the recoverable items, the tool ensures an efficient recovery process. The recovered files can be then saved in any desired location. In addition, the tool is widely compatible across various versions of Windows operating system including Windows 8, 7, Vista, Server 2003, XP, 2000, and NT (SP6).
Here the link: https://recoverytoolbox.com/lotusnotes.html
Sep 20, 2015 | IBM Lotus Notes (d53t7ll-bl) for PC, Mac
Lotus Notes Mailbox corrupt
In such situation below steps can be helpful...
Run Fixup command line tool (fixup -f)
Load fixup -i mail\file.nsf
Fixup command line tool checks all documents in the database.
Run Compact command line tool (compact -i -c -d -K)
Load compact -c -i mail\file.nsf
See more helpful solutions found in Internet...
http://www.filerepairforum.com/forum/other/other-aa/lotus-notes/1472-lotus-notes-file-problem
https://www.repairtoolbox.com/lotusnotesrepair.html Lotus Notes Repair Toolbox
http://forums.techguy.org/windows-7/1135994-i-need-help-lotus-notes.html
May 24, 2015 | IBM Lotus Notes (d53t7ll-bl) for PC, Mac
Why can't I open an NSF file in Lotus Notes client?
If you see an error "File is not database" then try to use the program to restore the NSF Viewer Tool as well as detailed information look here http://www.nsf.viewertool.com/
Apr 25, 2015 | IBM Lotus Notes (d53t7ll-bl) for PC, Mac
Sm bus contoller driver
Download the chipset driver for your motherboard.
Jul 20, 2013 | IBM X3100 M4 - E3 QC 3.1G, 2GB, 250GBSS,...
Try re-install the application and reconfigure it from scratch, good luck!
Jul 13, 2013 | Computers & Internet
What is lotes notes.
Lotus Notes is the client side of a client-server, collaborative application developed and sold by IBM Software Group. IBM describes the software as an "integrated desktop client option for accessing business e-mail, calendars and applications on [an] IBM Lotus Domino server." Prior to release 4.5, the termLotus Notes referred to both the client and server applications.
More about here: http://en.wikipedia.org/wiki/IBM_Lotus_Notes http://www-01.ibm.com/software/lotus/products/notes/
Oct 25, 2010 | Computers & Internet
Computers & Internet Logo
132 people viewed this question
David Payne
David Payne
