Teac R-H300 Dual Cassette Deck Logo
Anonymous Posted on Jul 13, 2013
Cassette clamp were to get one - Teac R-H300 Dual Cassette Deck
Sam Palermo
Level 3:
  • Teac Master 1,267 Answers
  • Posted on Oct 14, 2013
Sam Palermo
Teac Master
Level 3:
Answers
1267
Questions
Helped
255888
Points
1842
Try Teac in California-
Parts Department
TEAC America
7733 Telegraph Road
Montebello, CA 90640
Phone: 323-727-4840
Fax: 323-727-7632
E-Mail: [email protected]
Every time a cassette is inserted, within 5 seconds the power light blinks, and the cassette does not play, or the system does not play the cassette although the play button is green.
There could be several reasons why a cassette does not play when inserted into a system, and the power light blinks within 5 seconds. Here are some possible causes and solutions:
  1. Dirty or damaged cassette: The cassette tape itself may be dirty or damaged, preventing it from playing properly. Try cleaning the tape head and the cassette tape itself with a soft, dry cloth or a cassette cleaner. If the cassette is damaged, try playing a different cassette to see if the issue persists.
  2. Faulty cassette player: The cassette player itself may be faulty. Try inserting a different cassette to see if the issue persists. If other cassettes also do not play, then the cassette player may need to be repaired or replaced.
  3. Loose connections: Check that all the cables and connections between the cassette player and the amplifier or speakers are properly connected and not loose. If any connections are loose, tighten them and try playing the cassette again.
  4. Low batteries: If the cassette player is battery-powered, check that the batteries are fully charged or replace them with new ones. Low batteries can cause the power light to blink and prevent the cassette from playing properly.
If none of the above solutions work, then there may be a more serious problem with the cassette player, and it may need to be inspected and repaired by a professional technician.
CD player will not work in my Thomas Pacconi TPC-MSE-800
I have the same unit. Where do you find the screws that hold the cd clamp cover?
What is the proper tool to remove rear wheel cassette from specialized CrossTrail to replace a spoke?
You need a freewheel/cassette removal tool. Here's a link to Park Tools page (great quality tools at reasonable prices) http://www.parktool.com/category/freewheel-cassette There are several different types to fit different styles. My usual method is to remove the quick release skewer, place the tool on the freewheel/cassette, put the skewer back on to hold the tool in place (skewer should be just a little loose). Put the tool side of the wheel down and clamp it in a vise. Then grab the wheel with your hands and twist it sharply (not slow and steady) counter-clockwise. Good luck, Vote if you found this helpful. Al K
I need to change my back gear cable
Shift your rear derail down to the smallest cog on the cassette. Loosen the nut that holds the cable onto the derail. If you are reusing the outer cables back the inner cable out to the shifter. If your replacing the outers also, note where they are installed. There should be an allen screw on the bottom of the shifter that will free up the shifter and expose the knob on the end of the cable. Pull out the old cable and install new in reverse. Insert the cable into the clamp on the derail. Pull the cable taught with pliers while tightening nut on clamp. Run through the gears while on middle ring on front. Turn barrel adjuster on derail in and out to dial in shifting. That should do it. Good luck and let me know if you have any problems.
3helpful
I am getting a supply Rec Paper Cassette alarm error. How do i fix this and have it work again.
Hi ..
This error comes when the paper is not loaded properly in the cassette ... Follow the below instructions to load the cassette and I am sure you will not get the error again.
  1. Grip the cassette handle, and pull it out towards you until the cassette comes to a stop.
  2. Open a package of paper, and remove the paper stack. small_note.gif black_dot.gif If the paper is curled, uncurl it before placing it in the cassette. Failure to do so will cause paper creases and a paper jam. black_dot.gif 17 lb to 20 lb bond (64 to 80 g/m2 ) paper is acceptable. black_dot.gif The cassette holds up to approximately 500 sheets of 20 lb bond (80 g/m2 ) paper.
  3. Load the paper stack beneath the cassette's length guide (1) and width guide's claw (2).
    load_paper_in_cassette.gif small_note.gif black_dot.gif Make sure that the paper stack does not exceed the length and width guides' claws in the cassette. Failure to do so will cause a paper jam. black_dot.gif Do not load extra paper when there is still paper left in the cassette. black_dot.gif Only load one size of paper into the cassette. Do not load different sizes of paper into the cassette at the same time. black_dot.gif Do not load labels or transparencies into the cassette.
  4. Gently insert the cassette as far as it will go.
small_note.gif black_dot.gif The cassette is for plain paper, colored paper or recycled paper only. Loading other paper in the cassette may cause a paper jam. black_dot.gif If copies are curled, or a paper jam occurs, remove the paper stack from the cassette. Turn it over and then place it in the cassette. black_dot.gif If you load paper while making copies, do not load a different paper size.
Closing the cassette When closing the cassette, make sure to push it in completely as far as it will go. If copying is performed when the cassette is not pushed in completely, it will cause a paper jam.
If copy paper is sticking out of the cassette Sometimes, when you pull out the cassette, paper may stick out, as shown in the illustration below. Make sure that the paper is neatly loaded into the cassette, before you push the cassette back into the main unit.
Don't forget to vote if this helps ... Cheers :)
Cassette drive turns, speakers hiss but no music
Mode switch trouble! no audio from cassette function?
DCR-HC42
  1. I'm having the exact same problem. It wont accept the cassette...only half way then errors. It will close fully without a cassette as well. hmmmmm
Comment by Guest, posted on Apr 02, 2008 Load cassette, turn it on, then message says re-load cassette. Door to cassette compartment only works half way. After fiddling with power, can get the cassette door to open and close all the way, but not with cassette. Tried several brands of cassettes, no joy.
2answers
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
