Unknown error received from icc in lotus notes 8.5.3
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
Try re-install the application and reconfigure it from scratch, good luck!
Posted on Aug 07, 2013
3 Suggested Answers
jcoady
  • 79 Answers
SOURCE: Lotus Notes 8:How do I turn off ?Send Immediately When Connected?
There is not a perfect mirror of that function in Notes, but you do have options.
The first one is the "Recall" option:
==========Extracted directly from Lotus Notes Help================
You can retract a message that you have already sent and saved in the Sent view. This is useful if you sent a message in error, or if you want to edit the content of a sent message and resend it.
  1. In your mail, open the Sent view.
  2. Select the message.
  3. Above the message list, click Recall Message. If this button does not display, your Domino™ administrator has disabled this feature.
  4. If the message was sent to more than one recipient, select the recipients to recall the message from.
  5. (Optional) To recall the message from a recipient even if the recipient has already opened or previewed it, select Recall the message even if it has been read.
  6. (Optional) To suppress recall status reports, clear Send me a recall status report for each recipient. Recall status reports confirm whether a message is recalled successfully or not.
  7. Click OK.
Note For a message recall to work, both you and the message recipient must be using the Release 8 mail application template (Mail8.ntf) on a Release 8 Domino server, and the message recipient must have the basic mail preference Allow others to recall mail sent to me selected.
Of course this assumes you catch it before they read it.
No other option works on an individual message, but treats all messages with the same 'solution'.
One of those solutions is the somewhat obvious [Save as Draft]. Of course then the onus is on you to follow up and actually send them. I've trained myself to use this option if I'm a bit hot under the collar.
You could assist that process by creating an agent that would flag you with a reminder when messages are held in the draft folder. To do that you will need to know a little bit about agents and scripting. It's not as scary as it sounds - the interface for creating agents helps guide you a bit. And don't get this confused with Rules. Though there are similarities Agents is a more robust scripting environment.
A bit more sophisticated method:
  1. The first step is to set up for local Replication, where your Inbox is mirrored on your local hard drive. This should be done anyway because it allows you to read messages offline and it reduces overall network traffic.
  2. This is similar to how Outlook would store your messages in the local .pst files. Your Notes admins may already have you set up this way. If not, inquire about it - all mobile users will depend upon this, and office users can benefit as well.
  3. The other benefit is that when you click 'Send' it's que'd up to be sent the next time it's scheduled to replicate.
  4. Once you have replication set up and you have defined your replication schedule you will have xx minutes between replications to change your mind. Again, not perfect, but bearable.
A companion to that solution is the use of Location Profiles.
  1. If you look to the bottom right corner of your Notes screen you will probably see the work "Office", or "Network". If you click there you will see your available default location profiles.
  2. Each location profile is set up to a specific enironment. In my office we have "Island (Disconnected)", "Office (Network)", and others - each one set up to assume a certain type of connection to the network.
  3. If I select 'Island" it won't attempt to contact the server, thus convincing Notes I am disconnected from the network and ques all 'Sent' messages to be delivered. Once again the onus is on you to 'connect' by selecting the "Office (Network)" profile in order begin the push/pull of your messages.
For more information look into the Help system for Replication, Location Profiles, and Agents.
A less frequently used option is to use the 'Transfer outgoing mail if: xx messages pending. In this instance you would set the number to a high threshold, say 50. But, again, you would be responsible for forcing the transmission by manually initiating replication.
Unfortunately, none of these is a perfect substitute for the Outlook option you depend on. I hope this helps.
Good Luck!
Posted on Jun 05, 2009
SmokinJoe666
  • 77 Answers
SOURCE: How to Archive mails in Lotus Notes 8?
Open your Inbox, Select the mails you need to archive > Go to Actions menu on top and select Archive > Archive Selected documents. You should have an Archive Criteria created before doing this. To create a criteria, Go to Actions> Archive> Create Criteria and give a name and file path for the archive.
Hope this helps. Good Luck.
~SmokinJoe~
Posted on Apr 20, 2011
Testimonial: "Thank you very much.. it worked :-)"
A database error occurred
Hi
You can read more such errors and their solution from the given link. This blog will help to analyze the Lotus Notes problems and give you the easy approach to resolve them smartly. This will enhance your knowledge about IBM and the tips to fix them.
Read more:- http://www.nsfsecurityremover.com/blogs/lotus-notes-error-messages/
Thanks
Mar 20, 2018 | Sony Computers & Internet
Tip
Convert Lotus Notes mailboxes to Outlook profile
Make use of Lotus Notes to Outlook converter software to efficiently migrate NSF data, including mailbox properties - To, Cc, BCC, subject, email attachments from Notes to Outlook PST file. The software compatibly supports Lotus Notes versions 5, 6, 7, 8 and above, MS Outlook versions 2000, XP, 2003, 2007, 2010, 2013, 2016 and all versions of Windows 95, NT, 98, 2000, XP, Vista, Win7, 8, 8.1, 10.
Useful Features:
  • Converts almost everything from Lotus Notes into PST including Unicode content.
  • Large size of Lotus Notes files can be converted accurately and quickly.
  • Supports Conversion from Domino Server 8.5/8.0/7.0/6.5/6.0 to Exchange Server 5.0/5.5/2000/2003/2007/2010/2013/2016
  • Converts NSF to PST file that can be easily imported into MS Outlook profile
  • Provides options to save the converted Notes email items as PST, TEXT, RTF or HTML files
To Know more about software - http://www.nsftopstconverter.notestooutlook.net/
on Nov 25, 2016 | Computers & Internet
LotusNotes Cannot open the file.
Maybe this will help:
Solution:
  1. Open a command prompt and change the directory to your Lotus Notes program directory.
  2. Enter the command: nfixup.exe X:/<name-and-location-of-the>.nsf (+enter) ...
  3. Enter the command: ncompact.exe X:/<name-and-location-of-the>.nsf (+enter) ...
  4. Enter the command: nupdall -r X:/<name-and-location-of-the>.nsf (+enter)
Feb 21, 2018 | Lotus Computers & Internet
Email client IBM
I have found an effective solution, trying which will surely help you in sorting out this issue. so have a look to this thread:
https://www.fixtoolbox.com/lotusnotesfix.html
Nov 17, 2017 | IBM Computers & Internet
How to stop 'No Sitemap Found' error in Lotus Notes?
In case you get the error message, while trying to open your mail file using the icon on the workspace, you can dismiss the error message and close all the opened tabs of the mail file. Go to the workspace and use the icon to again open the mail file.
Notes: The 'No sitemap found' error message usually occurs when you open the mail file from the workspace, while mailbox and calendar tabs of a previous session are still open.
There are various other ways to fix such error messages and issues occurring in Lotus Notes. In case you are still not able to see mail items in the mailbox folders, you can use various techniques to recover inaccessible or lost mail items from Lotus Notes.
Since, Lotus Notes is a professional software, used mostly in organizations for an efficient communication; it is advised to use a professional tool to overcome any issue including data loss situations.
Recovery Toolbox for Lotus Notes is a highly efficient tool to recover user mailbox items like emails, contacts, notes, journals, etc. from corrupt or inaccessible Lotus Notes database files. With the ability to display preview of all the recoverable items, the tool ensures an efficient recovery process. The recovered files can be then saved in any desired location. In addition, the tool is widely compatible across various versions of Windows operating system including Windows 8, 7, Vista, Server 2003, XP, 2000, and NT (SP6).
Here the link: https://recoverytoolbox.com/lotusnotes.html
Sep 20, 2015 | IBM Lotus Notes (d53t7ll-bl) for PC, Mac
Lotus Notes Mailbox corrupt
In such situation below steps can be helpful...
Run Fixup command line tool (fixup -f)
Load fixup -i mail\file.nsf
Fixup command line tool checks all documents in the database.
Run Compact command line tool (compact -i -c -d -K)
Load compact -c -i mail\file.nsf
See more helpful solutions found in Internet...
http://www.filerepairforum.com/forum/other/other-aa/lotus-notes/1472-lotus-notes-file-problem
https://www.repairtoolbox.com/lotusnotesrepair.html Lotus Notes Repair Toolbox
http://forums.techguy.org/windows-7/1135994-i-need-help-lotus-notes.html
May 24, 2015 | IBM Lotus Notes (d53t7ll-bl) for PC, Mac
Why can't I open an NSF file in Lotus Notes client?
If you see an error "File is not database" then try to use the program to restore the NSF Viewer Tool as well as detailed information look here http://www.nsf.viewertool.com/
Apr 25, 2015 | IBM Lotus Notes (d53t7ll-bl) for PC, Mac
How do an user of Notes move all data into Outlook?
Nsf to Pst Converter programming which is one of the product for relocation from Lotus Notes to Outlook. This device is intended to determination all issues identified with email relocation from Lotus Notes to Outlook and guarantees faultless and flawless change. Free Trial form trade the NSF document to pst record and reveal to you the sneak peak on changed over letter box:- NSF to PST Conversion
Apr 23, 2015 | Microsoft Office Computers & Internet
Lotus notes. I receive the following message
-> restart the server, then try again
-> compact/fixup the users desktop.ndk database
-> try to create a new replica of the database (which is in fact similar to copy style compact)
Some actions from here: http://www.filerepairforum.com/forum/other/other-aa/lotus-notes/1195-lotus-notes-showing-errors-while-opening-documents-in-nsf-nsf-file-database
Or:
Lotus Notes Repair Kit
A must-have tool for quick and hassle-free Lotus Notes repair. The product combines the convenience of a step-by-step wizard with the power of professional data recovery tools.
For more information: http://www.lotusnotes.repair/
Jan 23, 2015 | Computers & Internet
Is the HTC evo 4G compatible with Lotus notes?
you can contact your mobile service provider.....
Jul 14, 2011 | HTC Cell Phones
Computers & Internet Logo
268 people viewed this question
David Payne
David Payne
