Question about Toshiba PORTEGE M200 TABLET PC
No sign of life
Laptop power comes on but... it does nothing, it does not make any noise, the screen remains the same, their is no sign of life except for the power lights. I suspect the System board has gone bad. Can anyone confirm that or tell me what the problem is? Any help would be greatly appreciated. Paula
    Sergeant:
  • 361 Answers
Once atime u can try to stall oprating system. in this way i had solved same problem. if not we can check system by using ERD commander2005. if not repair then we can say any hardweare is damage as ram/processer/p.c. 2/ isnt your computer resolution is high? go on f8 and adjust.
Posted on Jun 13, 2009
  • Roshan Rijal
    Roshan Rijal Jun 13, 2009
    once atime u can try to stall oprating system. in this way i had solved same problem. if not we can check system by using ERD commander2005. if not repair then we can say any hardweare is damage as ram/processer/p.c. 2/ isnt your computer resolution is high? go on f8 and adjust.
SOURCE:
WHAT CAN I DO TO MAKE MY VISUAL LAND 7Q TABLET WORK AGAIN?
then get a good job so you make money . then buy a new one of do what you did before . live without it .
Jun 25, 2015 | Tablets & eReaders
It wont turn on when charging the red light is on for abut 4hours and then turns green i unplug it and it wont turn on ive holding down the volume + and power button and still nothing
tablets are designed to be throwaway.
you can buy new batteries off ebay but replacing the battery will require cutting and soldering as the batteries in these tablets are soldered directly to the board and are stuck in place with glue and electrical insulating glass tape. Not a big job but fiddly and anyone with a soldering iron skill and basic leccie-tronics can do it.
it may be the battery - when you press the power button does the screen flicker or does the green power light come on.
pressing the power button whilst pressing the up or down volume button should take you into recovery mode - do this whilst the power block is plugged in - if the tablet shows signs of life with the power block plugged in you can be sure its the battery..
when tablets are vroken its usually by being dropped and this can cause the screen connector to come loose so you get no display but power lights will still be on.
Apr 26, 2015 | Nabi 2
Pc tablet power up but black screen
Could be power-supply or motherboard or video-adapter.
Take it to an authorized service-depot, for proper trouble-shooting.
Jan 06, 2014 | HP Pavilion Entertainment tx2500 Tablet...
How to maximise your iPad battery life?
And while the iPad may have a fairly long battery life, you're still going to need a few tips on how to keep it lasting as long as you can. Here are some hints on how to perverse the iPad between charges:
In the "settings" folder there is an option to turn down the screen brightness. Keeping it down a little won't ruin your experience and will help prolong life.
Turn off 3G and WiFi services when they aren't needed. You'll only need them when connecting to networks or downloading/browsing data, so turn them off when you can.
Make sure apps aren't running in the background when they don't have to. Turning apps off from the multitasking tray can save you some juice.
Run the battery out every few weeks. Giving the iPad a full charge will ensure it remains in good condition.
Turn the screen off. When you aren't using your iPad, then turn the screen off and don't waste any unnecessary power.
More Information:http://www.agptek.com/Maximise-your-iPad-battery-life_109_1.html
Mar 07, 2013 | Tablets & eReaders
Archos 97 carbon tablet has frozen, cannot turn off or nothing have tried holding power key but still unresponsive
it is dead easy. just get a paperclip and open one side of it, now look on the side of the 97 there is small hole between the USB port and the flash sd card, insert the paperclip end an hold until the system resets itself.
All will come back to life after pressing the power button..
No data wil be lost, I have done it lots of times.
Jan 26, 2013 | Archos 97 carbon 16GB 9.7" Capacitive...
Tablet has not been used for long time. It was given to me. Battery is empty for sure. When I connect PC to the power suppy it does not show any sign of life. No light - nothing. I tried the same without...
The power adapter may be faulty.
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.
Apr 28, 2011 | Compaq tc1100 Tablet PC
My literati won't turn on and I thought it may not be charged but when I charge it, the screen doesn't turn on still.
My Literati doesn't start. I tried to rest it, but nothing happened. I plug it in the power for more than an hour and tried again to reset it, but a gain no sign of life in it. Any suggestions.
Jan 18, 2011 | Sharper Image Literati Reader 16375680042...
Jensen NVZ225 doesn't show any signs of power, from car or home
Just a guess here! But i think you have battery failure ( not sure what you mean by let it sit up for a while..) You could try leaving it on thw AC charger overnight. If a battery is totally depleted it will take some time before enough charge is accumulated to operate the screen
Jun 29, 2009 | Jensen Mobile PC Tablet
Toshiba tecra m2 laptop wont start..
nothing happen when you press power? and when you plug energy no led?
Aug 27, 2007 | Toshiba Tecra M214-XGA (PTM20U0776X7)...
Open Questions:
See all Toshiba PORTEGE M200 TABLET PC Questions
Tablets & eReaders Logo
224 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Ekse
Alun Cox
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
