Question about Toshiba 46G310U LCD TV
I get no video signal from all thre HDMI inputs.
    Top Expert:
  • Toshiba Master
  • 75,581 Answers
If software to this board has not installed, it won't work. Check for it. It is best to contact the authorized service center. If you're something in electronics, check the site linked here. It has details about software update procedure to many brand TVs. If you don't know, do not proceed. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Timeslide / Mosaic option.
Posted on Jul 13, 2013
No video or audio from HDMI inputs, (DirecTV and Xbox), rca aux input or Component input. Over-the-air HDTV from the Antenna is perfect audio & video
HDMI Input Problems - TV Not Showing Image - TV Repair ...
? 2:34
https://www.youtube.com/watch?v=ZtaUPX1tHP0
May 26, 2015 - Uploaded by ShopJimmy.com
Basic troubleshooting and replacement tips for HDMI inputs that are not ... video or audio from your HDMI port, you can take the source video ...
no signal? -hdmi - LG 55LE5400 tv - Forums - CNET
www.cnet.com > Forums > LG
CNETJun 14, 2014 - Sunday my husband hooked up an RCA ANT571 antenna with great results. ... The Roku first showed no signal on the TV. I tried hooking the Roku up to other HDMI ports, i changed the hdmi cables, .... Sound comes through, but not picture. ..... Video; All Video · Apple Byte · Carfection · CNET Top 5 · CNET ...
No sound on LCD TV - Desktop HDMI connection [Solved] - CCM
ccm.net > Forum > Hardware
Oct 11, 2012 - The video is excellent, but there is no sound coming out of my TVspeakers. ..... I also tried inputs besides the "HDMI 1" input and the other RCA ...
HDMI vs Component ' TVBlanket
Feb 03, 2016 | RCA Televison & Video
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
Rx-v1900 hdmi hdtv problem
On most modern receivers you must select which signal type you want it to process.
for example on my Denon, I have to go into the on screen menu and select the input I want ie: video 1.Then tell it which signal I want it to use ie: s-video, component or HDMI input for video and then which input corresponds to the audio signal for that component ie: analog, digital, optical or hdmi.
Its complicated and a pain in the ****
Hopefully that helps call Yamaha they will usually walk you through the process while on the phone.
Feb 14, 2010 | Yamaha RX-V1900 Receiver
I have Denon 4308. Is it possible to use video select with hdmi?  When I try,the screen goes blank. -- Regards JP Naess Norway
From the manual of your Denon page 41:
http://www.usa.denon.com/AVR-4308CI-OM-E_305A.pdf
"Video Select -It is not possible to select HDMI input signals. • When playing HDMI video input signals, the analog video signal of another input source cannot be selected for the HDMI video output."
Nov 24, 2009 | Denon AVR-2807 Receiver
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Apr 22, 2009 | Yamaha RX-V663 Receiver
Picture from analog tv signal is not sharp
I have this same machine, you did'nt mention what input you are using (composite, S-Video, component or HDMI) or what type of display you have (CRT, LCD, Plasma etc.).
If your T.V. has a HDMI input I recommend using that, if not and it's of fairly recent vintage use the component inputs (not to be confused with composite video inputs, or yellow RCA-type input).or at the very least use the S-Video input.
In the setup menu (on screen) try setting the "TV Screen" option to the 480p setting and if you are using the HDMI input try setting that to the highest resolution your T.V. has or set it to "Auto"
Finally in the on screen video menu select the "Video" setting and set the "Still Mode" option to automatic, and the "Output Level" to lighter or darker whatever your preference is.
Remember...Always use HDMI or component video inputs on your television (if it has those inputs)!
Hope this helps!
Joe
Nov 19, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
No input signal HDMI
turn on and hold down the on/off button for thirty seconds when it resets it will load up via hdmi lead this works both ways going from sd to hd, failing that have both connections plugged in both scart and hdmi lead then change the settings to hdmi when viewing through scart connector then flick to hdmi input and hey presto its worked.........
Nov 09, 2008 | Sony Playstation 3 (PS3) Console
No input detected on projector
it sounds like the A/V reciever does not upconvert the component signal to HDMI. Not many do. The Marantz recievers will (SR6001, SR8001, etc..). Also bear in mind that HDMI cables are finicky and may require amplification over a few meters long.
Dec 04, 2007 | Hitachi PJTX100 Multimedia Projector
Toshiba 46G310U LCD TV Logo
37 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
