Question about Medline Chrome Manual Hoyer Hydraulic Patient Lifter With 6 Hooks
Vw golf mk4 gti 1.8t agu hydraulic lifter noise
Makes very bad noise and misfires then idled normaly and now doesnt start
Audi a4 1998 tapping noise only when idles under valve cover
Sounds like a bad valve lifter or a valve out of adjustment. It's probably a bad hydraulic valve lifter. In idle, when the oil pressure is lowest, it is not filling with oil. When the motor revs up, oil pressure rises and fills the faulty lifter.
If you do have mechanical lifters, the valve is probably out of adjustment. If you do car work, pull the valve cover and see if it's adjustable. Of course, you'll need the specs from VW/Audi.
Otherwise, it's probably a shop job.
Sorry.
Jul 05, 2014 | 1998 Audi A4
Serious electrical problems wiv vw golf mk4 gti turbo yr 2000
I had a VW rabbit that developed mad electrical problems. It started when one day the headlights remained on and would not shut off. It turned out that a $2.00 gasket for the antenna wire had failed. This allowed road water from the wheel well to leak onto the fuse box. In time the fuse panel corroded and shorted out. I had to replace the fuse box twice and use rubber epoxy to seal the leak.
Check all fuses and electrical wiring for signs of shorts or corrosion.
Jul 25, 2009 | 2000 Volkswagen Golf
Mk4 gti 1.8t cut out
it might be the e break sensor . ive heard of them causing shut downs . also check all fluid levels if your coolant is too low the sensor will shut it down lol. and i think theres a break light recall that might have something to do with it . take it in to vw if you have the means for a scan . of find someone in your area with a vag com . it can read the error codes from the computer . good luck
01 gti 1.8t blk on blk
Jun 19, 2009 | 2001 Volkswagen Golf
Loosing clutch when drive fast threw the gears
do you lose any fluid? there is know adjustment in hydraulic . did you get a bad remanufactured part ?
Jun 16, 2009 | 2000 Volkswagen GTI
VW MK4 IMMOBILISER
You need to get your key reprogrammed at your dealer... Did u drop the key as this can sometimes cause the key to loose the code, i dont know hoe all i no is i had to get it done a few times.
May 16, 2009 | 2001 Volkswagen Golf
'96 VW Golf GL with 2.0 motor. Cold start knock
It sounds like the hydraulic lifters are bleeding down after sitting for a while... there are ball checks which are supposed to prevent this... Try using a good engine flush (a product that frees sticky lifters) and replace the oil with a good synthetic... Hope this helps...;-)
Apr 27, 2009 | 1997 Volkswagen Golf
1991 1.8 jetta
I would say probably not a weak oil pump...
Visit http://www.ratwell.com/technical/HydraulicLifters.html for a good explanation on how hydraulic lifters work.
Might be a bad valve adjustment (yes, valvetrains with hydraulic lifters still have some kind of adjusting mechanism), or lifters which get airlocked (bleed down fast and have a hard time pumping back up by themselves)
Aug 20, 2008 | 1991 Volkswagen Jetta
Mk2 Golf GTI 2l 16v Not Performing Like IT Should!
ive had this problem the loud tapping noise if properly you have the wrong oil in the engine the lifters only have a very small hole in for the to get in so if it to thick it cant get in causing the slapping noise.
Jun 15, 2008 | 1992 Volkswagen GTI
Medline Chrome Manual Hoyer Hydraulic Patient Lifter With 6 Hooks Logo
35 people viewed this question
Top Medline Health & Beauty Experts
rugby prop
ka4iup
ka4iup
Are you a Medline Health and Beauty Expert? Answer questions, earn points and help others
