Question about Kobalt Large Gravity Feed HVLP Spray Gun SGY-AIR86
Kobalt large gravity feed paint gun
Took the gun apart to clean cant remember how it go?
  • joey Jul 14, 2013
    I need a complete diagram of how this paintgun is put together cleaned it and now can't remember how to put it back together.
How do you take this hvlp gun apart for proper cleaning of the spray gun?
I've found over the years the least amount of times you can tear a spray gun completely apart the better. Usually a real good 'flushing' with lacquer thinner will suffice. I will take the air cap off and let it soak in thinner to dislodge any build up but other than that, I simply run thinner thru till it runs clear out the tip.
I also 'back flush' which involves having thinner in the cup and the air supply hose attached. the air pressure should be adjusted quite a bit lower than what you use for spraying paint.
Then you place a clean shop towel or rag over the air cap of the gun and pull the trigger. This forces air back into the paint cup 'back flushing' the gun. Then take the rag away from the cap and pull the trigger again to run thinner thru the gun the normal way.
IF you still want to tear the gun apart for cleaning you can hopefully get some idea with this video link;
Quick Easy Way to Clean HVLP Spray Gun
Hope this helps.
May 25, 2015 | HVLP Air Tools & Compressors
Kobalt gravity spray gun and I have a little air that comes out constantly. Why is that and how do I stop it? Thanks
You must be using a "turbin" which is different and better than a compressor however a turbin runs all the time and air must escape from it unlike a compressor with an airtank the shuts off after the desired pressure is reached it shuts it self off then turns back on with tank pressure drops below what you have set it at- a turbin reaches the pressure you set the regulater at and maintains it constantly NEVER STOP THE AIR FROM PASSING THRU IT in fact a lot of times i do this to remove any dust i may have missed so evrything is working like it should on yr sprayrig..
perry tradesman
Oct 19, 2014 | Kobalt Large Gravity Feed HVLP Spray Gun...
I HAVE CLEANED MY DH3800 SPRAY GUN AND THE PAINT WILL HARDLEY COMES OUT I AM USING 60 PSI ON A LARGE COMPRESSOR WHAT AM I DOING WRONG AND THIS ONLY THE SECOND TIME THAT I HAVE USED IT ( AND THAT IS...
These guns are made to use about 35 - 45 lbs psi and the paint needs to be thinned a bit. You will have to experiment with the thinning for how much coverage, how much humidity, what type of paint and thinner it takes.
Sep 25, 2011 | Campbell Hausfeld Air Comp Basic Spray Gun...
We are having trouble getting the spray gun to pull the paint through. It will spray air but does not spray paint.
when you pull the trigger can u see the needle moving backward? if so, then it's either the paint is too thick compare to the nozzle size or the passage for paint is blocked. try to take the nozzle, needle and the cup off and give it a good clean!
Sep 05, 2011 | Campbell Hausfeld Husky Gravity Feed HVLP...
Hey yall i got a sharpe finex3000 hvlp spray gun model sh-880 1.4 finish gun. and ive used this gun before and i cant remember how 2 set it up etc or what the best working pressure is. anyways i was tryen...
There is a step by step description in the manual of the Finex3000 itself (incl. pressure set-up, etc...). In case you don't have it anymore, you can look online: http://sprayfinishingstore.com/manuals/
Jul 25, 2011 | RTO Sharpe Finex 3000 Hvlp Gravity Auto...
Porter cable PSH 1 - clogs even with thinned paint compressor 4 gal 5.1 scfm
strain paint befor using. run water in gun or thinner to see if it will spray it before using and mix paint to the consistancy that spray gun or paint requires for spraying ( fine strainer)
Feb 04, 2011 | Porter Cable Gravity Feed Paint Sprayer
I cant decide between two airbrushes i am thinking on ordering.I want a large cup gravity feed and right now am debating between the Badger 100LG and the Paasche Talon.Any comments would be great
I am not familiar with either brush, but they are both well known name brands. The Paasche will probably have more readily available parts for it than the Badger in case something breaks or you drop it. I myself use Iwata, BUT the parts are expensive.
It will boil down to which brush comes with what size tip/needle in accordance to what type of media you will be shooting. Thicker paints or stains will require a bigger tip and needle, thinner paints and stains, just the opposite. I hope this helps.
Feb 21, 2010 | Paasche Talon Gravity Feed Airbrush Set
Operating instructions for central pneumatic industrial paint spray gun md 91011
My #91011 One Quart is not a gravity feed, it is air compressor fee fed. My problem is the nozzle will not fan out . It only blows a round spray mist. ?
Oct 26, 2009 | RTO Central Pneumatic Gravity Feed Spray...
I bought a psh1 to spray latex as the reviews
Hi
What size is the jet?
What compressor pressure are you using, LOW is good >20PSI
You will need quite a large jet for latex paint even thinned. I have tried a 1.8mm jet and that still clogs!! Consult your local spray painter with what size jet you need.
I am betting the standard size of 1.5mm is way too small, that type of gun is fine with the correct jet size.
Aug 12, 2009 | Porter Cable Gravity Feed Paint Sprayer
Kobalt Large Gravity Feed HVLP Spray Gun SGY-AIR86 Logo
82 people viewed this question
Top Kobalt Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Kobalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
