Question about eMachines Acer 350-21g16i Netbook
What are the most problems of a phoenix bios beep coeds?
    Brigadier General:
  • eMachines Master
  • 3,400 Answers
Looking for a list of Toshiba beep codes please
this comes with two different version of bios, therefore different codes...
these are for phoenix bios:
http://pcsupport.about.com/od/fixtheproblem/tp/phoenix-beep-codes.htm
another bios'es have similar sequences, select other bios codes here:
http://www.bioscentral.com/beepcodes/awardbeep.htm
and here:
http://www.pchell.com/hardware/beepcodes.shtml
hope this will help you solve your problem, beeps usually are sign that something is wrong with motherboards, if you changed any hardware - check if it is inserted correctly and fully, and that includes portables, remove any external drive, external mouse or indeed any external attachment and then try to start your laptop and check if there is any beeping...
hope this will help you solve your problem, do not forget to vote...
Feb 19, 2015 | Toshiba Satellite Computers & Internet
Tip
Computer POST and beep codes The computer power on self test (POST) will test...
The computer power on self test (POST) will test your computer to make sure it can boot properly(test hardware and sys requirements), once it does the computer will then finish the boot process. Normally, if your computer passes the POST test it will beep once or possibly twice. If the computer fails the POST then it will either not beep at all or generate a beep code.
The beep code you receive can indicate what may be wrong with your computer. The beep codes vary depending on your motherboard BIOS manufacturer(AMI, Award, Phoenix). You can find what BIOS you are using by paying attention to the BIOS screen when your computer boots up. It should tell you what brand BIOS.
You can usually find the meaning of your beep code by doing a simple google search i.e "phoenix beep codes". Below, I have provided links to sites which go over beep codes and their respective meaning.
AMI BIOS Beep Codes
Award BIOS Beep Codes
Phoenix BIOS Beep Codes
-G33k
Keywords
computer beep codes, post beep codes, bios beep codes, computer beeps, computer will not start beeps, computer beeping, pc beep codes, award beep codes, phoenix beep codes, Ami beep codes
on Jul 27, 2011 | Computers & Internet
2 LONG BEEPS BUT THE PC STILL BOOTS mobo asus m4a785-m phenom ii x4 945 c3 4 gigs kinston ddr2 800 thermaltake 600w pny gtx 460
Beep codeswere first introduced by IBM on their first PC as a means of trouble shooting failures. The two long beeps are not familiar, but who knows. look at the following site for some of the Bios beep codes.
http://www.pantherproducts.co.uk/Articles/Motherboard/BIOSbeep.shtml#Phoenix BIOS
Jan 03, 2011 | ASUS M4A785M (890552666775) Motherboard
Got beep codes on a pavillion 5150 laptop
Your BIOS manufacturer's site will explain in full the beep codes you're experiencing. The beeps you are explaining is your system failing the POST (power on checks), it emits a series of beeps to tell you the precise nature of the problem. Beep codes are BIOS-specific. The following BIOS sites should help you. You must however first, identify which BIOS you've got.
Award � http://www.phoenix.com/pcuser/BIOS/award_error_codes.htm
Phoenix � http://www.phoenix.com/pcuser/PDF-Files/bios-postcode.pdf
AMI � http://www.ami.com/support/ For all other bioses try http://www.abios.com
Or try these alternative sites:
http://www.tufshop.com/support/beepcodes.htmlhttp://www.hardwarecentral.com/hardwarecentral/tutorials/13/1/http://www.phm.lu/Documentation/Firmwares/BIOS%20Errors.asphttp://www.efacorp.com/support/notes/980216.htm
Aug 05, 2010 | HP Computers & Internet
How will you absorved no display
I have looked at a PDF of your manual, but it did not give the BIOS (Basic Input Output) type. I did see a screen shot referencing Phoenix-Award BIOS, so I will give you the video adaptor error for both BIOS manufactures.
Award - You will hear one long beep and two short beeps from the speaker, which is a video adaptor error.
Phoenix - You will hear three beeps pause, four beeps pause and one beep from the speaker, which is a video adaptor error.
If you hear no beeps at all or another sequence of beeps from your speaker it could be another problem.
You can install a PCI Express video card in your computers PCI Express slot to test your on-board video.
Jul 02, 2010 | Foxconn 45CMX socket LGA775 motherboard...
My E-Machine T6544 will not boot up - monitor reads no signal, but fan and hard drive seem to be running on the tower
Do you hear any beep codes?
Mar 14, 2010 | E-Machines eMachines Desktop PC
Aspire 1800 video problem how to fix 1 long beep 3 short beeps
I'm going to assume that you have Phoenix Bios on that laptop. I assume this because the error code you described also describes your problem. 1 long beep and 3 short beeps on Phoenix Bios means " Enhanced Graphics Adapter ( EGA ) " failure usually. Which means, something can be wrong with the graphics card in that laptop. I'm not 100% sure that there IS a way to fix that other than bringing it in, unless the 1800 has an interchangeable graphics card, you may need to send it into a repair shop.
Jul 06, 2009 | Acer Aspire 1800 Notebook
POST-Beep-Code List availible for Phoenix-BIOS? ECS 755-A2
The problem is with your RAM. Try installing the RAM in another slot. Install your AGP card slowly. I can assure about your motherboard yet you have no problem without assembling. Keep informing.
Feb 22, 2009 | EliteGroup SiS755 (755-A2 V1.0)...
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
At POST I get 2 short beeps
it depends on the bios chip maker Here's some other beep codes:
for Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly
Short continuous beeps: Bad power supply
AMI BIOS:
1 short beep: DRAM flash error
2 short beeps: DRAM ECC check error
3 short beeps: DRAM detect error
5 short beeps: CPU error
6 short beeps: Keyboard error
8 short beeps: Video card error
1 long and 3 short beeps: Bad DRAM
1 long and 8 short beeps: Video card error
Invoking Beep Codes
If the computer is actually functioning and the computer beeps continuously, then there is a problem with a voltage on the power supply being incorrect or the CPU overheating. IMMEDIATELY go into the BIOS and check CPU temperature, fan speed and voltages
BIOS Beep Codes
Annoying isn't it? You have built your computer you switch it on and then nothing happens except a few beeps from the PC speaker. Frustration sets in as you try to figure out what is wrong with it. If you didn't already know the computer has already told you the problem. It can't speak of course but it can direct you to the problem. Its all in the beeps. The BIOS can recognise when the problem occurs and sends a signal out to send a certain amount of beeps through the speaker. These beeps then tell you the location of the problem.
Unfortunately not all the BIOS' use the same codes as each other. Two of the main BIOS manufactures AMI and Award (now Phoenix) have different codes for there errors.
AMI BIOS
# of Beeps Error Description
1 Refresh Failure The memory refresh Circuitry is faulty
2 Parity Error Parity error in the Base (1st 64K) of memory
3 64K Base Memory Error Memory error in the base memory (1st 64K)
4 Timer Not Operational Timer 1 is not functioning (also caused by error in base memory)
5 Processor Error CPU error
6 8042 Gate A20 Failure Unable to switch to protected mode
7 Processor Exception Interrupt error The CPU on the CPU card generated an interrupt error
8 Display Memory Read/Write Error Video adapter is missing, incorrectly seated or has faulty memory
9 ROM checksum error The ROM checksum does not match that of the BIOS
10 Coms Shutdown Register Read/Write The shutdown register for coms RAM has failed
11 Cache Memory Bad The cache memory test has failed. Cache memory will be disabled. *** DO NOT enable it ***
With the first 3 beep codes, its well worth re-seating the memory just to make sure that it's in correctly. 8 Beeps is probably the most common in my experience. Can be caused by a badly seated Graphics card. If you have re-seated it then check with another Graphics card in the board.
Always check for loose components before sending the board back as this is the main cause of errors on the POST.
Award BIOS
Award states that they now only use one beep from there BIOS. This beep is one long beep and then two short beeps. This indicates a graphics card problem. Any other beeps should be treated as a RAM problem first and then the board sent in to be inspected.
The reason that the Award BIOS only uses the beep code for display problems is that it tries to display the error on-screen if at all possible. If the BIOS cannot initiate the display adapter then this causes the BIOS to make the beep code for a display error, which must be corrected before any other errors can be determined. Memory Test fails and hard disk failures etc will all be displayed on screen
IBM BIOS
The IBM BIOS works with Short and Long beeps as well as the Award BIOS. However the IBM one does still have codes to work from.
Beep Code Error
1 Short Beep Normal POST, System booted OK
2 Short Beeps POST Error - Code on Display
No Beep Power supply or Motherboard error
Continuous Beep Power supply or Motherboard error
Repeating short beeps Power supply or Motherboard error
1 short, 1 long beep System board error
1 long, 2 short beeps Display adapter error (MDA/CGA)
1 long, 3 short beeps Display adapter error (EGA/VGA)
3 long beeps 3270 keyboard card
Phoenix BIOS
The Phoenix BIOS works on a slightly more complicated manor than the others. It does display an error code for you and produce a series of beeps. This BIOS produces its beeps according to the hexadecimal code the error produces. The Phoenix BIOS has many different codes for its possible errors and so many different beep codes. Rather than list the entire section here, I have provided a link to the official PDF file containing the codes and how they are derived.
Phoenix BIOS Post Codes
System board errors should be looked at by a specialist, Again always try to re-seat components to ensure they are in correctly. If necessary take all components out except for the RAM CPU and graphics card, then try the system. Re-seating components is the number one fix for getting past the POST screen. One badly seated components can cause the entire system not to function. so pick out your bios and follow the steps above to diagnose .hope this helps
Jan 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
eMachines Acer 350-21g16i Netbook Logo
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
