Cars & Trucks Logo
Anonymous Posted on Jul 13, 2013
1989 toyota sr5 transmission
Truck has the v6 in it. Transmission is soaked with fluid and it doesn't want to move in fwd gear, but moves fine in reverse. Fluid was topped off. It has the automatic tranny. Think it's a 3vze.takes a lot of revs to move fwd.
A
Anonymous
I would say if you have a lot of oil everywhere you have some kind of source where the oil is coming from power wash area and check where this oil is coming from repair as needed or may require total rebuild
5 Related Answers
Anonymous
  • 106 Answers
  • Posted on Jan 16, 2009
SOURCE: landcruiser auto transmission,,how to check fluid level
when you open your hood look in the back of the motor on the left side.. you should see a stick with a circle on the end of it for your finger have you vehicle running warmed up that means let it run for 10 or 15 min. and then pull the stick out.. wipe it off real good. stick it back in all the way.. pull it back out and hold it horizontally and check it.. it's sometimes hard to read because it has bubbles on it.. try it a couple of times to get an accurate reading good-luck ray
Anonymous
  • 140 Answers
  • Posted on Jan 23, 2009
SOURCE: 2001 toyota Prerun/tacoma automatic transmission engages slowly
Change the filter.
Kelly C Bundy II
  • 161 Answers
  • Posted on Jun 11, 2009
SOURCE: Overdrive light is flashing and tranny is slipping in drive and 2nd
my overdrive light is flashing due to a shattered speedo cable tip. check your fluid level. you may have to change the tranny filer and redo all the fluid.
Anonymous
  • Posted on Jan 16, 2011
SOURCE: vault on automatic gear box on toyota estima enima
2.2td estima enima,the auto gearbox stopt change gear from 3 to 4,can somebody help me please?
Anonymous
  • Posted on Sep 07, 2012
SOURCE: Transmission issue - almost no reverse & clacking
I've got exactly the same problem in '93 Camry w/5SFE automatic w/248,000mi. Transmission shop I trust told me ****** was gone. Another mechanic said the same. I'll drive it 'til the forward gears stop working. Forward L,2,D work great, except downshifting doesn't slow the car at all, although the engine goes to idle.
Let me know if there is any easy fix! Already did a fluid & filter change. . . .results no change. Thanks, cc
2002 Toyota Highlander transmission shifter shifts freely without engaging transmission.
1988 Toyota 5 speed manual w series transmission will only engage 4th gear. Why
Did you check the transmission fluid level? if it is OK, then you need to have a transmission specialist look into this.
My 94 Toyota celiac stars up but when I put in gear it won't move
Most possible ur transmission clutch r out.. if transmission fluid too low n u run it for sometimes the internal pump n the torque converter will damage too..
06 chevy equinox transmission, put in drive, speedo says 5 to 10 mph but the truck does not move, put in park but truck still rolls, is it transfer case problem because if transmission is in gear, speedo...
You need to adjust the 4x4 shifter itself. That's your only problem. Moving the shifter isn't putting the transfer case into gear and speedo will move, whirring sound is just the bearings spinning. Re-set the 4x4 shifter linkage to proper specs.
1helpful
Have an 05 cobalt with 110,000 mile. Car only moves while in reverse. When in drive or any other gear, the gear does nothing. I can move the shifter freely, but like I said. Unless in reverse, it...
CHECK TRANSMISSION FLUID LEVEL.IF OKAY.IF YOU HAVE NOT ALREADY DONE YET TRANSMISSION FLUID AND FILTER CHANGE IS DUE AT 100000 MILES.IF ALL IS GOOD YOU COULD HAVE FAULTY TRANSMISSION RANGE SWITCH.HAVE TRANSMISSION CODE SCAN FOR TRANSMISSION FAULT CODES.
5helpful
4answers
I put my truck in gear and i move no where. I can get into gear just as normal as when the truck did run. The rpm gets really high and i move nowhere.
This could be a clogged Transmission filter, bad torque converter, bad solenoid, disconnected shifting lever (not likely if you can put in park). If it's a standard it's most likely something you can fix on your own. If it's an automatic your most likely going to need to a service shop to do the rebuild.
2helpful
I have a 89 toyota pickup 4 speed. When I'm stopped at a stop light, and let out on the clutch it seems like it has lost pressure. When I'm shifting down the road it shifts fine. I checked the fluid and it...
this sounds like the clutch slave is goin out, this unit is on the outside of the transmission. Possibly losing pressure!! Your transmission does not use transmission fluid, but instead gear oil. Have the following checked:
1. Clutch Slave (possibly worn)-this will cause soft or hard clutch pedal feel, slipping clutch, unintended clutch release, hard gear engagement, no/insufficient clutch movement.
*2. Clutch pedal Mounting Plate (possibly cracked)-this will cause improper gear engagement, hard gear engagement, soft pedal feel, insufficient clutch movement.
*this plate is located above the clutch pedal itself, apply pressure on the pedal with one hand while inspecting the plate for fatigue cracks(use a bright flashlight). This is very common on these models. This problem will eventually get worst and most mechanics never figure this out.
more questions email me at [email protected]!!
Bronco II: automatic Transmission slow to shift gears
replace the torque converter or try to get the transmission flushed first by a professional auto trans outfit
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
