Question about Car Audio & Video
Boss amplifier I need the wiring diagram for a boss car amp model BA-4300 1200 watts
informatica
  • 1114 Answers
SOURCE: Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 14, 2007
  • 631 Answers
SOURCE: boss chaos 150 200 watt that shows light but doesn't produce sound
If this is the CH150, it's not bridgeable. Try connecting it normally (one speaker per channel) to see if it will produce output.
Posted on Dec 05, 2007
  • 4 Answers
SOURCE: wiring up amp/installing amp
Disconnect all the wires and make sure that their all connected to the right terminals. If not positively sure trace all wires back to source. If you ground and power is swapped it will automatically go over to protection mode.
Posted on Apr 05, 2008
SOURCE: wiring diagram
i have a hifonics amp brutus 1200 i need the diagram of the outputs inside how they go
Posted on May 08, 2008
  • 8 Answers
SOURCE: Pioneer GM-7200M 800 Watts Mono Amplifier
you Amp is overloading and going into protection mode. if it cuts out with the wire u were using first then their would be no need to upgrade the size of ur wire cause that would only be, doubling or trippling the power u are getting threw those wire now. bottom line the 2 subs u are using are obviously to much for the amp. try dropping the OHM's by connection the subs together and runnig just a single positive and negative to the amp! or just get a better amp
Posted on Jun 10, 2009
What's the watts for a boss audio systems BA-1200
Here is the manual with all the specs for the BASS1200 10" Low Profile Amplified Subwoofer
http://www.bossaudio.com/manual/index.php?dir=&file=BASS1200_EN_UM.PDF
Sep 16, 2015 | Boss Car Audio & Video
Does this boss chaos c550 amp match up to perform correctly with 2 12inch kenwood peak power 600 watt magnet 500g (17.6)oz impedence 4 ohm kfc-w300s speakers
It's not bad, but at 400 watts, it's a bit underpowered
It'll be plenty loud, but the amp will distort before the speakers do, particularly if your subs are wired in parallel (as dual-driver boxes are typically wired)
Listen for distortion, and turn it down a bit if the sound gets fuzzy or static-y sounding
Feb 03, 2010 | Boss C550 Car Audio Amplifier
Hi looking for a manual for a boss ba-1000 car amp
You can contact boss electronics or the amp retail store.. Most boss amps are sold at flea markets so they may not have direct access to the Manufacture. look at your amp and see if there is an 800 on it if not contact the place you bouht it for a phone #
Nov 02, 2009 | Car Audio & Video
Why would i spend a 100 to 120 dollars on a car amp?
any amp will work with any speaker, you just need to make sure it is a mono amp if you are running 1 speaker and a stereo amp wither 2 or 4 channel if you are running 2 or 4 speakers, the ohm rating on the amp should match the speakers also, on the back of the speaker it has the ohm rating, most will be 8 ohm, but you still find some 4 ohm, depending on the speaker if it has a lot of throw (the in and out movement) you may want a higher wattage amp so you get clean sound, it is up to you.... if you are installing lower price amps to you may hear engine wine or noise while car is running so a grounde loop isolator installed on the system will remedy that... also with the amp the directions will tell you the ohm rating of the wire to use, follow that.... and keep the ground short and clean where ever you put it.. try not to go directly off the battery cause you will get a lot of noise... hope this helps..
Jun 23, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
SHOULD I GO AHEAD AND BUY A 400 WATT AMP?
All amps aren't created equal. More exspense amps put out "cleaner" power. You need to know what the RMS power rating is for the amp at 8 ohms and 4 ohms. Also, is the speaker an 8 or 4 ohm speaker? How you wire a speaker or speakers (series or paralell) can change the ohms (resistence) which will change the power put out of the amp. Also, I'm assuming you are setting it up in mono?
Jun 22, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
Circuit diagram of 1400 watt woofer amplifier
www.the12volt.com/ subwoofer wiring diagrams and then find out what ohm of sub u have and how many voice coils and what ohm your amp is stable at.
Jun 10, 2009 | Beyma WOOFER, 1400 WTS, 18" => Model...
Blown amp, on circuit board, connecting fuse and power connect.
These amplifiers dont employ reverse polarity protection that most higher priced ones do.
The amplifier(s) are definately in need of repair - probably power supply - IF boss sells parts.
Chances are, however, the repair will meet or exceed the cost of a new (appropriately rated) entry level amplifier.
Just about anything can be repaired.... question is, are you willing to pay?
Jan 14, 2009 | Kenwood KAC-X501F Car Audio Amplifier
Boss 3500 Watt Monoblock Amp stops putting out signal
What's the battery voltage across the B+ and ground terminals of the amp when the engine is running?
Does the amp go into protect mode when the engine is running?
Are you sure the head unit is still producing output when the engine is running?
Apr 09, 2008 | Car Audio & Video
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
