Question about Xerox DocuPrint M750 InkJet Printer
Printer problem the printer is hooked properly...new inks...but when i start printing...the paper will come out blank/empty...the paper will go through the printer but nothing is printed....
    Sergeant:
  • 279 Answers
This may sound silly, but I've seen it done many times. When you installed the new ink cartridges, did you take the little piece of tape off the printhead? It's put there to prevent leaks, but it also prevents printing if it's not removed.
Posted on Aug 28, 2007
SOURCE:
Nothing at all printing or copying, just blank pages
hi and welcome to fixya
Your printers ink Carthage is empty ! making noise of printing and blank pages is because of the empty cartage bring a new cartage and then printer will print the pages
Dec 07, 2012 | Epson Stylus Photo RX520/RX530
My printer light is flashing and I am unable to print
Could be several options
First shut off and disconnect printer from pc and reboot without printer hooked up
once reboot hook it back up and turn on to see if windows found new hardware.check paper and ink
All else fails re-load printer driver
Jun 22, 2011 | Lexmark X1240 All-In-One InkJet Printer
My printer is only printer blank pages? When it prints, it runs the paper through at a rate as if it was actually putting ink onto it but than the paper just comes out blank. Help!
Check the ink cartridges for ink level - it might just be empty. If you've replaced them with new cartridges already, clean the print heads with a "Q" tip and alcohol and run the "clean-cartridge" function in the printers properties.
Nov 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Blank page
printer not print test page properly. sheet is coming out sppdly
Dec 20, 2009 | HP LaserJet 1010 Printer
Not printing
When a printer goes through the motions of printing bt delivers a blank paper, it is indicative of blocked nuzzles. Ink may be new, but their nuzzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it the nuzzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nuzzle is blocked. To be very sure of this, place nuzzle in a place/saucer with a bit water so that the nuzzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nuzzles, the procedure may be repeated over to get results.
Dec 06, 2009 | Epson Stylus DX8400 All-In-One InkJet...
The printer prints but the paper is blank
I uninstalled the printer and reinstalled the software (from the beginning) and it worked. I did not install the software for including the CD/DVD printing.
Dec 03, 2009 | Epson Office Equipment & Supplies
Canon i965 prints blank pages
Yes those printheads do go bad, they burn out just like a light bulb. If you emptied cartridges then the purge/cleaning assembly is working properly, and the only other option is the expensive printhead.
Aug 20, 2009 | Office Equipment & Supplies
Lexmark 1270
Could be your INK cartrage'is empty.or just cloged clean .it
hope that help you
Oct 28, 2008 | Office Equipment & Supplies
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Hp d2360
Uhm, it usually happens when your print cartridge is empty.
Nov 05, 2007 | HP Deskjet D2360 InkJet Printer
Xerox DocuPrint M750 InkJet Printer Logo
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
