Question about Kitchen Ranges
ALUMINIUM Does this product has aluminum? My doctor recommends that I change my cookware to stainless steel so that I can avoid aluminum
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
What is "this product"?
Posted on Jul 13, 2013
5 Suggested Answers
DeBruce
  • 145 Answers
SOURCE: cleaning top of gas range
Use DeBruce Polish I guarantee results go to debrucepolish.com
Posted on Mar 07, 2009
  • 59 Answers
SOURCE: Buying new cookware and need to know if Stainless steel will scratch the surface of smooth top.
stay with what you have been using. rachael ray has a unike design. try it.
Posted on May 23, 2009
SOURCE: Stainless Steel Range Tops.
The only way to clean it is with steel wool. I use 2 different grades, but finish with a fine grit-0000. You still can't get it completely clean, no matter what you do. Forget it looking new. It's not real stainless steel if it's model FEF455BBA. I won't EVER buy this sort of top again either. I have had numerous problems with it, including since it conducts heat and doesn't shield wiring from the heat generated by the eyes, it is constantly melting out the plug-in elements for the eyes. I am surprised it hasn't been recalled. I am surprised more people haven't had fires!
Posted on Jul 20, 2010
  • 83 Answers
SOURCE: Dacor Epicure ER48D Stainless Steel Gas Kitchen
go to this website for your reviews and ratings www.retrevo.com
Posted on Sep 17, 2010
What are the advantages of using aluminum oven cookwares?
The major advantages of using Aluminium oven cookwares are mentioned below:
a. Lightly weighted
b. Larger sized legs.
c. Safe dishwasher.
d. Delicious food.
e. Great versatility, etc.
You can visit this link, to get best deals on these aluminum cookwares of best brand.
Jul 03, 2017 | Kitchen Ranges
No matter what pot we use, it wont work
Most cookware found found in home today is aluminum or cast aluminum. These do not work on induction cook tops. Even older stainless steel Farberware doesn't work because it is not magnetic. Look for an induction compatible label or stamp on the cookware to be sure.
Induction cookware must be made of a magnetic-based material, such as cast iron or magnetic stainless steel. Fully clad cookware brands, such as All-Clad Stainless, Le Creuset Stainless Steel and Mauviel M'cooks stainless work on induction cooktops because they're magnetic.
Mar 15, 2015 | Eurodib Induction Cooker
If induction cooker does not heat the pot
Induction-compatible cookware contains contains iron or has a layer with magnetic properties. Cast iron, enamel cast iron and most types of stainless steel cookware are all induction compatible (But not all types; for instance, All-Clad's MC2 line, which is made of aluminum and stainless steel, is not induction compatible)
Nov 25, 2014 | Winco Professional Induction Cooker -...
Pressure cooker is not heated on induction cooker
Likely the pressure cooker base is not induction-compatible. This is the case with all aluminum pressure cookers and some older stainless steel models. Your cookware store will have a small metal plate that you can put on your induction burner to heat non-induction compatible cookware.
Nov 10, 2013 | Home
Which is the best material for kitchen utensils?
I believe it is widely agreed that aluminium is the best and most common material for kitchen utensils. It doesn't weight as much as copper, it's easier to clean, and it's very resistant to both substances and falls
Jul 16, 2013 | Home
Aluminum pans come out stained with a dark residue.
The aluminium reacts with the solution being used. Change the detergent making sure it can be used with aluminium.
Oct 09, 2010 | Maytag MDBH975AWS Stainless Steel...
I have a new induction cook top. When using for the first time I found an F or P appeared next to the element I was using. I have bought stainless steel cookware specifically to use. The user manual...
Stainless steel (or Aluminium) cookware will not normally work with an Induction cooker: Induction cooker need cookware that have a certain amount of metal especially at the bottom of the pot or pan.
An easy way to check if the cookware is suitable is to use a small (fridge) magnet: if it stick to the pot/pan then it is very likely that the pot/pan is suitable for induction 'magnetic' cooking!
Hope my small hint is of assistance and if so, vote accordigly!
Oct 03, 2010 | Westinghouse Microwave Ovens
How to remove scratches from stainless steel appliances
Try this at your own risk. Step 1 Consider using a product made for stainless steel2_bing.gif such as Scratch-B-Gone or Bar Keepers Friend (see Tips).
  • Step 2 Or, try spraying an all-purpose cleaner (such as Formula 4092_bing.gif) on the scratches.
  • Step 3 Use a non-metal scouring pad (such as Scotch-Brite pads) to rub the cleaner in, always rubbing in the direction of the grain.
  • Step 4 Keep the stainless steel wet with the cleaner as you work, and rinse the pad often.
  • Step 5 Rinse the surface and wipe dry.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Tips & Warnings
    • Before using any treatment on your stainless cookware, sink or appliances, it is wise to call the manufacturer for advice.
    • A new product called Scratch-B-Gone is touted as the "first aid kit for stainless steel." You can find it at many home improvement stores.
    • Bar Keepers Friend is another product for stainless steel. It can be found in most grocery or home improvement stores, or at www.barkeepersfriend.com.
    • To keep stainless steel sinks from scratching, put a rubber mat in the bottom of the sink to protect it.
    • Avoid using abrasive
    Please rate 4 thumbs for the free answer
    Mar 13, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    May 23, 2009 | Kitchen Ranges
    Kitchen Ranges Logo
    22 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
