Asus VE276Q monitor stuck in Display mode
I have a Asus VE276Q monitor which was working fine. I selected the display option from menu shows no signal. Now I can not bring up menu to revert back to DVI setting. I just get a black screen. Can you help please.
  • 86 Answers
SOURCE: check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Posted on Mar 31, 2007
Bogdan
  • 198 Answers
SOURCE: Acer AL1916W 19" problem
Hello mat78, Unfortunatelly the problem is hardware based. You will need to have the monitor repaired in a service center. Here's why: LCD/TFT monitors don't produce light themselves. They are composed by a matrix of transistors (TFT - thin film transistor) that have the property to reflect or allow some light (certain wavelenghts)to pass through them. They don't produce light by themselves. Instead there is a fluorescent tube (neon like) light inside the monitor and that's the light source used in order for you to see what's on the screen. A flourescent light is suposed to last pretty much, i don't think yours has a problem, you say it works for some seconds or so. Instead your problem is most probable with the inverter circuitry that powers on that light. It's a common problem among these types of monitors but in your situation i don't think it will be an expensive repair. In the case that the screen is dark (in a dark place you can't read or view anything on it) but if you apply light to it ( a flashlight or something) and you see something, then the problem is most likely to have occured with the invertor. Try to ask at a local service center for a repair, this shouldn't be an expensive procedure. Hope this helps.
Posted on May 24, 2007
  • 300 Answers
SOURCE: "No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Posted on Sep 14, 2008
  • 13433 Answers
SOURCE: Power Saving Mode problem using the DVI input. VGA input Ok.
try the display on another computer, if the display does the same thing on another machine, then its definitely a problem in the display not in the computer drivers or bios.
Posted on Sep 21, 2008
noone
  • 105 Answers
SOURCE: Display stuck at 640x480 16-bit after a reformat
You need the driver for the video. The default driver will just do minimum resolution.
Posted on Dec 16, 2008
PS3 asus mx279h hdmi black screen
When you turn on the PS3 hold the power button and it should do a couple of beeps this means it has reset the video output and should work :)
Jan 11, 2014 | ASUS Computers & Internet
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Tip
Siemens MODELS CODES & DESCRIPTIONS
*#0003*(secret code 8 digits)# All Siemens Phones: Service Provider Unlock
Siemens S25/C25
SP unlock *#0003*(secret code 8 digits)#
Show IMEI code: * # 06 #
Resets language to automatic selection : * # 0000 # then Green button
Pin Out
Data Cable schematics
Phone's connector pin-out:
1- GND
2- SB
3- POWER
4- NC
5- TX
6- RX
7- CLOCK
8- DATA
9- GND MIC
10- HF MIC
11- AUDIO
12- GND AUDIO
Siemens S1/S3/S3 Com
To view the software date and else with S3 com, S4, S4Power, Sony cmdx 1000e press with SIM removed *#06# and left softkey.
To view some other stuff with S4Power, Sony cmdx 1000e press with SIM removed *#06# and left softkey twice.
To view the software date with S3 com, S4, S4Power, Sony cmdx 1000e press with SIM installed menu 98 and left softkey twice.
ACTIVATE MONITOR MODE
Siemens S1/S3
Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 5553756, Hang-Up Button (Red Handset key)
Siemens S3 COM/S4
Menu, 9 (Phone Options), 7 (Phone Status - 8 on Some), Left Display Button (left MENU key), 7684666, Hang-Up Button (Red Handset key)
Note: Now Monitor should appear at the bottom of the Network Options menu.
MONITOR MODE
Pressing the right Display Button when in monitor mode will toggle into 1 and 2 modes
Pressing the right Display Button when in monitor mode will show a list of the six cells with the strongest signals.
Test Mode Indicators: (* = only available when call in progress )
CH Channel Number
RX Signal Strength (dB)
N NCC (Colour Code)
B BCC (Colour Code)
CI Cell ID (in Hex)
C1+ How long before phone does forced hand over. (see RX and RXAM)
LAI Location Area Identity. Display Network ID code (42F010 = 240.01) and MSC
TXPWR Transmit Power (dB)
RXAM Receive signal strength cut-off point
TS* Time Slot Number
TA* Timing Advance. Distance from tower in Km X 2
PL* Power Level
POWER table
PL: 5 6 7 8 9 10 11 12 13 14 15
dB: 33 31 29 27 25 23 21 19 17 15 13
Watts: 2 1.3 .8 .5 .3 .2 .13 .08 .05 .03 .02
LF* C1 value with continuous transmission from tower
LS* C1 Value with discontinuous transmission from tower
QF* Bit Error Rate with continuous transmission from tower
QS* Bit Error Rate with discontinuous transmission from tower
BER (bit error rate) table
QF/QS register: 0 1 2 3 4 5 6 7
% of bit sent: 0.2 0.8 0.4 1.6 3.2 6.4 12.8 25.6
Siemens S1/S3
Here's a trick to play Tetris, also known as Klotz on a Siemens S1.
Turn the phone on. Enter PIN. Before the telephone has logged in to the your GSM net do the following steps.
1: Choose F 9 (function settings)
2: Choose send own number and push the right button for choose.
3: Push 9
USE 2 as < and 8 as > , rotate the klotz with 5 and drop with 4.
[I have just heard from one of the programmers of the phone that Tetris was in the phone during development, but it was removed before it was produced. Apparently someone has the patent on games in mobile phones and Siemens didn't want to pay the licensing fees. It was either in Menu F-9-9 or it's not there at all.]
Siemens S3 Comfort
MONITOR MODE
The Siemens S3 Com series have a Monitor mode that can be activated directly from the standard user keypad. In order to activate this mode, you must enter the special access code currently programmed into the phone.
TO ACTIVATE MONITOR MODE:
Turn the phone on.
Enter the PIN access code on press OK. (Only if is enabled).
Press Menu. (Left top button).
Press 9. (Phone Options).
Press 8. (Phone Status) (May be button 7 in some phones).
You may see your IMEI Number
Left Display Button (Top left MENU key).
7684666
Hang-Up Button. (Red Handset key).
Note: Monitor should appear now at the bottom of the Network Options menu.
MONITOR MODE
Siemens S4/S4 Power
In phonebook under "Own Phone No." enter +12022243121 (which is the number to the White House) and you'll get a greeting from the people who programmed the phone.
MONITOR MODE
The Siemens S4 series have a Monitor mode that can be activated directly from the standard user keypad. In order to activate this mode, you must enter the special access code currently programmed into the phone.
Menu, 9 (Phone Options), 7 (Phone Status), Left Display Button (left MENU key), 7684666, Hang-Up Button (Red Handset key)
Now "Monitor" should appear at the bottom of the Network Options menu.
CH Channel Number
N NCC (Color Code)
B BCC (Color Code)
CI Cell ID (in Hex)
C1+ how long before phone does forced hand over. (see RX and RXAM)
RXAM Reeceive signal strength cut-off point
PL* Power Level
Power Table
Siemens S6/S10
In Phonebook, store as your own number: +12022243121
Then you get the sun and two palms in the display, also a greeting message of the "MMI-team".
It has been said that the phone number is the number of the Capitol building in Washington, DC (but not sure).
Siemens S15 Secret Menu's
Press * -> # -> 7 -> 4 -> 3 -> 6 -> 3 -> 6 -> 7 -> * -> 8 -> 3 ->
7 -> 8 -> # ,press clear key to clear screen and return to
stand-by mode
press Menu, it will show additional menu
Menu 3.3.4 Band selection,
Menu 3.3.4.1 Automatic band selection,
Menu 3.3.4.2 select GSM 900 only,
Menu 3.3.4.3 select GSM 1800 only,
Menu 10 Engineering,
Menu 10.1 MS info,
Menu 10.2 software detail,
Menu 10.2.1 software version,
Menu 10.2.2 EEPROM version,
Menu 10.3 Test/production details
Menu 10.3.1 Hardware deta
Menu 10.3.2 production deta
Menu 10.3.3 Service deta
Menu 10.3.4 Mechanical deta
Menu 10.1.1 MS info on, then on the screen show these, for example:
FCN RXL C1 C2
642 011+11+91 -> PAGE 1
CID DSC CB
11211 045 000 -> PAGE 2
BCC NCC TN
000 002 00 -> PAGE 3
RXf RXs RQf RQs
00 00 00 00 -> PAGE 4
ATa APa Hn Hf
001 000 05 00 -> PAGE 5
DTU DTD HP CI
+ ? - - -> PAGE 6
MM CC RR
IdNS Nul Idl -> PAGE 7
on Aug 30, 2009 | Nokia 9500 Communicator
Asus vh202-t cycles through display modes randomly and not responsive WHY?
sounds like the button is stuck. I would 'hammer' the mode selector button; attempting to free it of debris...
Apr 07, 2012 | ASUS VH202T Monitor
My brother was messinng with the resolution settings and now the screen is stuck at imput not selected aand ive tried restarting it and making sure the cables are tight
Clarify me your monitor to post you back the correct settings.
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 22, 2010 | Computers & Internet
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
LG LCD Monitor won't exit Power Saving Mode
Does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your LG monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PCs video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG Computers & Internet
I have purchased a Asus en6200le card for dual monitors at work. I have also purchased the correct DVI-I to VGA adapter so i can run 2 vga monitors, but i still cannot get the second monitor to show how...
Right-click the desktop, and then click Properties.
In the DisplayProperties dialog box, click the Settings tab.
Click the Display list and select your external monitor. If you do not see multiple monitors listed, your computer hardware may not support Dualview. You can still use MaxiVista to configure a second computer as an additional display, however.
Select the Extend my Windows desktop onto this monitor option. Click Apply or OK
Jul 17, 2009 | ASUS EN6200LE/TC256/TD GeForceĀ® 6200LE,...
Need to change vidio mode to display input to 1024-768 @60hz to use my new monitor dell 2400 diminsion and acer monitor please help me''
go to control panel. look for personalize or display menu. select display settings and change your resolution and apply. then go to advance settings and see if set to 60 hz
Apr 24, 2009 | Dell Dimension 2400 PC Desktop
Remote display/monitor
First try to reinstal the monitor display driver. Failing that working I would next borrow a monitor to see it it works. That wil tell you if it is a monitor or video card  problem.
May 22, 2008 | ASUS VW193T Monitor
Computers & Internet Logo
David Payne
David Payne
