Question about Umi JXD S602 4.3 Inch Game Tablet PC Android 4.0 HDMI Camera White
Jxd s602 I JUST BOUGHT A JXD S602 FOR MY SON. AFTER AN HOUR THE SCREEN WENT BLANK (WHITE). I HAVE TRIED TO RESET IT BUT IT STILL DOES NOT WORK. WHAT CAN I DO TO FIX IT?
My Kindle went blank with almost a white screen tho fully charged and now wont turn on at all. Have followed Amazon's suggestions but nothing works. Can you help?
Chances are your screen went defunct. Or it could be a problem with some other piece of hardware. You can try using the USB cord to plug it into the USB port on a laptop or desktop and see if the computer can read the files. If it can display and explore folders and files, chances are it's the screen (display) that went south. It it can't display and read folders and files chances are it's the memory or some other internal hardware that died. Sadly these things are cheaper to replace than to repair. I have a Kindle II with a faded out display. It works but the text is so light that it's barely readable so I retired it. I have a Kindle Touch that I dropped and the screen broke so I ended up getting a Kindle Paper White and I like it the best of them all.
Apr 22, 2015 | Amazon Kindle 1
My sumsung galaxy tab 4 just went blank n showing some white lines it's about fours hours
If resetting does not fix it, I'd hazard a guess there might be damage to the screen itself.
Feb 08, 2015 | Tablets & eReaders
My son tried a memory card on his and the screen went blank
press the reset beside the usb port its tiny will need a toothpick.
as he likely inserted it with it turned on he might have blown it.
May 19, 2014 | Visual Land Connect 7" Tablet
Archos arnova refurbished 7k G3 tablet frozen on ARNOVA screen
i had same problem with my gadget,i replaced the battery.and have it checked to make sure no reformattingg needed
Feb 04, 2014 | Archos Tablets & eReaders
Tablet wont turn on
Most tablets can be reset by holding down the power key for a period of time 15 secs 30 secs etc. power on and then hold down the power key to see if it resets the device?
Dec 06, 2013 | Polaroid Tablets & eReaders
How can i remove username and password from tablet jxd s6600
Tap 'Applications' to open the main apps menu and then tap 'Settings'. You may need to sweep with your finger to a new screen of shortcut icons before you can see 'Settings'.
Tap 'Location and security' then tap 'Set screen lock'. Next tap 'PIN' to set up a pin number for the lock screen.
here you can set and reset your password
Aug 09, 2013 | shop-fun JXD S6600 7 inch Android 4.0 All...
Just a blank white screen
My sons tablet was doing the same thing I discovered it was because he had a damaged memory card try a new one
Feb 26, 2013 | Tablets & eReaders
Umi JXD S602 4.3 Inch Game Tablet PC Android 4.0 HDMI Camera White Logo
27 people viewed this question
Top Umi Tablets & eReaders Experts
Are you an Umi Tablet and eReader Expert? Answer questions, earn points and help others
