Question about Kitchen Ranges
Oven not working
On 8/24/7 went to preheat oven, notice that display kept blinking on and off along with a clicking noise, oven did eventually heat up it took it awhile. as of 8/26 oven does not work at all timer display is just blank.But the top of the stove top works just fine. called GE they said that it probally need resetting or the breaker or fuse has tripped. unplugged for awhile, still got same problem. checked the breaker it's ok. please help
  • 34 more comments
  • Icalciano Nov 12, 2007
    sounds simular to my problem, how do you check the connections etc.
  • Chazwel Nov 19, 2007
    Same problem, stovetop works but oven does not. Opened up the back to look for a fuse, the only thing I can find is a black round looking thing with 2 black wires connected to it, is this the fuse? Check all connections, they are tight and nothing looks burnt up. Any ideas?
  • Anonymous Nov 20, 2007
    i opened the door of the oven and let it cool down .
  • Anonymous Nov 26, 2007
    no power on display tried resetting breaker
  • notacook Nov 28, 2007
    The oven quit working, burners and broiler were ok though. When plugged in and not in use, unit "beeps" and flashes F 6 in digital panel. Service guy came and replaced "Glo-bar" in bottom of oven, and now oven works. However, still beeps when plugged in and not in use. Service guy couldn't fix the beeping.
  • Summer123 Nov 29, 2007
    I have some issues on my Whirlpool electric range. Model RF262LXST. The cooktop works fine but the oven stopped working 5 to 10 minutes after pressing the START button.
    Here is the detail of the issues. Please give me some feedback and advice. Thanks in advance!
    Bake function problem: Turned Bake on, oven became hot, after 5 to 10 minutes, oven display blank or flashing (sometimes with flashing clock time, sometimes just blank)
    Broil function problem: Turned Broil on, then pushed oven light button once, oven display turned off automatically
    I had to turn on one of the cooktop elements to bring the oven display back on. The oven failed again in a few minutes when using Bake or Broil.
  • breadbaker Dec 03, 2007
    I have a GE JBP30 electric range. When I try to turn on the oven, only the top broiler element comes on. The oven "on" light stays on all the time. It also won't display the temperature. Sometimes I can get it to work, but in the middle of baking it will switch to broil and ruin the food.
  • Kim1stove Dec 29, 2007
    Oven flashes F3 error and quits working. Have tried all the troubleshooting suggestions of GE, including turning breaker off and resetting, to no avail.
  • solpapikoy Dec 31, 2007
    I have two problems with my hotpoint gas range. First, the stove top ignitor doesn't work anymore. I can't hear the clicking sound as soon as I turn on the switch. I have to use a match to light a fire.
    Secondly, the oven doesn't work at all. Seems like no gas coming out from the burner. My gas range is only 3 years old and the oven is seldom used. My friend and I tried to fix the problems for hours but were unsuccessful. Is there anything you can help us? ps, we've already turned the fuse on and off and checked all the wirings inside the range.
  • everafter Jan 01, 2008
    top part of oven working but the oven itself is not turning on would like to know what does the fuse breaker look like.
  • charlie machoy Jan 02, 2008
    Same model. Same problem. Sad thing is that my warranty expired only 1 month prior to the problem. My wife was cooking a ham for Christmas dinner when she noticed that the oven performance was not as usual. A few days later we noticed that the display was blank and the oven not working. However, the stove top still works. I unplugged the stove and tripped the circuit breaker a couple of times without success.
  • MickdaMan Jan 28, 2008
    Mine is like the other person with PF error. It beeps loudly and will not stop until I unplug it and let it sit a bit. No help when i called frigidare
  • Brownie00 Feb 26, 2008
    My stovetop works fine, but oven will stop working after a while. I have to turn on a burner on the stovetop for gas to start coming out for the oven again. There are no error codes. What the heck?
  • Anonymous Mar 07, 2008
    The oven will heat up initially, sometimes it stays on, sometimes when the oven "clicks" to cycle the burners to light, it just keeps clicking without lighting. Other times it cooks fine. It seems to happen more often when baking at longer lengths. Could it be the igniter or maybe the thermostat?
  • Anonymous Mar 09, 2008
    Had the oven on convect and accidently hit the cancel button. Now nothing on the left side (8 buttons work). Timers and cook top work but no set up, oven, convect or anything else. Range is 1 yr and 4 mo old.
  • Anonymous Mar 15, 2008
    when ever I press bake or broil it says F90 and it locks me out
    what are the sequence codes?
  • firefight222 Mar 17, 2008
    where can you buy the controller Thats all i need. I have the part # but cant find anyone that distributes them.
  • shel333 Mar 25, 2008
    had the same problem.........stove top works but oven hasn't worked at all. All the displays......."bake,broil,clock,ect. don't light up or go on. PLease help.
  • cold dinners Mar 27, 2008
    Oven takes over an hour to warm up to just 285 degrees. Finally gave up. Called Sear's repairman where unit was purchased from. He came out 3 days later, examined the oven, he then called Jenn-Air tech support. They determined that the sensor and board had gone...only after 3 years (no longer under Sears warranty). I paid the price, parts came in that week, after 3 weeks and cancellation after cancellation, I hired an electrician who put in the parts. It does the same exact thing it was doing before. I bought parts I did not need, paid a Sear's repairman who never did the installation, hired and electrician to put in the parts and the oven still cycles through and does not warm up. Any suggestions, besides never buying from Sears again?
  • Anonymous Apr 01, 2008
    did u ever get it fix im having same problem
  • runt136 Apr 01, 2008
    please help us
  • lmr997 Apr 09, 2008
    oven does not work. stove top and broiler work. help!
  • spullerchuck Apr 10, 2008
    the bottom element does not come on. I took off the kick panel and found 2 relays called hot point relays. i tap on the relay to the right , notice some sparks and walah!! the bottom element begins to heat up.
    Also grill no longer ignites. Occasionally the glow plug comes on. My model #is ZDP48LG4W2SS   HELP!!!!!
  • Anonymous Apr 15, 2008
    burners work fine however,display light inside oven work
    but top and bottom oven does not work.
    top burners work fine. display light along with top and bottom elements does not work.please help me find a solution
  • MarkMichelle Apr 17, 2008
    Oven just shut off while cooking and left a residue inside the oven. I can wipe it clean but wondering why this happened. The display went blank. After, my husband reset the breaker it restarted again, but I am afraid to use it until I know what caused this.
  • kpel May 17, 2008
    The bottom element is not working in my oven. I am not getting any error codes. I took it apart and didn't see anything unusual. It makes some clicking noises when it's on, it just doesn't heat up. My only guess is that it's the resistance temperature detector.
  • kheidinger May 21, 2008
    My clock is blank and my oven does not work. The top burners work and flourescent light works but nothing else.
  • jtundervary Jul 07, 2008
    auto on -cannot use oven as this wants me to use timer - pressing manual button - nothing happening - please help
  • breezefrm Jul 08, 2008
    I HAVE THE SAME RANGE IT WAS A BURNED OUR WIRE BEHIND PANEL IN BACK OF STOVE COULD HAVE STARTED A FIRE .
  • Anonymous Jul 18, 2008
    the preheat light will not go on and will not go up to temperature
  • alisteralexa Jul 20, 2008
    I have the same problem with "locked door" blinking.
    How do I access the fuse behind the panne? I already disconnected and
    reconnected the power to no avail. I need to know how to get to the fuse.
    Thanks,
    Alister
  • perrymyers Aug 20, 2008
    I have an Amana AGDS902SS and suddenly while cooking, the controls for the oven part simply went out and I cannot cook with the oven. The led lights for the clock also disappeared however the electronic ignition for the stove tops and oven fax controls are still powered. So it is not a total electrical issue.
  • dfsffsf Nov 24, 2008
    I have a maytag gas oven and i got a guy to put in a new ignition switch and now my bottom and top oven won't work
  • Anonymous Feb 27, 2009
    How much is an ignitor??? my oven keeps showing f2 we just got it in december
  • Anonymous Mar 23, 2014
    stove from 80s plugged it in and buzzing started undid fuse for timer how ever now lower oven does not work need to no how to stop timer
  • 3 Answers
Gas Burner valves use a flame proving circuit to verify that a flame exist before releasing gas to the burners in the oven as a safety precaution, this sensor being exposed to temperature extremes, fails over time.
Posted on Mar 03, 2008
We had the same problems. The oven would preheat to the temperature, then make a clicking noise and go off (either right away, or shortly into the baking time). It had been acting up for months bur finally go to where it would barely even work at all. The clock would blink and was not keeping time well at all either. My husband took out the control module/clock unit and examined it with a magnifying glass. He found over two dozen broken/cracked/faulty solder joints on the board. He was able to re-solder them and everything has been working perfectly. It's like having a new stove again!
Posted on Jul 31, 2008
I have a Whirlpool oven and have had a problem with the oven beeping nonstop for about 4 minutes when it would eventually allow me to turn it off. I've had the oven over a year and teh beeping thing was always an issue. Last week, all at once the oven quit working. This whole thing was solved by having someone come in and replace the ignitor. SO it isn't always the relay board like most think. I was getting error code F2 and it ended up being a faulty ignitor.
Posted on May 16, 2008
  • 45 Answers
It might be you have some faulty components up in the controller. try dismantle the upper part and check for blown up components or loose connected componets and wires. Patrick
Posted on Aug 29, 2007
2 Suggested Answers
panthers85
  • 54 Answers
SOURCE: oven not working
http://www.geappliances.com/search/fast/infobase/10002629.htm Follow the driections here to see if they work I had the same problem and this fixed mine.
Posted on Jul 30, 2008
Top oven doesn't heat properly
What is the model number of the unit?
Dec 03, 2012 | Ovens
Oven not working
Jul 30, 2008 | Jenn-Air PRG3601P Gas Kitchen Range
My Dimension4's convection oven often starts to make grinding noises when it preheats.
From the description it is the turnable motor, eventually it will need to be replaced down the road.
Mar 22, 2012 | Microwave Ovens
I noticed my oven was taking longer and longer to reach the preheat temperatures I was setting. As time went on, the stove was not heating up past 285 and now the temperature never increases but I can...
It is probably as simple as changing the ignitor...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 16, 2010 | Maytag MGR5770 Gas Kitchen Range
Thermador Pro Harmony Range--> Blue Lights Blinking
thermador rang, blue light blinking. Oven is not working,
Oct 03, 2009 | Thermador Pro Harmony PRG304EH (Gas)...
My oven display is beeping and blinking 'PBR' on the display. What does that mean?
I had this same problem last night.. I have been having problems with the oven shutting off on preheat.. That sort of stopped. Last night lost power to the house. When it returned the oven was beeping and flashing PBR. I turned off the breaker for a few mins. last night and it returned. It was bugging me so much that turned it off the whole night. Woke up this morning turned the breaker back on and it stopped. I don't think this is the total solution. I am thinking that eventually I am going to have to replace power board in this oven. Hope it works!
Sep 23, 2009 | Jenn-Air Ovens
Oven not heating KitchenAid KERC506HWH3
This is probably the thermal shuttoff fuse. Usualy mounted in the back of the oven. Aftermarket fuses are resetable but the OEM ones that come with the ovens usualy are not, so when they go out they stay out. This shuttoff only effects the power to the element so the rest of the oven appears to work.
The oven has to come out and remove the rear covers, behind the covers you will see 2 wires that go to a small 1/2 in dia "plug" that mounts directly to the surface with 2 screws.
Remove the connections and put a meter across the cuttout. it should read very close to zero ohms, if not its blown.
Apr 23, 2009 | Frigidaire FEB27T5D Electric Double Oven
Built-in ovens have a thermal fuse mounted in the back of the oven preventing the bake and broil from operating. In some cases this fuse will open after a self clean operation. In some models, the cooling fan turns off too soon, causing an overtemperature condition that may also cause the fuse to open. You will have to remove the oven and take off the back panel to gain access to this device.
May 25, 2008 | Frigidaire PLEB30T8A Electric Double Oven
Sharp Carousel Convection Microwave R-9H56 suddenly stops heating
at highvoltage section wiring may bae problem, check wiring and connectrors of magnetron and capacitor and transformer.
Dec 11, 2007 | Sharp R-510HW Microwave Oven
if this cooker is fitted with a clock check that it is not set to delay start mode(auto) if it is reset clock and this will resolve problem
Jun 13, 2007 | KitchenAid KERC506HBS Electric Kitchen...
Kitchen Ranges Logo
2,747 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
