K1136780 fuse open. new one fix again open
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 81 Answers
Sounds like something went bad in the power supply. I would check all the capacitors to make sure none are raised on top or leaking. If all the caps look good then it could be a bad transformer. A new power supply board should fix it if you don't want to desolder, test and replace components.
Posted on Jul 13, 2013
Power went out last night. I am now getting a flashing H2 code. What should I do?
reset error using simulation mode 14 & 16. this is occur due to fusing thermistor is open. still occur remove fusing unit & clean thermistor using alcohol & reset thermostat. then fix it & again reset error using simulation mode 14 & 16.
still h2 appear replace old one to new 1.
May 24, 2011 | Sharp AR-M205 Copier
My hitachi television refuses to turn on. nothing has changed in the way it's been treated, the light below the hitachi symbol isn't even red it's as if it isn't even connected to the power. what can i...
Hi nycozza,
Here are some basic steps that will help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
You may also replace the power supply board, try online like ebay.com and shojimmy.com.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Feb 21, 2011 | Televison & Video
Why my TV does not turn ?
Assuming that you don't even have a standby light on the led.
Here are some DIY steps that may help you fixing the problem.
  1. Check the power cord - check the cord it might be opened (no continuity).This is due to frequent bending and pulling.
  2. Check the internal fuse - sometimes the fuse fail because of the power surge, replacing with new one cure the problem. However if the fuse blew again then this is an indication that you have a shorted parts on the power supply. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
  3. If the fuse is intact then you have a faulty in the power supply or on the load. You might have an open fusible resistor,open volt regulator ic, shorted H-out IC.
The #3 should be done by an expert or qualified technician because isolating the problem on the regulator section is technical.
But first check if the unit is under warranty then avail it because the manufacturer will fix it for you for free or a little charge only.
Have a nice day!
Jan 27, 2011 | Zenith Z32X31D 32" TV
Sanyo tv with no power
1.Check the power cord - check the cord it might be opened (no continuity).
2.Check the internal fuse - sometimes the fuse fail because of the power surge, replacing with new one cure the problem. However if the fuse blew again then this is an indication that you have a shorted parts on the power supply. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
3.If the fuse is intact then you have a faulty in the power supply or on the load.
The next steps should be done by an expert or qualified technician because isolating the problem on the regulator section is technical.
Jan 26, 2011 | Sanyo Televison & Video
DEAD SUPPLY
2.Check the internal fuse - sometimes the fuse fail because of power surge, replacing with new one cure the problem. However if the fuse blew again then this is an indication that you have a shorted parts on the power supply. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
The next steps should be done by an expert or qualified technician because isolating the problem on the regulator section is technical and fatal.
pls rate my help.
Jan 25, 2011 | Televison & Video
TV will not turn on, there is no light indicating power
Please rate my help.
Jan 19, 2011 | Televison & Video
My tv wont turn on
  2. Check the internal fuse - sometimes the fuse fail because of power surge, replacing with new one cure the problem. However if the fuse blew again then this is an indication that you have a shorted parts on the power supply. If no reaction and still the unit didn
AC compressor will not turn on, and will not blow
open fuse panel under hood and check the AC Comp fuse. If it blows again you may need a new compressor
Apr 10, 2010 | 1999 GMC Suburban
2002 mercury mountaineer power windows not working will not go up
read owners manual to locate pwr window fuse.or open up box and a label diagram should be on bottom of lid or door of fuse box. locate and pull.hold up to light to check or run continuity test.
if new fuse fixes prob, it is most likely going to happen again. then you'll need to isolate window that is problem.(last one used before fuse blows)go from there. GinoR
Mar 22, 2009 | 2002 Mercury Mountaineer
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
