Question about Coby Electronics Corporation Coby Csmp95 2.1 Speaker System - 80 W Rms - Wireless Speakers - Glos
My button on my soundbar does not work only standby button
I just bought it with no remote.only standby button works
    Top Expert:
  • 12,223 Answers
You must claim this to the company where do you buy it. Can be the control be defective. Go and return it for fix it or exchange it.
God bless you
Posted on Jul 13, 2013
My soundbar remote doesn't work volume button switches it off
Check the remote control for its infra-red emission by pressing every button on it. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Mar 05, 2015 | Televison & Video
How do I program the jamo torsten sound bar to my remote control?
Great product, horrible instructions that focused on every language known to man rather than clear steps. Hope this helps....for the JAMO TORSTEN 2 WAY SOUNDBAR W/ WIRELESS 10" SUB 360 Series, as well as other Klipsch soundbars.
If the SoundBar is in STANDBY mode (solid RED status light), push the <SOURCE> button on the SoundBar until the status light is solid GREEN.
STEP ONE (Place the unit in learning mode): With the status light showing solid GREEN, press and hold the <SOURCE> and <MUTE> buttons on the front of the SoundBar at the same time (approximately 3 seconds) until the status light flashes RED and GREEN.
STEP TWO (Select the function to learn): Press the <MUTE> button once on the SoundBar (the status light changes to solid ORANGE).
STEP THREE (Learn the function): Hold your remote control within one foot and pointed at the front of the SoundBar. Slowly press the <MUTE> button on your remote control four times. On the first three presses, the status indicator light will flicker ORANGE with each press. If the unit has successfully learned the function, on the fourth press of the button, the light will flash GREEN several times and then turn to solid GREEN.
To program the remaining functions, simply repeat all steps, substituting <MUTE> with the new function and button presses (VOLUME UP, and VOLUME DOWN) on steps TWO and THREE.
Apr 28, 2014 | Jamo Torsten Soundbar with 10" Wireless...
Yamaha soundbar
Remove the batteries from the remote. Push all the buttons to eliminate a stuck button as a cause. Reinstall the batteries or install new batteries. Disconnect and reconnect the soundbar. Check operation. If the problem remains, you may need to replace the remote
May 24, 2013 | Audio Players & Recorders
Coby csmp95 soundbar
my button on my coby soundbar does not work only standby button
May 03, 2013 | Audio Players & Recorders
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
Need Dish remote code (6.4 IR/UHF) for Vizio VSB200 Soundbar...
There are no codes available for a 6.4 remote on a Vizio Soundbar. Below are the steps to Power Scan the remote control. This will search all codes 1 by 1 until it finds a code that works, or exhausts all available codes.
Power Scan:
1.) With the Soundbar on, press and hold the AUX mode button (about six seconds) on top of the remote until all mode button backlights come on, then release.
2.) Press 2 then press STAR (*)
3.) Press the Up arrow button once a second while pointing the remote at the Soundbar. If the code for the Soundbar comes up, it will power off.
4.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times. To verify the code works try several different functions for that equipment.
Tommy Faust
DISH Social Media Representative
Feb 12, 2012 | DISH Network IR Remote Control
My kids broke the remote that came with my vizio soundbar, I bought a universal that worked fine for about 6 months and now I can not get a remote to work with my vizio at all. I bought a new remote and...
The remotes you have purchased and tried, are universal remotes ? For an item like that the default remote that came with it would work best. I would email Vizio customer support and get a replacement. I had to do the same thing about a year ago. They charged me 10 dollars for a new one.
Post back if you have any question's or comments.
Thank you for choosing Fixya!
-Daniel
Mar 21, 2011 | Televison & Video
I recently bought a Logitech Harmony One universal remote for my VIzio HDTV and Vizio soundbar. Following the setup instructions on the DVD I sucessfully set up the remote to control the TV, cable box...
Great remote but not always easy to find right category for device.
Had a look for you and sure enough the device IS listed in data base under AMPLIFIER- then select amplifier again and input vizio for make and soundbar for model and click next.Problem solved!
Jan 09, 2011 | Logitech Harmony One Advanced Universal...
My soundbar (Phillips hts8100) freezes on low pwr standby.
hi
i have also same problem, by that time i am pressing tv/ disc button then it should be okay
Oct 11, 2009 | Philips SoundBar DVD Home Theater with...
Coby Electronics Corporation Coby Csmp95 2.1 Speaker System - 80 W Rms - Wireless Speakers - Glos Logo
56 people viewed this question
Top Coby Electronics Corporation Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Coby Electronics Corporation Audio Player and Recorder Expert? Answer questions, earn points and help others
