Question about Samsung LN46A630 LCD TV
Colors are distorted and picture images bleed into each other
The video just began distorting the picture with some blue colors and now all of the images appear to be melting into each other on the screen. Is this fixable or time to recycle it?
mfspencer
  • 58 Answers
SOURCE: LCD picture distortion.
This is caused by a failure of the main board. The failure causes the refresh rate of the unit to be off creating a trailing or ghost effect. This will require a technician to replace that board though. Hope this help.
Posted on Apr 02, 2008
SOURCE: SAMSUNG SP-P4251 DISTORTED PICTURE AND THEN SCREEN GOES BLUE
Wow same here but mine is red I know its because of the plasma bulb is wearing out and for my fix is $1000 but I didn't do want to go on so I tried to change the color settings and tried RGB to all 0 and it became fine. Well at least you have a cool blue screen, mine is red.
Posted on Jan 30, 2009
SOURCE: Crazy (red) disturbances in image
I have a very similar problem. My HP-4272 is about 3.5 years old. Started off with the bottom half going black for a couple of seconds. Then the top would flicker. Now I get the following picture... Not sure if I need to replace boards (Y-buffer lower, upper, and/or Y Main Board)? or if something just needs to be "adjusted"...
Posted on Mar 24, 2009
  • 73 Answers
SOURCE: Picture on Samsung LCD LNT5271F is blurred
Try reseating the LVDS cable.It runs from the main signal board to the T-con board at the top of the panel.
Posted on Dec 01, 2009
Had this exact problem diagnosed by a local repair shop as a bad LCD panel. According to the technician there's a loose ribbon cable on the panel and it would cost as much to replace/repair as a new TV.
Posted on Sep 10, 2010
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Intellesence cant correct wavy color ghosted images on my screen. attempted to manually adjust and line up the colors blue will adjust but red will not.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 25, 2010 | Philips 60PW9383 60" Rear Projection...
The color is distorted and the picture blinks. I've replaced the lamp twice before and i don't think this is a lamp problem.
color distortion (bleeding colors, or overwhelming of one color)on these tv's is commonly the optical engine. that might make it unecinomical to repair
Mar 27, 2010 | Toshiba 52HM95 52" HDTV Projection...
Image of picture has blue color overlaping the other colors
These sets have several common problems listed below.
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Ghosting of the image
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Green/Blue distorted Colors
Color issues are harder to solve without seeing the problem. It sound like the red amplifier on the crt board is bad. Is there any red in the picture at all? If not, that will be you problem
Nov 26, 2008 | Televison & Video
Distortion and double imaging
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Sep 07, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Distorted color on image
You might have "color filter" settings. Turn the digital filters off. Here is what manual at p72 says. "You can take pictures using digital filters. The filters consist of color filters such as red, blue and green, a soft filter that produces a fuzzy effect. Color filters Eight colors, black-and-white, sepia, red, pink, violet, blue, green and yellow, are provided for the color filters. When you select a color filter in the Digital Filter mode, the display on the LCD monitor is filtered with the selected color, and the pictures are taken in that color."
Mar 20, 2007 | Pentax Optio 555 Digital Camera
Samsung LN46A630 LCD TV Logo
127 people viewed this question
Henry  Thomas
Henry Thomas
