Question about Ovens
F 7 p oven door wont shut properly
Model 758 TC oven door wont shut properly fisher & paykel oven
  • 1170 Answers
SOURCE: Fisher Paykel electric oven doesn't heat in Bake mode
Electric Oven: Repairs and Maintenance Electricranges and ovens are generally easy to repair, because there's not muchto go wrong and there's not much you can do. Most repairs are actuallyreplacements, a matter of unplugging the old part and plugging in thenew. Most of the malfunctions that affect electric ranges involvefaulty heating elements.
Caution: Beforedoing any work on an electric range or oven, make sure it's unplugged,or turn off the power to the unit by removing one or more fuses ortripping one or more breakers at the main entrance panel or at aseparate panel. If the range is fused at a separate panel, this panelmay be located adjacent to the main panel or in a basement, crawlspace, or other location. If there is a grounding wire to the range,disconnect it. Make sure the power to the unit is off.
Servicing Fuses
Ifthe range or oven is receiving power but doesn't work, the unit mayhave its own fuse or circuit breaker assembly. This assembly is usuallylocated under the cooktop of the range. In some units, lift the top ofthe range to gain access to the fuse assembly; or lift the elements,remove the drip pans, and look on the sides of the cabinets. Inside theoven, look to the back to spot the fuse assembly.
Ifthe unit has this additional fuse or breaker system, components such asthe oven light, the range heating elements, the timer, and aself-cleaning feature may be separately fused.
If thesecomponents or features fail to work, don't overlook the possibilitythat the fuses have blown. To replace a blown fuse, unscrew the oldfuse and install a new one of the same type and electrical rating. Ifthe unit has circuit breakers, push the breaker or reset button, whichis usually located on the control panel.
Replacing Range Heating Elements
Whena range heating element burns out, it's easy to replace. But before youdisassemble the range to check or replace an element, make sure therange is receiving power. Here's what you can do:
Step 1:Check the power cord, the plug, and the outlet. Then look for blownfuses or tripped circuit breakers at the main entrance panel or at aseparate panel.
Step 2:Check the fusing system inside the range. If the circuit is broken,restore it. If the range is receiving power, go on to check the element.
Step 3:When the element is cool, remove it. In most ranges, each top heatingelement is connected to a terminal block in the side of the elementwell. To remove the terminal block, lift the element and remove themetal drip pan that rests below it. The element is held by tworetaining screws or is push-fit into the terminal block. To remove ascrew-type element, remove the screws holding the wires. To remove apush-type element, pull the element straight out of its connection.
©2006 Publications International, Ltd.
To remove a range heating element, remove the screws holding the terminal
wires, or pull the element straight out of its connection.Step 4:Test the element with a volt-ohm-milliammeter (VOM) set to the RX1scale. Disconnect one of the electrical leads to the element and clipone probe of the VOM to each element terminal. If the element isfunctioning properly, the meter will read between 40 and 125 ohms; ifthe meter reads extremely high, the element is faulty and should bereplaced.
To test a range element without using a VOM, remove aworking element from its terminal block and connect it to themalfunctioning element terminal. Don't let the test element overlap theedges of the element well; keep the element inside the well, even if itdoesn't fit perfectly. Turn on the power to the range. If the workingelement heats, the suspected element is bad and should be replaced. Ifthe working element doesn't heat, the terminal block wiring or theswitch that controls the element may be faulty. Call a professionalservice person.
Step 5:Replace a burned-out range element with a new one made specifically forthe range. Take the old element to the appliance-parts store; ifpossible, take the make and model information, too. This data willprobably be on a metal tag attached to the back service panel of therange. To install the new element, connect it the same way the old onewas connected.
Replacing Oven and Broiler Heating Elements
Electric oven and broiler elements are often even easier to test and replace than range elements. Here's how:
Step 1:If the oven element doesn't work, first check to see if the range isreceiving power. Don't overlook the fusing system inside the range.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale.
Step 4:Remove the screws or plugs that connect the element to the power.Remove the retaining shield, which is usually held by two screws, andremove the element from the brackets that hold it in the oven. Theelement is usually held in these brackets by screws.
To remove an oven or broiler heating element, remove the screws or pull
the plugs that connect it. Remove a retaining shield and lift out the element.
Step 5:Clip the probes of the VOM to each element terminal. If the element isin working order, the meter will read from 15 to 30 ohms. If the meterreads higher than 30 ohms, the element is faulty and should bereplaced. If the element tests all right but doesn't work, the problemmay be at the terminals. Make sure the terminals are clean and tight atthe element connections.
Oven and broiler elements cannot betested without a VOM. If you don't have a VOM, take the element to aprofessional service person for testing. The problem is usually amalfunctioning element; however, you aren't risking much by replacingthe element without a professional test.
Step 6:Take the burned out element with you to the appliance-parts store tomake sure you get the right replacement part; if possible, take themake and model information, too.
To install the new element,place it in the same position as the old one. Connect it the same waythe old one was connected, using the same screws to hold it in place.Just about all the other components of an electric range or oven(including its door gasket, oven controls, and timer) are virtually thesame as the components used on gas ranges.
Most problems withgas and electric ovens or ranges are easier to fix than you think. Thekey is knowing how the various parts work and when to replace them.
Have a look at these websites to find parts and details :
http://www.appliancepartspros.com/appliance_range_oven.aspx
http://www.gallawa.com/microtech/dataselect.html
Posted on Mar 21, 2009
  • 89 Answers
SOURCE: STOVES 600 oven door wont shut properly
open the door about 30 degrees, lift straight up to release the hinges, this will allow you to remove the door.
you will be able to assess the hinges from there.
most likely the hinges are just out of alignment
Posted on May 26, 2009
  • 205 Answers
SOURCE: Our Fisher Paykel OS302 completly overheated
The thermostats have probably blown. There is a rebuild kit for this problem, it is not cheap nor is the labor to do it. Try shutting off the breaker for a few minutes... sometimes it will reset, but not heat. In any event you should have the new thermostat kit installed. F/P should at least be able to give you the tele. of a Tech., keep in mind that depending on where you live there are very few technicians that are certified to fix these.
Posted on Jul 21, 2009
  • 19 Answers
SOURCE: How do you replace an oven door lining
no need of spl.tools it can change by openig screws left bottom of the door
Posted on Aug 05, 2009
  • 1891 Answers
SOURCE: fisher paykel double soft touch oven just came up
shut off the power for 5 min and try again . you will find inside the control panel a tec sheet with this code . it should help / thanks mm
Posted on Dec 02, 2009
How do you start the clock on Fisher & Paykel
Fisher and Paykel does not know that model number. Could you recheck it please and advise us?
May 09, 2016 | Fisher Ovens
Fisher & paykel b1602cte oven fan in element at back of oven not working
FIRST YOU NEED TO KNOW JUST HOW THE FAN WORKS, DOES IT WORK OFF OF ELECTRICITY OR IS THERE A COMPUTER CHIP IT WORKS OFF OF. DOSE IT WORK OFF OF JUST A SWITCH. LOOK UP ON LINE TO FIND A MANUAL FOR A FISSER & PAYKEL B1602CTE IT MAY TELL YOU WHY IT IS NOT WORKING.
Jan 29, 2015 | Fisher Ovens
I have a fisher & paykel paprika and i cant get
Hi - Are you able to provide model number of the oven - or describe the front controls as they have about 6 different types of controls regardless of the brand name 'paprika'
cheers
Jul 01, 2011 | Fisher and Paykel Ovens
Fisher and paykel oven door wont close, there is a gap at the top of the door. The seal seems to be intact. The door feels loose to the touch.
you need to either replace - or get the door hinges replaced, the spring in the hinges has weakened over time, if it is still in warranty, then they should replace them for free, if not, then take the model number to your local f&P dealer and buy new hinges. Remove the door and dismantle the door to gain access to the hinges, undo the 2 screws holding each hinge in place, clean the inside of the glas while apart, reassemble in reverse order.
May 17, 2011 | Fisher and Paykel OS302SS, Stainless Steel...
Fisher Paykel oven model OS302M error code F7?
Check your lock on the oven for the door. It may be sticking out a bit:)
Oct 01, 2010 | Fisher and Paykel AeroTech Double OD302...
Aug 05, 2009 | Fisher Ovens
Our Fisher Paykel OS302 completly overheated during its cleaning cycle. Oven door is locked, nothing comes on and Fisher Paykel will not help, it is only 4 years old, we have made many calls, and certified...
Jul 08, 2009 | Fisher and Paykel AeroTech Double OD302...
Cannot get vegetables & potatoes to roast & crisp up properly
Use fanbake and crank the heat up to 250 Par boiling the veges will help
May 18, 2009 | Fisher and Paykel OS302SS, Stainless Steel...
Fisher and paykel B1600E multifunction stove manual
I have a PDF copy of the Fisher & Paykel B1600E user manual
Nov 12, 2008 | Fisher and Paykel AeroTech - OS302M...
Ovens Logo
19 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
