Question about Cell Phones
How to move my pictures from old phone tp - Cell Phones
    Problem Solver:
  • 10 Answers
Use a micro SD card.
Posted on Jul 13, 2013
How do I move pictures from old phone to new one
You can do this using:
  • Bluetooth
  • USB cable (connect phones to PC and copy pictures)
  • NFC
  • cloud storage
Aug 21, 2014 | Samsung Cell Phones
I tryed to connect on a wireless network with TP-LINK usb Wireless Adapter b/g/n/ on puppy linux
Read http://www.cyberciti.biz/tips/linux-usb-wireless-compatibility-adapter-list.html
Jan 27, 2013 | TP-LINK TL-WN821N (TPLINKWN821N) 802.11b...
Need to copy pictures from one pantech to another pantech phone
Put your SIM card from the old one in the new one and there is a feature in there that gives you the choice to send to SIM card or phone mmemory.
Jul 20, 2012 | Pantech Link P7040 Black Rubber Feel Hard...
WATER IS DRIPPING FROM THE OUTLET VELVE LOCATED ON TOP WATER HEATER.
That sounds like the TP valve is leaking.
http://waterheatertimer.org/Water-heater-leaking.html
1) Leaking TP valve can be caused by defective TP valve
How to replace TP valve:
http://waterheatertimer.org/How-to-replace-TP-valve.html
2) TP valve can also be caused by overheated tank.
Turn down thermostat.
Install expansion tank on incoming cold water line.
Electric heater: thermostat or element may be bad and tank needs troubleshooting
Gas heater: thermostat is connected to gas valve and gas valve may need replacement.
3) First step is replace TP valve and see if that solves problem.
4) Add a comment for more free help.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on water heater.
Jan 03, 2011 | General Electric Water Heaters
Have a GE GG40T6A gas hot water tank. Leaking really bad out of the pressure relief valve. It is a rental property, gas was off to the house (tenants moved out in the night). When the gas company turned...
12 year old water heater is getting near the end.
Some tanks last 20 years, but that's the exception.
To find exact age of your brand water heater:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
Leaking TP valve:
1) Lift TP lever and gently lower back into position to see if that stops leak.
Occasionally something gets stuck in the valve.
2) Sometimes water heater temperature gets turned up because heater is not producing as much hot water as before, and higher temps cause TP to release pressure because of overheating.
Dial temperature down to 120 degrees.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
3) If steps above don't fix problem, replace TP valve >> TP valves have 125 or 150 degrees rating >>> older tank shouldn't be running above 125 because higher temps cause more pressure on tank, so thermostat should be lower than 125 degrees TP rating.
Buy replacement TP at any hardware store + a roll of teflon tape to seal pipe threads.
Turn gas control to pilot ... this will keep pilot lit but burner will not fire.
Let water cool, and then drain some water out of tank.
If TP valve is on side of tank, then open drain on side of tank and drain water until it is lower than valve level. Open bathtub spigot to let air into line.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Be careful around water that is higher than 120 degrees F >> you can get burned quickly >> apply cold water to any burn.
Use pipe wrench and unscrew TP valve counterclock-wise.
Install new TP and put teflon tape on threads.
Re-fill tank completely and open tub valve on hot side until water is running >> then turn gas control back to original position.
Do not fire up any water heater before tank is completely full of water or this could damage tank.
To read more preventative information about water heater leaks and age problems:
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Nov 24, 2010 | General Electric GE SmartWater Household...
Is there any way to get pictures from the "assigned media" folder to my mem card on my old LG Rumor or is there maybe a way to send them via bluetooth to my new LG Rumor2 without the data cable (which of...
yes,
using the memory card...
Go to your phone picture album, select the pictures you want to move to the memory card, then choose options and scroll down to copy/move. Then select either copy which will leave a copy in your phone and make a copy on your memory card, or move which moves them to the memory card and removes them from your phone. I just did this after seeing your post
Mar 18, 2010 | LG RUMOR Cellular Phone
Move pics saved on cell to memory card... a faster way?
Download them from the phone to your computer, then reload them to your new phone. Read the documentation for each machine.
Jun 09, 2009 | AT&T LG CU720 Cell Phone - Silver
Move contacts tp sim card on a slivl7c
what card? your external Memory card or internal memory card...
Aug 16, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Trigonometry(height and distance)
PA = 7 meters
ð A=600
Given Tan 60 = 1.732
Tan A = TP/AP
TP=AP*Tan A
TP = 7 * Tan 60
TP = 7 * 1.732 Meters
TP = 12.12436 meters
Zulfikar Ali
Aug 05, 2008 | Super Tutor Trigonometry (ESDTRIG) for PC
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
