Convair finesse 3300 fan turning of and on
Gas heater. Starts normally, but after a short time the fan turns off, then on, then off..... while the burner is still running
3 Suggested Answers
  • 9 Answers
SOURCE: Heater Burner ignites but main blower motor will not turn on.
it sound like the blower motor may be seizing up. try spining the blade by hand to see if it feels free or not. the motor could be trying to turn but can then tripping itself out on overload. (most motors have built in safety overloads which will trip during an overcurrant event. aka too many amps.) you may have to replace blower motor
Posted on Mar 22, 2009
  • 8 Answers
SOURCE: how do i get the front cover off of a convair finesse 3300
undo small screws between the two panels just above the bottom door
open out and pull the top hinge wire down in a u shape it will come out
easy
Posted on Mar 22, 2010
The top red light flashes and then after a while it turns off and both lights flash red with temp 14 flashing also
Hi Karen,
If my description of what your heater is doing please read through to the end.
The heater is turned on and a room temperature is selected.
You can hear the noise of a small fan start, which shortly after the heater starts.
After a short period of time the heater stops and the red led begins to flash and shuts itself down.
This type of heater has a balanced flue, which means it draws air in one pipe and exhausts it out another.
Have the balanced flue checked for blockages, the problem will most likely be in the flue pipe which draws the outside cool air into the heater and not the flue pipe which blows out the hot air.
it may be full of cob webs or something else which restricts the air flow to the heater.
A service person can perform a quick test to prove the above theory. At the rear of the heater there are two pipes, one is an insulated metal pipe and the other is plastic pipe.
Disconnect the plastic pipe from the flue box and restart the heater.
If the heater runs normally this will confirm that there is a blockage.
Jun 08, 2014 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a 1997 JGC V6 lately I noticed that the gauges don't work when the key is in the run position and the jeep wont start. If it sits for a while then I turn the key the gauges come on and the jeep...
Are you the only driver for this vehicle?
Next time when you refill up,DO NOT TOP OFF THE GAS.
When the gas pump stop,just let it stop. DO NOT TRY to put more into the take.
When topping off,the fuel sensing float is push BEYOND it limit. It will create a short on the wiring to the gauage.
Please ran few tank WITHOUT TOPPING off and see does the flow return to normal and not creating a short.
The fuel pump and gas level sensor is in the same unit. It's costly to pull the gas tank down and replace it.
Aug 26, 2009 | 1996 Jeep Grand Cherokee
How do i get the front cover off of a convair finesse 3300
easy
Apr 28, 2009 | Heating & Cooling
Mar 16, 2009 | Mr. Heater Natural Gas Garage Heater -...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
