Question about Electrolux EW1000i Front Load Washer
Reset Electolux Washing Machine(EWF 10751) Memory
Hi, I bought a Electrolux EWF 10751 washing machine recently, the problem is after two incidents of stopping the washing machine abruptly, the machine recorded(into the memory) these interruptions at two different interval like 15 mins and 45mins, ever since this incidents, i need to press the Start button twice at two different intervals. Is there a way to reset the memory?
  • 3 Answers
SOURCE: Machine stops and the Start light is blinking
It might be teh same problem I have. in my case, teh machine works for a few seconds and then stops i.e. nothing else happens. no alarms go off either. In my case it appears that teh door interlocking device is faulty. You can by this spare part for around 22 euro. Replacing it is a bit tricky because you need to take off the locking device(the slot where the door locks into) and redo wiring. DONT mess up teh wiring becasue then you will need an engineer. Before you go looking for a spare part, you can take off teh interlock adn manual try to operate it. do this by turning on a wash and pressing teh two metal parts together on the lock.
Posted on Aug 27, 2009
  • 174 Answers
SOURCE: A washing machine Electrolux EWF 1025 does not start up.
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
Posted on Jul 24, 2010
BIKER T
  • 909 Answers
SOURCE: Hi, I have an Electrolux
Im taking it that you have a squirrel cage motor.(motor without bruhes) Locate the capacitor and replace it. Most of the time its the capacitor that has malfunctioned and that will stop the spin cycle. If you have a soft start.(an electronic control), then check the brushes. Possibly need someone to help as the motor will need to be removed to gain access to the brushes. Check length. must be at least 25 mm.(otherwise not enough tension). Make sure power is pulled out when doing this repair.
Posted on Sep 05, 2010
SOURCE: how to reset my washing machine (electrolux)
my electrolux EWT606 will not spin. it drains and then just wont go into spin cycle....no error messages it just beeps. can anyone help me please as i have kids with disabilities and NEED to wash!
Posted on Sep 26, 2010
tunde007
  • 2382 Answers
SOURCE: The washing machine Electrolux 1087
Hi, if the washing machine stops in the middle of a wash cycle, the first step that should be taken is to perform troubleshooting steps to determine the cause of the problem. After the source of the trouble has been established, it can be resolved in most cases by continuing the troubleshooting process.
  • Make sure the lid is completely closed. Certain parts of a wash cycle will not start if the lid is not closed.
  • Check the load to see whether it is unbalanced. If the washer gets off balance, it may stop in the middle of a cycle. Redistribute the clothing so that it is evenly balanced around the drum.
  • Make sure the hot and cold water faucets connected to the washing machine are turned on fully. If the washing machine is not getting enough water, it will not be able to complete the cycle.
  • Inspect the drain hose for clogs or obstructions. The washing machine may stop if it is unable to drain water properly. Check the drain pipe that the hose feeds into for clogs or debris.
  • Check the house's circuit breaker panel or fuse box. The circuit may have been tripped or a fuse may be blown. Replace any blown fuses and reset any tripped circuits.
If after doing all these and the problem still persist, you have to call in a tech to check it out because there is no way to reset the Electrolux 1087
Posted on Dec 20, 2010
I want to reset program for electrolux ewf 10751
Turn the program selector to position "O" to
Reset programme / Switching OFF the machine.
Dado
Nov 03, 2015 | Electrolux Washing Machines
How do I replace the door handle on a electrolux front loader ewf 1074 washing machine
hi
you need to take the door apart to be able to replace the handle
is a easy job but remember the order you take it apart to be able to put it back on
Apr 23, 2015 | Electrolux Washing Machines
Electrolux EWF 1495 won't spin.
The belt could be stretched or the tension idler could be malfunctioning.
Feb 12, 2015 | Electrolux Washing Machines
Why wont my ewf 1080 electrolux spin
Most likely the washing machine is stuck in Hold mode. Check if you have the spin speed knob at the correct setting.
Manual is available from here
http://www.manualslib.com/manual/616814/Electrolux-Ewf-1080.html#manual
Check the parts and schematics at this site
http://spares.bigwarehouse.com.au/index.php?cPath=64689_77309_77544&sort=2a&page=1
Aug 29, 2014 | Electrolux Washing Machines
Jul 24, 2010 | Electrolux Washing Machines
Electrolux EWF 1470 Error code E20
could be the element at fault or pressure chamber
Jan 12, 2010 | Washing Machines
Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
Aug 08, 2009 | Electrolux EW1000i Front Load Washer
How to reset my washing machine (electrolux)
Mar 14, 2009 | Electrolux Washing Machines
Whats is the total weight of electrolux ewf 1495?
thas a question that the manufactuer should be able to answer for you, ifnot the dealer that your goingto purchase tehunit through should be able to get you those specs.
Mar 12, 2009 | Electrolux AWF1235 Front Load Washer
Electrolux EW1000i Front Load Washer Logo
599 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
