Question about Danby DPAC13009 Air Conditioner
Dpac 13009 loud noises
SOURCE: Actually it's a DPAC 13009. We need to extend the 2 air pipes 4 to 5 feet each to reach upper windows over patio doors to keep doors locked and secure. Does Danby provide air pipe extensions? Thanks.
No solution possible, given that the air ducts going up over the patio doors are quite an eyesore. This building is entirely fieldstone outside, so either the patio doors or windows above them are the only way to go in or out.
We will return the unit and get instead one that can be placed in the upper window and activated by remote control. Thanks.
Posted on May 19, 2009
SOURCE: DPAC 13009 portable air conditioning problem
Remove your remote control on the unit, follow the manual step by step. First, do the emergency on/off button, then operate the air conditioning using the remote control, follow the procedure of your manual.You may notice a clicking sound of your remote control. The yellow/green color of your emegency on/off button will turn to blue. Do not put it back your remote control on the unit because he may sense the temperature of the vent, and your air conditioning will not stay on, it will shut off every five minutes. Your problem is solve.
Regards,
Cesar
Posted on May 28, 2009
TheMobilian
  • 8220 Answers
SOURCE: How do you install Danby
This whirlpool manual will give an idea: 10000 btu portable
Posted on Jun 26, 2011
  • 20 Answers
SOURCE: we bought the danby Premiere
check service tag on unit what is the amp rating on the unit does it exceed your breaker size??
Posted on Jul 03, 2011
  • 4736 Answers
SOURCE: I have a DPAC 13009
From your description, I would have to agree with you on the pieces being from a broken fan. The good news is, that your model has a 24 month in home service warranty, so the parts and labor to repair are covered. But, the real key is having a Proof of Purchase. Armed with that, you're good to go.
Contact Danby Consumer Support 1-800-263-2629, to file a Warranty Claim.
I hope this helped you and thanks for choosing FixYa.
Posted on Jul 26, 2011
I have a DPAC 13009 that was purchased a year ago at COSTCO. It has worked fine until now. It began making weird noises and then kept shutting off. Upon further examination there were pieces of white...
Jul 26, 2011 | Danby DPAC12031 Air Conditioner
We bought the danby Premiere DPAC 13009 for our trailer and it is blowing the breaker.
Jul 03, 2011 | Danby DPAC13009 Air Conditioner
My Danby Premiere DPAC 13009 is leaking water through the bottom. I have attached the continuous drainage hose, and no water is going through it. I tried to manually drain the tank using the drain at the...
Water is collected from cooling mode, not just dehumidifier mode. It does not always evaporate into the exhaust stream due to design limitations.
Of course the water should never leak even on the hottest day. Two suggestions:
Try removing the hose and attaching the external tank to see if it has any effect. Otherwise, you'll need to locate the exact source of the leak.
May 25, 2010 | Danby DPAC12031 Air Conditioner
Sears brand CHEST freezer had beeping noise. I changed the 9volt battery. It still beeps every 10sec. and flashes the number 6 and FF
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 05, 2010 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Picked up used chest freezer...plugged in and briefly clicks...I can hear it energized for about 5 seconds then quits....it then repeats this cycle. It was on its side when delivered
Try to replace the compressor relay (most of the times problem) ,but if still doing the same clicking noise , the problem is in the compressor.
Sep 29, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
I am purchasing the DPAC 13009 Danby 2009 portable A/C, but....
Mae; I'm sorry to hear another good deal went bad. Door to door wholesale is a way to sell items that can't be sold in stores.. If you take a picture of what the hose connecta to and send it to me, I'll see what I can do. Explain the purpose of this hose andthe measurement of the connector outside diameter. The picture will say alot, I would appreciate it. e-mail the picture to co7196@yahoo.com and we'll figure out something.
Jul 20, 2009 | Danby DPAC12031 Air Conditioner
Regards,
Cesar
May 24, 2009 | Danby DPAC12031 Air Conditioner
May 16, 2009 | Danby DPAC12031 Air Conditioner
Danby dpac 7599 PC board fuse keeps blowing
Sounds like the Start capacitor might be shot.  I think  you need a professional to service it.
Jul 08, 2008 | LG Goldstar GWHD5000 wall/window Air...
Open Questions:
What is the best physical configuation exhaust/drainage to use with dehumidifier mode to avoid room temperature increase? There are 2 drainage outlets on this model top and bottom. However the user manual doesn't mention about the top one. In AC mode, if I don't connect any drain hose, the unit fills up fast and stop. When the exhaust vents are connected outside required for AC mode only, I cannot use the bottom drainage hose because I have no drain nearby. Therefore I use the top drainage and add a bucket beside the unit. This setup works fine for hours in AC mode without intercuption and the bucket fills up with water fast. However the rooms gets too cold below 20C/68F while still quite humid +60%. But if I switch to dehumidifer mode with the same setup, the unit only runs for a few minutes, then stop completely for another 5 minutes, then turn into FAN mode which blows very humid air for another while and then turns the compresssor back ON for another 5 min. and the loop start over. After hours of operation, the bucket nearly has any water and the room humidity is the same if not worst. I thought the compressor was defective so I tried the dehumidifer mode without the exhausts vents connected outside and the bottom drainage hose as suggested in the user manual. This setup works continuously but does not remove much humidity vs. the amount of heats it generates. The unit has AUTO Mode which switch between AC and dehumidifier mode. So there must be a way to keep the same physical installation exhaust and drainage for both these mode, is there? Thanks
Jul 30, 2016 | Danby DPAC13009 Air Conditioner
See all Danby DPAC13009 Air Conditioner Questions
Danby DPAC13009 Air Conditioner Logo
24 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
