Question about Frigidaire Fra064vu1 Air Conditioner
How to fix a frigidaire air conditioner FRA064VU1
2 Suggested Answers
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
Will you help me fix my Frigidaire fac107p1a unit?
Good morning friend, I appreciate your post!
I understand that you are trying to diagnose and repair your Frigidaire air conditioner, FAC107P1A. Could you describe what your appliance is doing so that I can assist you better in pinpointing the problem before any additional steps are taken. I have provided the link to where you could find additional information regarding a manual for your air conditioner as you have requested as well. I look forward to assisting you. -Matt
Frigidaire Manual Search Results
Jul 23, 2014 | Frigidaire FAC107P1A Wall/Window Air...
I have a frigidaire fac105p1a that is spiting water out though the vents what do i do about that?
Good Morning Friend,
I understand that you have water spitting out of the top vent on your Frigidaire air conditioner, model# FAC105P1A. I also see that it sounds like water is gurgling through the pipes and you want to know how to fix it. If your air conditioner is also leaking outside, this is normal during excessively humid days, due to it removing large quantities of moisture from a humid room. If it is also dripping inside, I suggest slightly tilting your air conditioner to the outside, to allow water drainage. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 15, 2014 | Frigidaire Heating & Cooling
My frigidaire air conditioner LRA067AT7 won't cool
The thermostat isn't turning on the compressor. Check it out first. If it seems ok then check the wires going to the compressor. One of the 2 places will be the trouble .
Feb 05, 2014 | Frigidaire 6000 BTU Window Room Air...
Frigidaire FRA064VU1 repair
Hello, yes once you remove the outer housing it should not be difficult to snap or fasten into place.
Jul 06, 2012 | Frigidaire Fra064vu1 Air Conditioner
Water is spitting out of vents where is the drain pump on ac ?
David, there is no drain pump on your AC. There is a drain hole in the drip pan near the rear of the unit.
It is probably clogged. Another reason for your trouble is that the rear of the unit may not have the proper downward tilt. The rule of thumb is 1/4" to 1/2" downward tilt. This allows the water to flow freely to the rear drip pan drain hole.
Find the drain hole can be a challenge, as the clog can blend in with the hole. Once you find it, a pipe cleaner works well to clear the clog.
Hope this helped you & thanks for choosing FixYa.
Sep 16, 2011 | Frigidaire Fra064vu1 Air Conditioner
My window is only 18-19" wide. I need to know the
You can find the information you're looking for, as well as the Owner's Manual and Installation Guide at the following link.
http://www.frigidaire.com/products/air-conditioners-dehumidifiers/window-air-conditioners/fra052xt7
Hope this helped you.
Jul 14, 2011 | Frigidaire FAX052P7 Compact Room Air...
My frigidaire window unit has started leaking inside. what could be causing the leak and how can I fix it.
its either in the drain pan which would need cleaning so water can excape or filter cleaned or both please give me a vote and rating
Sep 21, 2010 | Frigidaire FAC126P1 wall/window Air...
My frigidare wall mount air conditioner won't blow cold air? Can this be fixed?
<P style="MARGIN: 0in 0in 0pt" class=MsoNormal><SPAN style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang=EN>Hi,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P style="MARGIN: 0in 0in 0pt" class=MsoNormal><SPAN style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang=EN><o:p>&nbsp;</o:p></SPAN></P><P style="MARGIN: 0in 0in 0pt" class=MsoNormal><SPAN style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang=EN>Here is a tip about troubleshooting your air conditioner...<o:p></o:p></SPAN></P><P style="MARGIN: 0in 0in 0pt" class=MsoNormal><SPAN style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang=EN>There are many things that can cause your air conditioner not to cool…<BR><BR><A href="http://www.fixya.com/support/t4975332-c_run_only_humming_noise_when_turned" target=_blank><FONT color=#0033cc>Air Conditioner</FONT></A> Trouble -Review the <A href="http://www.fixya.com/support/t5003406-compressor_failure_sends_out_hot_air" target=_blank><FONT color=#0033cc>Possibilities</FONT></A> <BR><A href="http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi" target=_blank><FONT color=#0033cc>http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi</FONT></A><BR><BR>heatman101 <BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break"></SPAN></P>
Aug 25, 2010 | Frigidaire Heating & Cooling
Jun 30, 2008 | Frigidaire FAH08EJ1 Air Conditioner
Frigidaire Fra064vu1 Air Conditioner Logo
20 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
