Question about Refrigerators
79577563600 how do you replace water hose at top of refrigerator - goes into a hole at the top. Can not find repair manual Kenmore Elite 7957563600
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
  • 363 Answers
SOURCE: replacement instructions for ice maker in
I have found service manuels at appliancesfactoryparts.com
Posted on Jul 17, 2009
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore Elite 79577563600 is showing Er 1F.
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#@%
Posted on Sep 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: KENMORE ELITE MODEL #79577563600 FAILURE COCE
Why is water leaking from back of kenmore elite refrigerator?
Also, can be a crack on the plastic hose, close to the inlet water valve.
Aug 16, 2014 | Kenmore Refrigerators
79577563600 defrost reset
as for the water part sounds like the drain is pluged.most of these drains have a trap.just like your sink only a lot smaller,and get alge growing in them.to clean you must remove the lower back wall of the freezer,drain hole will be at the bottom of the drain pan below the coils,be very careful not to make a hole in the coil or it WILL cost you.i use a ball pien hammer and flat tip screwdriver to remove all the ice i can.then i have a squirt bottle that can make a stream and a rubber hose that will go down the hole,5-16 fits a lot.HOT water in bottle down the hole.hose in hole,blow,no good?pull water out with mouth,blow into pan,repeat.may take a few times,may take an air tank.if not cooling good you may find the coils are frosted up, no defrost!could have evap. fan staled.that will give the drain issue.if this is the case you need to call for help.hope this helps.
Apr 16, 2014 | Kenmore Refrigerators
Looking for a manual for Kenmore Elite Refridgerator MFG 2005 Model #106.74219400
http://www.managemylife.com/mmh/owner_manuals/5877
/KENMORE-ELITE-Top-Mount-Refrigerator-L0408620
Apr 20, 2011 | Kenmore Top Freezer Refrigerator
Kenmore Elite refrigerator, double doors, bottom freezer, not making ice error code comes up er1f Model # IS 79577563600
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 15, 2010 | Refrigerators
Mar 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore refrigerator. Just replaced defrost timer, 2 weeks ago. This corrected the problem of warm refrigerator compartment. Now water puddles forming on top shelf, and in the very bottom. Water is...
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Nov 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Leaky bottom freezer on my kenmore elite refrigerator
defrost drain is clogged. defrost drain water is over flowing into bottom. take back panel off. remove ice to find drain hole. use very hot water and turkey baster to wash out till clear.
Jul 25, 2009 | Kenmore Refrigerators
Kenmore Elite
could be spash over be sure washer is as level as possible
Jun 01, 2008 | Kenmore 22422 Top Load Washer
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
