Question about Pioneer Audio Players & Recorders
Pioneer sc-lx56 remote
Remote not working
How do i master reset
Here is a screen shot of the user manual section......25168606-leps2bfk05nmwqmujoyhxhwt-2-0.jpg
Oct 01, 2014 | Pioneer Elite SC-55 9-CH Class D Receiver
Turntable will not work
If the other lead wire is a single wire, that's a ground wire that attaches to ground on the amp or reciever.
Jun 07, 2014 | Sony Ps-lx56 / Ps-lx56p Stereo Turntable...
How do i connect to internet radio
Your Receiver can be configured to receive Internet radio provided it is connected to the LAN port.
Please check the user manual at this site for LAN connection and internet radio setup.
Hope you find it useful.
http://www.pioneer.com.au/au/products/archive/SC-LX73/media.html
May 05, 2014 | Audio Players & Recorders
How do I connect my pioneer SC LX73 to my wifi
Panasonic sc-ht855 remote not working
it's either your batteries need replacing or the remote does. unless, of course, the receiving sensor on the home theatre isn't working.
Jun 07, 2012 | Audio Players & Recorders
Hi: i have a sc-05 pioneer elite rec. i just
Hello I believe you are correct in the cause of this problem; it would be due to one of the audio calibration protocols that are programmed on board that uses each channel individually and disables the others. Or, there is one other cause. I'll address both.
Make sure the MCACC microphone is disconnected.
Then make sure the slide switch on the remote is NOT on the selection at the far right that is labeled "RCV." Select either "source", or "TV."
Otherwise, also on the remote is a button on the right side of the panel labeled for channel level as "CHLevel" that allows you to have individual volume control of each speaker.
To correct this, move the slide switch on the remote to "RCV" and then press the "CHlevel" button, then use the left or right arrow keys on the remote to set each channel to the same value. When finished, return the slide switch to "Source."
Jan 10, 2012 | Audio Players & Recorders
Were can i get a remoto from my one is not working
First check the Panasonic Accessories Order Site: http://www.pstc.panasonic.com/EpartR/PartsListChoice.asp . Then enter the remote part number in the part number search area. The remote is either N2QAYB000029 (black) or N2QAHB000064 (silver).
Alternatively, try remotes.com: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=SC-AK640&uuid=12987598805750 . I see two Panasonic SC-AK640 remotes (one for the SC-AK640K and the other for the SC-AK640S).
I hope this helps.
Feb 26, 2011 | Panasonic SC-AK640 Shelf System
Remote for Pioneer HTV-2 not working
I never did fix the remote, but I was able to use my other remote (universal) to control the Pioneer HTV-2. Thanks
Jun 04, 2009 | Pioneer HTV-2 System
49 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
