Question about Garden
Craftsman lawn tractor Model 917.28856
When brake is depressed tractor is quiet,when brake petal is depressed,when petal is out machine is very noisey, is there an adjustment to quiet this problem?
  • 10 Answers
SOURCE: What color was Craftsman Lawn Tractor Model
Im pretty sure it was gray, than the newer models bcome green
Posted on Sep 23, 2009
  • 19 Answers
SOURCE: adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
Posted on Jul 19, 2010
  • 1015 Answers
SOURCE: I have a craftsman lawn
If you haven't done so check drive belt to make sure it is fully engaging when you put it in gear. You can also check to make sure that your break is fully releasing.Grasp pedal with your hand and pull it back to make sure it is returning. Thank you.
Posted on Apr 14, 2011
kel1guy2002
  • 3740 Answers
SOURCE: brake adjust need manual craftsman lawn
The manual for your mower is here: (5.08 mb)
http://www.managemylife.com/mmh/lis_pdf/OWNM/LR707473.pdf
Brake adjustment is on the bottom left of page 20.
Thanks for choosing FixYa,
Kelly
Posted on Sep 25, 2011
roadtech7
  • 297 Answers
SOURCE: where is the spark plug located on my craftsman lawn tractor model 917.273360
James, it is at the front of the engine. It is next to the 4" by6" metal cover that says OHV. It is on the right hand side ( sitting on the tractor), There is a black wire the size of a pencil ( diameter ), hooked to it. It is set deep in the engines cylinder head. There is a rubber boot over the end of the spark plug. Remove the rubber boot, you will hace to grip it hard and pull it off. Then you will be able to remove it, using a deep 5/8" socket with a 4 to 6 inch extension.
Hope this helps, if you need more let me know.
Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Dec 02, 2011
Park brake won't hold. mower will roll with brake engaged
Not sure what mod or make you have..but most mowers have an adjustment on the brake arrangement..get the mower in the air so you can see the movement of the brake rigging when depressed..have someone depress the brake while you watch the movement..now follow the rod or rigging to rear wheels or axle..you should find a adjustment..you may have to remove it to adjust the end connection..good luck..
Jun 23, 2015 | Garden
Why wont my1996 mtd lawnmower stop when i depress brake
The brake is located on the right side of the transmission just forward of the axle. Check that the spring and keeper are in place on the brake rod. The brake is adjustable via the 1/2 inch nut at center of the brake assembly
Sep 01, 2014 | Garden
Where are kill switches on my Craftsman 46" Hydrostatic lawn tractor?
how old is the mower? Usually one in the seat & under the engine cover where you depress the clutch/brake pedal. Good place to start. Hope it helps.
Aug 14, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to adjust brake/clutch on mtd riding mower
Go to MTD website and download owners/or repair manual for your tractor ,then adjusting the brake will be easy !
Jun 29, 2014 | Mtd FASTATTACH MANUAL SLEEVE HITCH
No brakes petal very stiff
probably a leaky vacuum brake booster.
Feb 09, 2014 | 1998 Dodge Caravan
2005 jeep liberty brake lights don't work, none of them but fuses and brake light switch are good.
maybe brake light switch located near your brake petal needs adjusting...its simply a push button that the brake petal hits as the brake petal is depressed usually u can just pull on them toward you and they'll "self-adjust" after pressing on brake petal...push on brake petal with ur hand and make sure this button is depressed while the pedal is down...
Dec 18, 2013 | Cars & Trucks
My craftsman 19.5 hp with model 42e707 will not crank
Cutting attachment turned off, brake pedal depressed? These are interlocks and must be happy before cranking is possible. Is this machine new to you?? or is it a new problem this spring?
Aug 19, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman lawn tractor parking brake won't engage
are you holding the lever while lifting your foot of the pedal?
Jun 27, 2012 | Garden
Gear shift stuck in park - brake lights are working - we have checked all the fuses. How do we remove the cover on the shift panel?
First check for a loose vacuum hose to the brake petal. Most models use this safety for engaging the tranny by depressing the brake petal and then selecting the drive or reverse gear.
May 26, 2011 | 2008 Chevrolet Impala
My lawn mower will start easily and continue running as long as the clutch brake is depressed but when I lift the clutch or try to engage the blades while the clutch is depressed the mower will stall.
This is a shot in the dark. I think you have a failed "operator presence safety switch". Rule this out by finding the switch and jumping it.
Your mower should run with no one in the seat IF THE PARKING BRAKE IS SET.
If the brake is released and no one is on it, it should shut off.
If you are on it and the brake is released you should be able to engage the blades (probably an electric clutch)
Purpose of this interlock is the shut the machine OFF should you fall off or jump off the machine. Do not disable this valuable safety feature.
Let me know what you find.
Thanks for your question @ FixYa.com
May 15, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
139 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
