At12000-a i have a aerotemp heatpump model#at12000-a serial#cta-400047-c00 need wiring diagram so i can rewire all paperwork gone
5 Suggested Answers
  • 340 Answers
SOURCE: need wiring diagram for intertherm e2eh-017ha
try their web site. then ask your self why the wires melted. Tom
Posted on Jul 03, 2009
  • 588 Answers
SOURCE: how to wire rth3100c to tempstar heatpump
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Posted on Feb 28, 2010
  • 82 Answers
SOURCE: i need a wiring diagram for a tempstar gas pack
Go here - http://www.gotempstar.com/go/index.asp?t=86&s=477
enter PGAA in model box.
Posted on Mar 14, 2010
  • 51 Answers
SOURCE: wiring diagram for Rheem rpka-31 jaz heatpump
TURN THE POWER OFF TO THE UNIT. TAKE THE BACK PANEL OF OF THE HEAT PUMP AND LOOK FOR A SQUARE PLASTIC BAG FASTENED TO THE INSIDE OF THE UNIT, IT MAY BE LOCATED BY THE CONTACTS AND SYSTEM WIRING OR ON THE PANEL ITSELF. REMOVE THE PAPER FROM THE PLASTIC AND THIS SHOULD CONTAIN YOUR WIRING DIAGRAM. ALSO LOOK ON THE BACK OF THE PANEL ITSELF FOR THE DIAGRAM. SOMETIMES THE DIGRAM IS PRINTED THERE.
Posted on Apr 13, 2010
What size capacitor in a Carrier Heat Pump 38yh036300
This is a three ton heatpump must likely it is a 35/5uf capacitor. But if you can read compressor tag it will tell you size it requires and also fan label will do some for it.you will need to ask for a dual capacitor from supply house make sure you pay close attention to hoe wires hook up so you can wire in new on before removing wires make sure you have high voltage turned off to unit.take pic with phone this will help when you rewire
Mar 10, 2015 | Carrier 52CQ-312-4 Comfort Series Heat...
How do I rewire a cut harness car radio of a chrysler town country 2010
If you have original cables match pins. Otherwise there should be a diagram or table (paperwork) explaining where to wire in the new to old wires.
Feb 07, 2015 | Chrysler Cars & Trucks
I have intertherm e1eh-015h I just wired up heat
when the thermostat is set more than 2 degrees higher than room temperature the auxiliary heat will run with the heat pump.
Oct 11, 2014 | Heating & Cooling
Hi my name is Pat I need the rewiring diagram. So I can rewire my dewalt radial arm saw motor, it is a single phase capicitor motor with built in brake.It`s 120/208-240 volts, 11/5.5 amp, 3450 rpm, 236...
Here's a Google search on the subject:
https://www.google.com/search?q=dewalt+radial+arm+saw+wiring&ie=utf-8&oe=utf-8&client=firefox-b-1
Feb 04, 2018 | Saws
Need the wire diagram to rewire my Ariens lawnmover to bypass the safety switch. It is Ariens GT-19 model # 931026 Serial # 001463. Can you help? It is an old Ariens mower but still runs good but now I...
here is owner manual:
http://apache.ariens.com/manuals/030305C.pdf
usually the switch is behind the ignition, sometimes at the N position of gearshift, just look for a switch with one wire coming in & one going out (usually the same color); disconnect the two wires & jumper them together to bypass the switch. Looks like yours has one under the seat.
Apr 25, 2017 | Sport & Outdoor - Others
Wiring diagram for Rheem rpka-31 jaz heatpump
Apr 13, 2010 | Heating & Cooling
Changing home thermostat
Couldn't find your thermostat based off the information you provided; find the model number and follow the link to the Contractor Support Page.
White-Rodgers Multi-Stage Thermostate Diagrams for Contractors
Nov 28, 2008 | Heating & Cooling
BMW Wiring Diagram
Google it;enter you're make/model system operations schematics-it'll take you to wireing diagram.
Oct 23, 2008 | 1984 BMW 3 Series
WIRING
why did the wiring burn?Id have the heat exchanger inspected before rewiring.better to be safe.
Sep 17, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
