Question about Minolta Di3010 Copier
Minolta ep 3010 error code - Minolta Di3010 Copier
  • Minolta Master
  • 6,696 Answers
Sir/mam which is it EP3010 or Di3010 one is digital the other anolog
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 30, 2015
Bubbabear64
  • 2794 Answers
SOURCE: Minolta Di 3010 Error code C0910
Sorry it took so long but I found it.
C0910 indicates that the 2nd drawer on your copier isn't lifting. Open the drawer and see if there is any jammed paper in there.
Posted on Sep 06, 2008
SOURCE: meaning of code C04 ( EP 2030)
minolta cspro1054 turns off once you turn it on and code is c
Posted on Nov 03, 2008
claudiomn
  • 10 Answers
SOURCE: my Minolta ep 1030 shows C04
Verify exposure lamp or  lamp's fuse.
Posted on Jan 17, 2009
  • 990 Answers
SOURCE: Minolta EP 5000 error code c0b63
Hello sir; that code means sortr bins problem, I belived when you moved hit somewhere soter bin out of track( not line up).
Posted on Mar 22, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: my copier minolta cs/pro ep 2010 does not
This is a C05 error code. This means you have a fuser error. The fuser is the section that gets hot right where the paper exits the machine. Most common failure in the fuser unit is the thermal fuse. The repair requires removal and some dis-assembly of the fuser unit to replace the fuse. Also have to use a special reset procedure to clear the C05 code from the machine after repairs are made. Do you have access to a local repair shop that can repair this for you?
Posted on Mar 20, 2010
MMY COPY MACHINE IS CSPRO MODEL EP 3010 MINOLTA APER ERROR CODE C061
Lens Motor, under the big glass is to your right is the lens assy. there is a motor that works the mirrors on that side it is either jammed or burned out. Or worse case the board controlling it is bad. You have a Legacy Minolta Machine, get a tech out (Old School one:))
Jun 02, 2014 | Konica Minolta Office Equipment & Supplies
Ep minolta giving error code 400
well the EP model number would help
Jan 04, 2014 | Konica Minolta Minolta DI1610FP...
Book Maintenance Copiers Konica Minolta cspro ep300
Exposure lamp the bright light under the big glass is burned out, try reset, by opening front door look to your upper left small access plate remove it this must be done with machine on. press the reset button if the code goes away OK. If not replace the exposure lamp if you can find one a very very legacy Minolta machine!
Nov 27, 2013 | Konica Minolta 1149-0291-01 Minolta Cs Pro...
Minolta ep 3010 error code c920
DO you mean a Di3010 or EP 3010 totally different one is anaolog the other digital?
Jul 13, 2013 | Minolta Di3010 Copier
What is Error C0110 for ep 4000/5000 cs pro
Could not find that code in the service manual how about C0000 or c-0010
Apr 18, 2012 | Minolta Office Equipment & Supplies
HOW TO ENTER INTO SERVICE MODE minolta ep 3010
Utility, meter count, stop0 stop01
Mar 05, 2012 | Minolta Office Equipment & Supplies
Please I want the solution of the code error C0F22 for the minolta EP 3010 CSPRO
Check the drum density sensor must remove the drum to clean it.
Jun 27, 2011 | Minolta EP4000/5000 CS/PRO Copier
Minolta cspro ep 3010 code c0924
On the control panel is there a little icon like wrench in the left hand corner of the screen, if so touch it then new screen will appear, once new screen appears open close the front door to reset the code
Mar 16, 2011 | Minolta DiALTA Di520 Laser Printer
Mar 22, 2009 | Minolta EP4000/5000 CS/PRO Copier
Meaning of code C04 ( EP 2030)
Nov 15, 2007 | Minolta EP1030/1030F CS/PRO Copier
Minolta Di3010 Copier Logo
57 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
