User manual for Telex Caramate 4140 Slide Projector
Need for bulb and other parts of this projector,
2 Suggested Answers
  • 33 Answers
SOURCE: Slide/tray advancement
http://www.fixya.com/support/t1564949-slides_advance_continusly
This link talks specifically about a Kodak slide projector. However the faulty mechanism in your Telex works in a similar way if you feel up to taking it apart. If you do, mark every screw and piece you remove, in a diagram. Though your symptom is sporadic advancing and the other link is continuous advancing, it's essentially the same cause, as sticking trigger mechanism in the clutch release.
Posted on Feb 19, 2009
I just got a used Telex Caramate 4000 slide projector but no manual. Who has one I can buy?
sadly when buying used items getting a manual would be the first thing I would ask about from the seller .. you can try searching thru Google and hope for the best
Jun 07, 2016 | Office Equipment & Supplies
Want to transfer slide pictures from a Telex Caramate 4000 to a laptop. Is it possible to do this?
you need telecine transfer facility take it to duplication house they might help ypu
Dec 21, 2013 | Telex Caramate 4000 Used Audio Visual
Projector turns itself off and on
Caramates have a Thermal Breaker built into their electrical circuits, which will "open" if the internal temperature gets too high for safety. When the internal temperature drops to an acceptable level, the breaker "re-sets" and the projector will come back on. You will need to check for any obstructions to air flow first. Next, make sure the exhaust fan is running at the proper speed. Once those items are checked, if the problem still exists, you will need to locate a circuit diagram and the appropriate thermal breaker for replacement. Good Luck!! Jim
Oct 27, 2013 | Kodak Office Equipment & Supplies
Manual for kodak ektasound moviedeck projector 275
Check with www.micro-tools.com for parts and manuals!! They have an amazing inventory of classic Kodak parts for slide & movie projectors! Good Luck !! Jim
Jun 05, 2012 | Kodak Vintage Ektasound Moveideck 265...
I have an OLD telex projector. Looks like a box with a tv screen on one side and carousel on top. have no idea how to use it. maybe bulb needs replacing
Telex called those "CaraMate XXXX" (XXXX usually relating to model number ). The old ones projected on the internal screen. Newer models could project both on the internal screen and (by sliding a door on the top panel) on a projection screen for larger audiences.
If it needs a lamp, check with: www.bulbman.com But you may have to search - - it's been a long time since they were manufactured!
Good Luck !!
Jun 21, 2011 | Telex Office Equipment & Supplies
I have an old Kodak Caromate 3300 slide projector. Can I get a manual for this? I cant get it working properly, ie carousel will not move forward and slide cannot be viewed.
Is it a Kodak AudioViewer or a Caramate 3300?? hard to tell from the problem description.
If it is a Kodak branded unit, I know Kodak doesn't have the manuals any more, so my advice is to contact a factory-trained service dealer to see if they still have a service manual!
If it is Caramate branded, I'm really not sure where to send you. There were subtle design differences between the 2 brands!!
Good Luck !!
Feb 04, 2011 | Kodak AV210P 80 Slides Rotary Carousel...
Projector works but image is very dim
Hello.
Here are 2 links for your Epson Powerlite 7300 projector:
User manual:
http://files.support.epson.com/pdf/pl53__/pl53__u1.pdf
User Replaceable parts list:
http://files.support.epson.com/pdf/pl53__/pl53__rp.pdf
And ... yes .. the replacement bulb for most projectors are very expensive.
Hope this helps.
Feb 23, 2010 | Epson PowerLite 7300 Multimedia Projector
Kodak 410 Projector/Viewer - no lite through projector or viewer
These projectors were designed & made by Telex for Kodak.
If the screen stays black when you push a slide down into the "gate" (in either viewer or projector mode), then the trip mechanism that opens the shutters when a slide is detected has a problem. It could be an adjustment, a broken or out of position spring or hardened lubrication.
There is no good way to proceed unless you are trained in the service of these projectors. Contact a factory-trained repair dealer. Happy New Year!
Nov 16, 2009 | Kodak Open Box BC-4601 Slide Projector
Jan 27, 2009 | Telex 3280 Caramate 80 Slides Rotary...
112 people viewed this question
k24674
jasbo
jasbo
