Question about LG Televison & Video
Lg model 50PT250-TA
RED BUTTON GOES BLUE THEN RED (CLICKING SOUND)
4 Suggested Answers
freelance-au
  • 131 Answers
SOURCE: LG 60PC1D making clicking sounds
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Please rate my reply ++++
Posted on Apr 05, 2010
  • 11800 Answers
SOURCE: Hi I just bout a
You can't do that, this tv doesn't have RCA audio outputs. You will have to connect it using the Optical output - an optical cable is required.
Posted on Mar 19, 2011
SD Tech
  • 14553 Answers
SOURCE: my toshiba tv model 32yt56b2 wont power on light flashes and makes clicking sound
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.3_29_2012_1_18_58_pm.jpg
Posted on Mar 29, 2012
How do I fix my LG 42PG25 plasma TV? The model number is 42PG60UA. What should I try next see details below?
It is 19 years old, and I would say beyond economical repair. You will be chasing blown components that were damaged when the power surge or brownout occurred. It is only a 42" set and it is plasma. Technology has moved on to 4K Ultra HD, LED and smart hubs. Treat yourself, it's Christmas :>)
Dec 19, 2017 | LG Televison & Video
I have an LG smart tv model no. 42LV3730-TD- standby light flashes blue once then it goes red again then nothing.i hear a clicking noise from the back of the tv but that's it. No sound/picture nothing.can...
In most of the case, the problem is a defective main digital board (component loses connections on board). you may try this at your own risk:.
Re-Flow Soldering Procedure for LG Main Board
    1.Pre-heat your kitchen oven to 385 degree (No more than 400 degree);
    2.Put the main board on a card board (like a pizza box board) in the oven;
    3.Heat it for 10 minutes (No more than 10 minutes);
    4.Turn the oven off & leave the door open, at this moment, do not touch or move the board until it colds down to the room temperature.
    5.Install the board in the TV & try it out.
Aug 31, 2017 | LG Televison & Video
I NEED AN LG INSTRUCTION MANUAL FOR MODEL 42PC7RVH-TA. I NEED TO TUNE MY TV
LG 42PC7RVH-TA
Hello Joyce,
Service manual site (below)
Personally I'd try talking with the shopjimmy.com folks
"tune" has such an ominous sound when talking of
Plasma sets...
42PC7RVH-TA
Download lg 42pc7rvh 42pc7rvh ta plasma tv service manual
Dec 11, 2016 | LG Televison & Video
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
I have an LG plasma tv model # 42pg20-ua. Everytime I try to turn it on the tv keeps clicking turning from blue to red. Tv never actually turns on. I keep trying to turn it on, but it just clicks and...
that is usually a t-con board or video card. ebayers usually have those parts reasonable.
that's how I fixed one of mine.
it could be the power board which is the costlier part.
Aug 01, 2017 | Televison & Video
Hi I just bout a LG plasma modle 50pt250,ta and im trying to hook up my surround sound to it, but I dont know where to put the RCA cables on the back of the tv?
Mar 19, 2011 | LG Televison & Video
Hi
Hope this helps
Apr 05, 2010 | LG 60PC1D 60 in. Plasma Television
Televison & Video Logo
78 people viewed this question
Computer Repairing
Computer Repairing
