Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint WD440G Hi When I start a cycle the washer fills up with water then stops, The on/off button then flashes so does drying high heat, reduce creases and time saver. resetting it does not help, happens on various cycles not just one. Any ideas? thanks
  • 2 more comments
  • Anonymous Dec 08, 2007
    did you ever find out what it was - I have the same problem
    I have had the same problems myself. Had an engineer from Hotpoint out to fix but he said there was no fault registered when he ran a diagnostic test from him laptop. He just said unplug from the mains an it will work. Yes it did for about two washes then it stuck again on a the last spin and ON/OFF and dryer button flashing. I pulled the washer out switched off at mains but sill keeps cutting off. I am sooooo fed up with this I will be contacting Hotpoint again tomorrow. Did you manage to get yours fixed. Mine is only 8 months old
  • Tina23 Mar 26, 2008
    The washing machine got deliverd yesterday. I have tried to do the
    "first wash" however the washing machine is giving an error. The
    machine is pomping water and spins for 5 mins and then stops and two
    options "drying high heath" and "reduce creases" start flashing. I
    tried to do the first wash a couple of times but with no luck. Help!
  • Anonymous Apr 13, 2008
    on/off button flashes
Posted on Feb 24, 2008
Hotpoint WD440 washer/dryer wont control.when plugged in 4 lights flash and it goes to pump out . no switch has any effect. the lights flashing are the on/off ,drying high heat.reduced creases and time...
The NTC for the dryer is situated on top of the dryer heater box, fault can often be caused by a simple broken wire, they are very weak at this point.
its the sensor on the dryer
if you take off the top, its mounted on top of the dryer box, usually has a white plug with 2 black wires attached
Dec 13, 2011 | Hotpoint Ariston WD440G Front Load...
Hi, I have a Hotpoint WD440 Wash / Dryer. When switched on at the mains electricity the "Rinse Hold, Reduce Creases, Drying Heat, time saver, dry and on/off buttons all flash for approx 5 mins, then...
The flashing lights are an error code (Which I can't quite figure, but I believe ARE associated with a blocked filter. Is it possible that the slime and mess extended beyond the filter?
Before you go throwing the machine away, Unplug it from the mains (NOT just turn it off) to allow the machine to reset and while it's unplugged, stuff your garden hose up the waste water pipe and turn it on full blast to blow any remaining debris out of the way. (Wrap a towel over the end of the pipe to soak up the spliiage as one will not fit neatly into the other).
As the Dr Pepper ad says - "What's the worst that could happen?"
Jul 07, 2011 | Hotpoint Ariston WD440G Front Load...
Hotpoint Aquarius WD440G
Unplug the machine from the wall for 5 minutes, then plug it back in and try it again. If the lights come back, the control board needs to be replaced.
Jul 28, 2017 | Hotpoint Ariston WD440G Front Load...
That means that the machine detected a problem at a certain point of the cycle and stopped.
If the machine stops when filling check the inlet valve and the water supply.
If it stops because ofervilling check the water level switch.
If it stops when the cycle is hot water only , then check the heating element.
If it stops when draining, then inspect drain filter, drain pump , and drain hose. You access the drain hose removing a panel at the front side of the machine.
If it stops when motor is supposed to spin faster (rinse) then it is motor control unit or motor coupler.
If it is none of the above, then it is a defective control board.
Feb 16, 2009 | Hotpoint Ariston WD440G Front Load...
Hotpoint wd44d wash/dryer wont finish a wash nor wont pump out
there may be something stuck in the pump itself. hairgrips and brawires are a common find.
Jan 19, 2009 | Hotpoint Ariston WD440G Front Load...
Hotpoint DW440 flashiing lights
I have just seen the same problem on a neighbours WD440G. I have tracked down the problem to the main circuit board at the back, bottom of the machine. Transistor/FET Q9 has exploded. There was water at the bottom of the machine and the wiring in the vicinity of the nearby connector was wet.
This neighbour is in no financial position to be able to buy a new board, or get an official Hotpoint engineer to confirm what we already know. Anyone know where I can get a schematic diagram for the board?
Dec 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd440 aquarius
Not all programes fill with hot water.Try on 95 degree wash if it takes hot water ,you are dialing a prog,that does not take HOT.
Oct 31, 2008 | Hotpoint Aquarius WD63 Front Load...
ON/OFF & Time saver Button keeps flashing
For mine, it started flashing the on/off light along with the "drying high heat" and the "reduce crease".
Unplugging the unit for 30 minutes appears to have reset the machine and it is now working.
Aug 18, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
399 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
