Question about Coffee Makers & Espresso Machines
Delonghi rotofriteuse plus
The light on my deep fryer isn't lighting up when I turn it on at the power switch wall,and isn't heating up
  • 77 Answers
SOURCE: Deep fryer wont heat up
I have the exact same deep fryer and it was doing the same thing if you take out all of the oil and clean it realy good it should work again
Posted on Feb 19, 2008
SOURCE: Bravetti Deep Fryer Model F1053B Not getting Power anymore
Hey guys I fixed my problem...yay. All I did was to push a red button which I beleive is a resset button on the back of the on/off button part. It ain't visible but if you look in the holes of the screws that hold this part together (they are far down in the hole) one of them hides a small red button. Push it down with a toothpick or anything small enough to fit the hole and you're done. Plug it back and it works.
Posted on Jun 30, 2008
SOURCE: Deep fryer not working
May Blow Your Fuse Replace the fuse
Posted on Jul 18, 2008
SOURCE: my bravetti dep fryer F1063B wont heat up
In the back of the unit there is a recessed reset switch(red) Depress it until it clicks.
Posted on Mar 13, 2009
SOURCE: comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Posted on May 26, 2009
Tip
Will not power on, powers off, will not heat Pwr light out or goes out.
Like most of the problems listed on FixYa about this Deep Fryer ours worked fine the last time we used it, but we could not get the power light to come on again. I found that there is s SAFETY Micro-switch on the heating element control unit. This switch prevents the heating element from being turned on when it is not in the Fryer Pan. The accuator lever for the switch is located under the guide slides on the heating element control unit. It is a metal lever which is moved as you mount the heating element control unit on the fryer pan. You have to look closely under one of the guide ledges on the heating control unit to see it . The problem is that over time the adjustment of the lever changes as it flexes under use. I simply readjusted the lever by forming it with a pair of long-nosed pliers. CAUTION !!!!!!! You can bend the lever so far that the switch is closed all the time defeating the Safety Switch and create a hazard in that the unit will heat as soon as you plug it in whether inserted in the Fryer Pan or lying out on any surface. This might burn someone or cause a fire. Good Luck
X-IBM
on Oct 09, 2008 | GE 168997 Deep Fryer
Delonghi deep fryer D14527DZ
Hi there.
You can download Owner's Manual for your fryer at the Cutomer care tab on http://www.delonghiusa.com
Regards.
Nov 26, 2011 | DeLonghi D14527DZ Dual Zone Deep Fryer
D14527DZ Delonghi deep fryer
Hi there.
You can download Owner's Manual for your fryer on the Customer Care tab of http://www.delonghiusa.com.
Regards.
The pilot is on but the switch won't turn the fryer on. The gas is on but it just wont fire up? Dean Fryer
I can tell you from my own experience with fryers, that they take quite some time to heat up....before lighting.... The probe takes some time to get hot, before it will kick on and light. You normally have to hold the light button on for some time, before the manual fryers will light. I have helped many a customer who cannot seem to get their manual gas fryers to light, and normally it's because they don't hold the light button down long enough. The sensor in there takes alittle time to heat up and it tells the fryer it's time to light. I think people get alittle scaried with gas and just don't hold it down long enough. Try holding that button in longer first, then light it... It should work. If not, call us and we'll try to walk you through it.... Our service tech is Ray, and I'm Susan with Restaurant Equipment Outlet, Cincinnati, Ohio, 888-542-5959. Thanks and good luck, Susan
Sep 10, 2011 | Frymaster Dean 2424G Deep Fryer
Light comes on, but it no longer heats up.
I have a similar model of DeLonghi fryer, and I have read that many customers have problems with their fryers not heating, after owning and using them regularly for some time. Mine gives an error message and stops heating, once in a while. The lights remain on, but it displays an error message on the temperature readout. I've found that detaching the magnetic safety cord and thoroughly cleaning both the cord and the connections on the back of the machine makes a big difference. Your mileage may vary.
Mar 04, 2011 | DeLonghi D14522DZ Deep Fryer
Deep Frier power indicator light is on but will
Most fryers have what is called a hi limit. When the oil temp reaches a certain Max temp this switch opens the circuit and will not allow the unit to heat. On commercial fryers, the hi limit has a really small red plunger button. Push it in to reset.
Mar 28, 2009 | Kitchen Appliances - Others
My DeLonghi D14527DZ will not "power up"
FIRST OF ALL YOU COULD CHECK THE FUSE IN THE PLUG IF THIS IS OK THEN CHECK THE THERMOSTAT SWITCH TURN IT BACK AND FORTH AND MAKE SURE YOU CAN HEAR A CLICK IF NOT REPLACE THE SWITCH
Feb 19, 2008 | DeLonghi D14527DZ Dual Zone Deep Fryer
Coffee Makers & Espresso Machines Logo
73 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
