Question about GE WBVH6240F Front Load Washer
GE Front Loader Washer - Not washing
Everything works fine on the machine until the wash cycle. I put the clothes in, the door locks, turns the clothes one way, then the other. The door then unlocks, pauses, relocks and the water goes into the machine. After that, the machine won't spin to wash the clothes. Can some give me some advice?
  • 2 more comments
  • SteveGEowner Feb 07, 2008
    This problem is caused by the trap in the bottom of the washer is full. When this happens the washer cannot drain and so it does not continue the cycle. Unplug the unit. You will have to remove the bottom panel on the front of the washer. Once removed you will find a white plastic plug that you can unscrew. It is near the electrical connections be very careful. You will need towels to clean up the trapped water that will come out when you remove the plug. When you pull out the plug remove all debris from the attached trap and the hose leading into it. Replace plug and dry up any water you have spilled on the electrical connections. Plug in washer and it will work like new. You will have to repeat this procedure every few months if you have kids who leave stuff in their pockets.
  • Anonymous Mar 19, 2014
    DOOR LOCK LIGHT FLASHES
  • Anonymous Mar 24, 2014
    front loader was on spin cycle and the machine stop door is lock how can I unlock it
  • Anonymous Mar 31, 2014
    I have a GE WPRE8150K top loader washing machine I purchased in 2010, I push the button it won't turn on, start the water flowing.
  • 641 Answers
It sound like a lid switch issue. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Look that the switch is not broken or loose. If all is fine, you should replace the switch. Good luck!
Posted on Aug 27, 2007
6ya staff
SOURCE:
The door on LG front loader washing machine won’t unlock
hi Margaret.
If the washing machine malfunctions or you need to stop the cycle and retrieve the clothing, you can force the door to unlock.
  • Open the door after the "Door Lock" indicator turns off. ...
  • Press the "On/Off" button, if the washer is not already on.
  • Select the "Spin Speed" button to turn on the Drain & Speed cycle.
  • or go to this link and have a read up.
LG front loader washing machine wont unlock Google Search
Dec 12, 2017 | LG Washing Machines
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
Door on ge front loader washer leaks, door gasket is fine. Could it be the lock not working properly
Yes it could be the door lock not pulling the door in enough to make the seal. Solution... Remove covers and with door pressed in hard, ( You may need help ), adjust the lock mechanism to make seal. Put lock-tite on the threads after it works for you. This will prevent the shaking of the washer from losening of the nuts again.
Aug 01, 2010 | GE WSXH208A Front Load Washer
The door is locked on my front loader washer.
PUSH THE START PAUSE BUTTON, AND CLEAN THE LINT TRAP AT THE BOTTOM OF THE UNIT
ROB
Apr 14, 2009 | GE WPXH214A Front Load Washer
Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Apr 09, 2009 | Whirlpool WFC7500VW Washer
Whirlpool front loader not working - Control Lock Light On
Press the End of Cycle Signal for 3 seconds until the Control Locked light turns off.
Apr 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock is on my front loader.
ok, you are in the model selection part of the service mode. for 6240 I believe the model code is 3 select this and press start. normally to release control lock press and hold small I button by start button.
if model selection in incorrect it can still be corrected. only difference in models is cycles matching the labels. you can tell by the time indication for each cycle if it doesnt look right then check book inside top cover
Mar 29, 2009 | GE WBVH6240F Front Load Washer
Maytag Neptune Front Loader Washer
Sounds like the door lock unit isn't locking and may be bad. It is also a possiblity but not likely that there could be a problem with the computer board but start with the door lock unit first
Dec 29, 2008 | Maytag Neptune Washer
Frigidaire front loader washing machine won't spin...
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
May 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
GE WBVH6240F Front Load Washer Logo
356 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
