Question about Dishwashers
Electric plug stuck into back of bosch dishwasher
Plug was pulled out of wall to move dishwasher but is stuck onto the back so impossible to get back in
4 Suggested Answers
  • 1462 Answers
SOURCE: Bosch dishwasher is stuck on drain cycle
cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
Posted on Oct 20, 2008
  • 160 Answers
SOURCE: The handle of my Bosch exxcel dishwasher is stuck
i usually use 2 thin bladed screwdrivrs and flip the catch back over without dismantelling the door.
for the catch to flip usually means the unit is not level as the door is not closing squarely..
Posted on Dec 17, 2009
  • 457 Answers
SOURCE: Bosch Classixx Dishwasher stck in one program
the module must be changed. let me know what happens. im a old bosch tech
Posted on Feb 26, 2010
Bosch diswasher e15 light
Most likely it is the flood switch trigger causing the problem.
Many reasons for this but mainly it means there could be water leaked into the base of dishwasher where flood switch is located.
Or if you have Aquastop fitted in the water inlet hose then the hose might have kinked due to age or being pressed between cabinet wall and dishwasher. Turn power off to dishwasher at mains plug and pull it out. Check hoses. Tilt it about 20 degrees to one side on a towel and hold for about 10 secs. This should get the water out. Wait an hour or so to dry any moisture in the base and then plug back in and turn on. This should reset the E15 fault.
Apr 21, 2014 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
How do you check for error codes on a Bosch SHY56A05UC/23 Dishwasher? My dishwasher runs continuously in the drain mode and the "cancel drain" feature does not work.
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Jan 29, 2011 | Bosch 24 in. SHY56A05 Stainless Steel...
Not releasing tablet and not filling or washing
Ensure that the dishwasher has sufficient electricity (e.g.: wall switch, plug, etc.), and that the water supply is on. Otherwise, contact an appliance service company.
Feb 22, 2010 | Bosch Dishwashers
Danby Dishwasher stuck in drain cycle after wrong soap use
There might be water in the overflow sensor. I unloaded the dishwasher and lifted the front so the dishwasher rested on its back. There's a narrow gray tube that runs down from the bottom right of the door. The tube runs into a white piece of plastic with some wires coming out of it. There is a rubber plug that covers a nipple on the plastic. Pull the rubber plug off. Mine was quite tight. Tip the dishwasher back onto its casters to drain the water from the overflow. Check to see if the dishwasher functions normally, then put the rubber plug back on.
Dec 10, 2009 | Danby DDW1805W Designer Series...
Our Bosch SHY66C05 door latch is stuck in locked position
you have to pull back the spring or replace the lock. the repair is pretty easy.let me know what happen.
Nov 07, 2009 | Bosch 24 in. SHY66C05 Stainless Steel...
No idicator lights door wont close
Door may have been pulled off its hinges, the d/w doors electric is connected at the bottom of the door and when it was pulled, there is the possibility that a short occurred.
The door of the bosch will pull straight up, carefully remove the door and then carefully place door back onto the hinges and making sure the door is seated properly. The door should close. The hope is that once the door closes, the sensors to the door should hopefully work, properly.
Try these before the more costly options which is either a new door or the call of a service technician.
Oct 02, 2009 | Bosch 24 in. SHY56A05 Stainless Steel...
My bosch classixx dishwasher won't drain
It doesnt take much to stop a drain motor from rotating. If you dont know the bosch washer, you will find it almost impossible to get into it One thing, if the door is opened, the bottom tray removed then the sieves untill no loose items are left, you will notice a little piece of plastic that can be pulled out to allow you access to your drain pump impellar. Remove the obstruction and turn with your finger. Does it turn easily.? if so reassemble and try again.(note if you dont replace the plastic part back properly, the pump will run but not pump correctly.)
Sep 24, 2009 | Bosch Dishwashers
Dishwasher sometimes works
where is the appliance plugged in if the three pin plug is directly behind it the plug sinks into the insulation on the back then when the appliance cools it pulls the plug out of the wall
Mar 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
SHU 9922 UC Top wash arm came off
We've just had the same problem, after a little frustration trying to get it to fix on to the back wall of the washer, we realised that it fixes onto the underside of the actual tray. When you pull the tray out, the arm comes with it, and then when you push it in, it engages with the holes.
Easy when you know how!!
Jan 14, 2008 | Bosch SHU9922UC Built-in Dishwasher
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
